标题: iPhone6手机专题帖 [打印本页]
作者: lucky!    时间: 2016-11-23 10:10
标题: iPhone6手机专题帖
iPhone6手机专题帖
  iphone6无显示断线维修案例
  http://www.chinafix.com/thread-986553-1-1.html
  iPhone6螺丝柱断线导致开机不显示维修一例
  http://www.chinafix.com/thread-998681-1-1.html
  iPhone6断线故障维修实例!
  http://www.chinafix.com/thread-1013915-1-1.html
  iphone6现不显示故障,经过维修成功解救!
  http://www.chinafix.com/thread-993663-1-1.html
  iPhone6螺丝柱 接线图 左下角
  http://www.chinafix.com/thread-957652-1-1.html
  iPhone6/6p 无服务,无触摸维修
  http://www.chinafix.com/thread-939569-1-1.html
  iphone6被摔无显示无wifi维修一例
  http://www.chinafix.com/thread-973115-1-1.html
  iPhone6换屏后无显示
  http://www.chinafix.com/thread-978095-1-1.html
  关于IPHONE6扩容的那些事
  http://www.chinafix.com/thread-906577-1-1.html
  iphone6 进水暗屏维修
  http://www.chinafix.com/thread-963288-1-1.html
  iPhone6被摔后自动重启维修一例
  http://www.chinafix.com/thread-981685-1-1.html
  iPhone6 刷机报错"9",你遇到了吗
  http://www.chinafix.com/thread-1017096-1-1.html
  iphone6换屏不亮二次维修
  http://www.chinafix.com/thread-969765-1-1.html
  iPhone6进水导致指纹失灵故障维修一例!
  http://www.chinafix.com/thread-1019000-1-1.html
  iphone6 闪光灯无法打开故障维修一例
  http://www.chinafix.com/thread-996077-1-1.html
  苹果iPhone6换屏不亮二修
  http://www.chinafix.com/thread-942154-1-1.html
  iPhone6红屏 刷机报错4014维修案例
  http://www.chinafix.com/thread-1028558-1-1.html
  iPhone6开机反复重启故障维修实记
  http://www.chinafix.com/thread-1006198-1-1.html
  iphone6无法唤醒小修
  http://www.chinafix.com/thread-1010740-1-1.html
  iPhone6不充电解决方法,联机,电压全部正常
  http://www.chinafix.com/thread-973452-1-1.html
  iphone6刷机报错4005维修实记
  http://www.chinafix.com/thread-1006567-1-1.html
  iphone6搬板干货分享
  http://www.chinafix.com/thread-1011561-1-1.html
  苹果6无法打开指纹、无法添加指纹故障维修
  http://www.chinafix.com/thread-977458-1-1.html
  IPHONE6手机红屏蓝屏维修实例分析,转载
  http://www.chinafix.com/thread-1003278-1-1.html
  iphone6手机工作时序图分析
  http://www.chinafix.com/thread-1002627-1-1.html
  iphone6手机待机工作时序图分析
  http://www.chinafix.com/thread-1002634-1-1.html
  iPhone6和6plus如何进入DFU模式/刷机知识
  http://www.chinafix.com/thread-887146-1-1.html
  iphone6进水维修,夏天到了能不能长点心呐!
  http://www.chinafix.com/thread-985108-1-1.html
  iPhone6开机不显示维修一例
  http://www.chinafix.com/thread-1001730-1-1.html
  Iphone6、6Plus显示屏接口问题
  http://www.chinafix.com/thread-862139-1-1.html
  iPhone6经常无服务、不显示串号故障维修案例
  http://www.chinafix.com/thread-1010856-1-1.html
  iPhone6充电导致不开机维修案例
  http://www.chinafix.com/thread-1030456-1-1.html
  iPhone 6 指纹不能用 漏电故障维修案例
  http://sj.xinxunwei.com/case/2016/1124/662.html
  iPhone6爆屏 更换屏幕图文并茂!
  http://www.xinxunwei.com/wxjs/sjcjjc/2016/1123/6479.html
  iPhone6电量至40%自动关机拆机换电池过程如下:
  http://www.xinxunwei.com/wxjs/sjcjjc/2016/1017/6321.html
  Iphone6改7全程实录
  http://www.xinxunwei.com/wxjs/sjcjjc/2016/0926/6244.html
  iphone6维修实例没有2G信号,有3G4G信号!
  http://www.xinxunwei.com/pgsjwxpx/04115538.html
  iPhone6P摔出好几种故障,奇葩故障维修!
