- 积分
- 511
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-12-14
- 精华
换了USB 键盘也一样,一加载系统时就蓝屏闪一下如下画面重启
if heis is the first time you`ve seen this stop error screen
restart your computer.if this screen appears againfollow these steps:
check to be sure you have adequate disk space. if adriver is ident ified in the stop
message. disable the driver or check with the manufacturer for driver updates.try changing
video adapters
check with your hardware vendor for any bios updates.disable bios memory options such as
caching or shadowing. if you need to use safe mode to remove or disable components,restart
your computer, press fb to select advanced startup iptions. and thenselect safe mode.
technical information: |
