- 积分
- 156
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2009-3-4
- 精华
DC IN
Error code Meaning
10h AC Adaptor output voltage is more than 16.5 V.
12h Current from the DC power supply is more than the limit (6.05 A).
13h Current from the DC power supply is more than the limit (0.5 A) when there is no load.
14h Current sensing IC is not normal.
Main Battery
Error code Meaning
21h Main battery charge current is more than 6.05 A.
22h Main battery discharge current is more than 0.5 A when there is no load.
23h Main battery charge current is more than 3.1A when DC IN direct charge is off.
24h Current sensing IC is not normal.
25h Main battery charge current is more than 0.3A when the battery isn't being charged.
S3V output
Error code Meaning
40h S3V voltage is not more than 3.14V when the computer is powered on or off.
45h S3V voltage is not more than 3.14V when the computer is supports CV and is booting up.
C5V output
Error code Meaning
50h C5V voltage is more than 6.00 V when the computer is powered on or off.
51h C5V voltage is not more than 4.50 V when the computer is powered on.
52h C5V voltage is not more than 4.50 V when the computer is booting up.
53h C5V voltage is not normal when the computer is suspended.
54h C5V voltage is not normal when the computer supports CV and is suspended.
55h C5V voltage is not more than 4.50V when the computer supports CV and is booting up.
C3V output
Error code Meaning
60h C3V voltage is more than 3.96 V.
61h C3V voltage is not more than 2.81 V when the computer is powered on.
62h C3V voltage is not more than 2.81 V when the computer is booting up.
63h C3V voltage is not normal when the computer is suspended.
64h C3V voltage is not normal when the computer supports CV and is shut down.
65h C3V voltage is not more than 2.81V when the computer supports CV and is booting up.
PPV output (PCU core voltage)
Error code Meaning
70h PPV voltage is more than 1.56V when the computer is powered on or off.
71h PPV voltage is not more than 0.68V when the computer is powered on.
72h PPV voltage is not more than 0.68V when the computer is booting up.
73h PPV voltage is not less than 0.68V when the computer is powered off.
BGVSNS output
Error code Meaning
80h BGVSNS voltage is not more than 1.62V when the computer is on or off.
81h BGVSNS voltage is not more than 1.02V when the computer is powered on.
82h BGVSNS voltage is not more than 1.02V when the computer is booting up.
83h BGVSNS voltage is not less than 1.02V when the computer is powered off.
84h BGVSNS voltage is not more than 1.62V when the computer is suspended.
1R5-E1V output
Error code Meaning
90h 1R5-E1V voltage is more than 1.80V when the computer is powered on or off.
91h 1R5-E1V voltage is not more than 1.275V when the computer is powered on.
92h 1R5-E1V voltage is not more than 1.275V when the computer is booting up.
93h 1R5-E1V voltage is not less than 1.275V when the computer is powered off.
94h 1R5-E1V voltage is not more than 1.275V when the computer is suspended.
1R8-E1V output
Error code Meaning
A0h 1R8-E1V voltage is more than 2.16V when the computer is powered on or off.
A1h 1R8-E1V voltage is not more than 1.53V when the computer is powered on.
A2h 1R8-E1V voltage is not more than 1.53V when the computer is booting up.
A3h 1R8-E1V voltage is not less than 1.53V when the computer is powered off.
A4h 1R8-E1V voltage is not more than 1.53V when the computer is suspended.
2R5-SNS output
Error code Meaning
B0h 2R5-SNS voltage is more than 3.00V when the computer is powered on or off.
B1h 2R5-SNS voltage is not more than 2.125V when the computer is powered on.
B2h 2R5-SNS voltage is not more than 2.125V when the computer is booting up.
B3h 2R5-SNS voltage is not less than 2.125V when the computer is powered off.
B4h 2R5-SNS voltage is not more than 2.125V when the computer is suspended.
1R25-E1V output
Error code Meaning
C0h 1R25-E1V voltage is more than 1.50V when the computer is powered on or off.
C1h 1R25-E1V voltage is not more than 1.063V when the computer is powered on.
C2h 1R25-E1V voltage is not more than 1.063V when the computer is booting up.
C3h 1R25-E1V voltage is not less than 1.063V when the computer is powered off.
C4h 1R25-E1V voltage is not more than 1.063V when the computer is suspended.
2R5-E1V output
Error code Meaning
D0h 2R5-E1V voltage is more than 3.00V when the computer is powered on or off.
D1h 2R5-E1V voltage is not more than 2.125V when the computer is powered on.
D2h 2R5-E1V voltage is not more than 2.125V when the computer is booting up.
D3h 2R5-E1V voltage is not less than 2.125V when the computer is powered off.
D4h 2R5-E1V voltage is not more than 2.125V when the computer is suspended. |