  http://www.chinafix.com/thread-1010437-1-1.html
  IPHONE6 各种故障维修电路图
  http://www.chinafix.com/thread-931928-1-1.html
  iphone6 CPU发热、打电话不灭屏故障维修一例
  http://www.chinafix.com/thread-982475-1-1.html
  iphone6故障维修方法彩图送大家了
  http://www.chinafix.com/thread-842251-1-1.html
  摄像头接口定义及摄像头故障维修攻略
  http://www.chinafix.com/thread-944107-1-1.html
  有关iPhone刷机常见错误代码
  http://www.chinafix.com/thread-856109-1-1.html
  iPhone6被摔现复杂故障维修分析
  http://www.chinafix.com/thread-979890-1-1.html
  iphone6泡澡致花屏不开机,洗澡真棒!可惜代价不小!
  http://www.chinafix.com/thread-990172-1-1.html
  iPhone6拍照后照片无法保存故障维修方法
  http://www.chinafix.com/thread-972347-1-1.html
  iphone6闪光灯不工作维修一例
  http://www.chinafix.com/thread-983974-1-1.html
  iPhone6插卡无服务维修案例
  http://www.xinxunwei.com/sjwx/11306558.html
  iPhone6换屏不当致蓝屏不开机!
  http://www.chinafix.com/thread-1031968-1-1.html
  iPhone6进水不开机维修案例
  http://www.xinxunwei.com/sjwx/12076612.html
  iPhone6充电后不开机,刷机报错4005维修案例
  http://www.chinafix.com/thread-1034118-1-1.html
  iPhone6不显示维修案例
  http://www.xinxunwei.com/sjwx/12016563.html
  不用再找了,iPhone全系列图纸全在这了
  http://www.chinafix.com/thread-930985-1-1.html
  iPhone6不认SIM卡故障维修篇
  http://www.chinafix.com/thread-1032569-1-1.html
  iphone6 更换硬盘后无服务故障维修
  http://www.chinafix.com/thread-1032254-1-1.html
  iPhone6 无显示、无背光维修思路分析
  http://www.chinafix.com/thread-1034665-1-1.html
  iPhone6开机不正常,灰屏重启故障维修
  http://www.chinafix.com/thread-1035448-1-1.html
  iPhone6 WIFI打不开故障维修
  http://www.xinxunwei.com/sjwx/12126649.html
  iPhone6 摔虚焊CPU 灰屏重启故障维修
  http://www.xinxunwei.com/sjwx/12136660.html
      iPhone6 旧貌换新颜,见证奇迹的时刻到了!
      http://www.chinafix.com/article-8677-1.html
  iPhone6开机花屏、刷机报错解决全过程
  http://www.xinxunwei.com/sjwx/12196704.html
  iPhone6 Wifi不能用故障维修
  http://www.xinxunwei.com/sjwx/12206717.html
  iPhone6代插卡信号弱故障维修
  http://www.chinafix.com/thread-1041448-1-1.html
  iPhone6 摔后无照相,温度过高故障维修
  http://www.chinafix.com/thread-1045177-1-1.html
  iPhone6蓝屏重启、不充电、不联机维修案例
  http://www.chinafix.com/article-8836-1.html
  iPhone6充电故障 不充电不联机维修案例
  http://www.chinafix.com/thread-1045363-1-1.html
  iPhone6进水不开机 40Ma小电流故障维修
  http://www.chinafix.com/thread-1046471-1-1.html
  iPhone6 可以录像不能照相故障维修
  http://www.xinxunwei.com/sjwx/02067023.html
  iPhone6按#06#不出串号,无法拨打112维修思路分析
  http://www.xinxunwei.com/sjwx/02117069.html
  iPhone6开机灰屏 刷机报错14故障维修
  http://www.chinafix.com/thread-1048751-1-1.html
  iPhone6突然无服务 无法打电话故障维修
  http://www.chinafix.com/thread-1048974-1-1.html
  iPhone6 WiFi故障引起的卡机 无唤醒维修思路分析
  http://www.chinafix.com/thread-1049692-1-1.html
  iPhone系列重力、陀螺仪、指南针三者都无效的检测方法
  http://www.xinxunwei.com/sjwx/02207130.html
  iPhone6 不开机故障维修
  http://www.xinxunwei.com/sjwx/02227146.html
  iPhone6不开机 待机漏电故障维修
  http://www.xinxunwei.com/sjwx/02237155.html
  iPhone6进水 不开机不联机漏电40mA维修案例
  http://www.chinafix.com/thread-1050237-1-1.html
  iPhone6/6Plus重摔不开机故障维修
  http://www.chinafix.com/thread-1050496-1-1.html
  苹果iPhone6重摔后多故障解决过程与思路普及
  http://www.chinafix.com/article-8992-1.html
