2937| 12
T40 触发后电流上到0.52就掉电,待机也不正常了(坚决要求版主清理3楼的ID) |
该主题被收录于: 待机正常不触发 https://www.chinafix.com/zt/45437-1.html 掉电后不触发 https://www.chinafix.com/zt/30504-1.html 触发不上电 https://www.chinafix.com/zt/19209-1.html 触发 不上电 https://www.chinafix.com/zt/78960-1.html 上电就掉电 https://www.chinafix.com/zt/100844-1.html 掉电不触发 https://www.chinafix.com/zt/61834-1.html 无待机电流 https://www.chinafix.com/zt/40740-1.html 待机电流大 https://www.chinafix.com/zt/83631-1.html | ||
相关帖子
