ZXCVWtest
查看: 5695|回复: 10
2006.09.28 MSI PT890 Neo-V 主板声卡不好用维修一例-->心在飞翔转移
发表于 2006-9-29 05:42:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">机种:</span><font face="Times New Roman"><state wst="on"><place wst="on"><span lang="EN-US">MS-</span></place></state><span lang="EN-US">
                                <chmetcnv wst="on" tcsc="0" numbertype="1" negative="False" hasspace="True" sourcevalue="7258" unitname="pt">7258<span style="mso-spacerun: yes;">&nbsp;&nbsp;&nbsp; </span>T</chmetcnv>890 Neo-V</span></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">故障现象:声卡(</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">)不好用,量测</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的输出端,发现对地仅为</span><span lang="EN-US"><font face="Times New Roman">004</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,判断为</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">芯片短路,于是更换</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,更换后故障依旧,而且声卡温度急速升高,表面有烧黄的痕迹,量测</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的输出端,发现电压很高,为</span><span lang="EN-US"><font face="Times New Roman">10V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右。更换</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,加电测试,发现还与原来一样,这时怀疑是前个</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">损坏,导致声卡芯片同时烧坏,而后换的</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">因为声卡芯片处于短路状态,所以</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">又损坏了,于是就同时更换了</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">和</span><span lang="EN-US"><font face="Times New Roman">ALC850</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,可是故障现象还是与原来一样,这时重新量测</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">,发现</span><span lang="EN-US"><font face="Times New Roman">1087</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的调节端(</span><span lang="EN-US"><font face="Times New Roman">ADJ</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">)的电压过高。正常的应为</span><span lang="EN-US"><font face="Times New Roman">4-5V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右,由于这个调节端的电压是用两个电阻分压的方法来进行产生的(图示如下:)</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">所以调节端的电压是与</span><span lang="EN-US"><font face="Times New Roman">R414</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">和</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">这两个电阻有关的,查阅电路图后,发现</span><span lang="EN-US"><font face="Times New Roman">R414</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">为</span><span lang="EN-US"><font face="Times New Roman">100R</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的精密电阻,</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">为</span><span lang="EN-US"><font face="Times New Roman">309R</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的精密电阻。实际量测,发现</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的阻值</span><font face="Times New Roman">
                </font><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">为</span><span lang="EN-US"><font face="Times New Roman">30KR</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右。这明显是不对的,说明这个调节电路有故障,将</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">进行更换,由于手中没有</span><span lang="EN-US"><font face="Times New Roman">309R 0402</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的精密电阻,所以更换为</span><span lang="EN-US"><font face="Times New Roman">300R</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的普通</span><span lang="EN-US"><font face="Times New Roman">0603</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">电阻,重新开机测量,由于</span><span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的阻值非设计值,所以输出电压偏高一点,为</span><span lang="EN-US"><font face="Times New Roman">5.2V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">左右。但完成可以正常使用,进入系统后,声卡正常出声,此板修复。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">相关电路:</span></p><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 宋体; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA;"><shapetype id="_x0000_t75" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" opreferrelative="t" ospt="75" coordsize="21600,21600"><stroke joinstyle="miter"></stroke><formulas><f eqn="if lineDrawn pixelLineWidth 0"></f><f eqn="sum @0 1 0"></f><f eqn="sum 0 0 @1"></f><f eqn="prod @2 1 2"></f><f eqn="prod @3 21600 pixelWidth"></f><f eqn="prod @3 21600 pixelHeight"></f><f eqn="sum @0 0 1"></f><f eqn="prod @6 1 2"></f><f eqn="prod @7 21600 pixelWidth"></f><f eqn="sum @8 21600 0"></f><f eqn="prod @7 21600 pixelHeight"></f><f eqn="sum @10 21600 0"></f></formulas><path oconnecttype="rect" gradientshapeok="t" oextrusionok="f"></path><lock aspectratio="t" vext="edit"></lock></shapetype></span><img src="attachments/dvbbs/2006-9/20069282142976990.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-9/20069282142976990.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><br/>
发表于 2006-9-29 18:18:44 | 只看该作者 �
呵呵,偶昨天也碰到了这种故障的板.
会员12 该用户已被删除
3#
发表于 2006-9-29 05:59:22 | 只看该作者 �
<p>那么原先的声卡芯片与1078都是好的吗?</p><p>主要是什么原因造成<span lang="EN-US"><font face="Times New Roman">R415</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'times new roman'; mso-hansi-font-family: 'times new roman';">的阻值</span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'times new roman'; mso-hansi-font-family: 'times new roman';">为</span><span lang="EN-US"><font face="Times New Roman">30KR</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'times new roman'; mso-hansi-font-family: 'times new roman';">左右?</span></p><p><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'times new roman'; mso-hansi-font-family: 'times new roman';">谢谢!</span></p>
发表于 2006-9-29 06:03:10 | 只看该作者 �
<p>不是好的,原来就是坏的。</p><p>至于什么原因造成的R415开路,我也不清楚。只是找到了故障原因。</p>
发表于 2006-9-29 07:19:44 | 只看该作者 �
顶了再看吧&nbsp; [em02][em02][em02]
发表于 2006-9-29 07:23:17 | 只看该作者 �
最开始的 1087 和 ALC850 都挂了 ?
发表于 2006-10-2 22:07:15 | 只看该作者 �
<p>我不记得一般都用7805提供电源!</p><p>干脆换一下是不是更稳当</p>
发表于 2006-10-3 04:18:45 | 只看该作者 �
78L05供电的只是一部分,再说了,维修要找点,而不是靠没有明确目的的换件。
发表于 2006-11-1 10:42:14 | 只看该作者 �
<p>我认为1087,由于r415变值使1087输出端基本等于输入端电压12V造成声卡被烧毁成短路状态,使1087电流加大电压下跌到10v左右,时间一长就会烧毁1087.后一个1087必然也发热严重,时间较短应该没坏.</p><p>v0=1.25*(1+r415/r414)</p>
发表于 2007-9-2 20:20:27 | 只看该作者 �
师公啊,我们要好好向你学习呀就!
发表于 2007-9-4 00:36:24 | 只看该作者 �
顺便请问下 象ALC 201 101  650这些吻合AC97规范的声卡管脚定义都一样吗     能代换吗
谢谢