  iPhone6手机进水 不开机维修一例
  http://www.chinafix.com/thread-1057507-1-1.html
  iPhone6摔后无服务故障维修
  http://www.xinxunwei.com/sjwx/03287302.html
  iPhone6卡槽坏了 飞线修复案例
  http://www.xinxunwei.com/sjwx/03297305.html
  iPhone6手机wifi打不开故障维修
  http://www.xinxunwei.com/sjwx/04047337.html
  iPhone6手机电池充不进电 重启故障维修
  http://www.chinafix.com/thread-1061656-1-1.html
  iPhone6小电流 不联机 手机无法开机故障维修
  http://www.chinafix.com/thread-1060027-1-1.html
  iPhone6手机无法开机 刷机报错4013故障维修
  http://www.chinafix.com/thread-1060697-1-1.html
  iPhone6指纹不能用 耗电快故障维修
  http://www.xinxunwei.com/sjwx/04057343.html
  iPhone6摔后手机开不了机故障维修
  http://www.xinxunwei.com/sjwx/04157389.html
  iPhone6摔后白苹果重启 手机无法开机故障维修
  http://www.chinafix.com/thread-1063145-1-1.html
  iPhone6更换电池导致手机屏幕不显示故障维修
  http://www.chinafix.com/thread-1063717-1-1.html
  iPhone6前摄像头不能用故障维修
  http://www.chinafix.com/thread-1064089-1-1.html
  iPhone6手机触摸屏失灵,前置摄像头不能用维修全过程
  http://www.chinafix.com/thread-1064597-1-1.html
  iPhone6手机手电筒不能用故障维修
  http://www.chinafix.com/thread-1068297-1-1.html
  iPhone6手机拍照黑屏 闪光灯打不开故障维修
  http://www.chinafix.com/thread-1066579-1-1.html
  iPhone6手机指纹不能用维修案例
  http://www.chinafix.com/thread-1064795-1-1.html
  iPhone6后摄像头不能用 黑屏维修案例
  http://www.chinafix.com/thread-1065040-1-1.html
  iPhone6手机进水开不了机维修案例
  http://www.chinafix.com/thread-1070596-1-1.html
  iPhone6开机满屏英文 手机无法开机故障维修
  http://www.chinafix.com/thread-1071533-1-1.htm
  iPhone6摔后无服务 正在搜索故障维修
  http://www.chinafix.com/thread-1071223-1-1.html
  苹果6代手机没信号 拨打*#06#不显示IMEI串号故障维修
  http://www.chinafix.com/thread-1072378-1-1.html
  iPhone6手机触摸屏失灵故障维修
  http://www.chinafix.com/thread-1154715-1-1.html
  iPhone6手机开机白苹果重启保资料维修一例
  https://www.chinafix.com/thread-1158472-1-1.html
  苹果6代手机没信号 拨打*#06#不显示IMEI串号故障维修:
  https://www.chinafix.com/thread-1072378-1-1.html
  iPhone6代插卡信号弱故障维修:
  https://www.chinafix.com/thread-1041448-1-1.html
作者: バ幸福De右岸    时间: 2016-11-23 17:39
这个专帖好多帖子啊,废了不少时间写的吧
作者: 天意wx    时间: 2016-11-23 21:47
继续总结补充吧 有一定的查找意义
作者: 句容诚信电脑    时间: 2016-11-23 22:47
看来还是小6修的多啊
作者: hcrt    时间: 2016-11-25 11:18
バ幸福De右岸 发表于 2016-11-23 17:39
这个专帖好多帖子啊,废了不少时间写的吧
还可以
作者: 胡大敏    时间: 2016-12-7 21:32
谢谢分享了
作者: 乐呵呵    时间: 2016-12-8 08:12
赞一个。好好的要1个1个看看把
作者: 小汇    时间: 2016-12-8 18:28
谢谢整理出来
作者: 胡大敏    时间: 2016-12-19 21:54
谢谢分享,,
作者: woaimeinv5    时间: 2016-12-19 23:32
整理得很好。
作者: Jokers    时间: 2016-12-20 21:56
6P刷机错误-1是哪里出问题了呀。。客户升级出错之前听说手机升级10.1.1会导致手机崩溃是真的嚒?
作者: Jokers    时间: 2016-12-27 20:28
6代不震动的有么
作者: 花落花开    时间: 2016-12-27 23:18
楼主辛苦了,谢谢分享
作者: 小峰维修88    时间: 2017-1-7 16:03
这个总结的太好了,适合我们新手学习。
作者: バ幸福De右岸    时间: 2017-3-4 10:36
小峰维修88 发表于 2017-1-7 16:03
这个总结的太好了,适合我们新手学习。
其实也可以使用论坛的搜索功能,来找到自己需要得资料,效果更好
作者: nblxg    时间: 2017-3-18 13:58
作者: 上海企升科技    时间: 2017-4-11 21:51
看了好久了 这些经验很好
作者: 邵陪陪    时间: 2017-4-18 11:59
谢谢分享
作者: 名创科技    时间: 2017-5-12 20:50
苹果6的触摸问题遇见的最多。
作者: jkj413    时间: 2017-6-3 16:15
有没有关于6代指纹不能激活的
作者: woaiweixu    时间: 2017-6-3 18:12
整理了这么多,也是不容易,感谢楼主,方便了很多人
作者: zy8428    时间: 2018-6-24 11:44
这个太好了 有空慢慢一个一个学习
