ZXCVWtest
查看: 8640|回复: 5
[显卡维修]
ATI显卡刷BIOS软件 Windows版本 atiwinflash v2.0.1.2
 关闭 [复制链接]
发表于 2008-8-20 13:35:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
ATIWinFlash - Windows Port Of ATIFlash
[2.0.1.2] - Fix Vista to work on all Motherboards
[2.0.1.1] - Fix Vista to use Primary card
[2.0.1.0] - Add Progress Bar while flashing BIOS
      - Display Marketing Name when Driver is not installed in the system.
        it can import the device ID, marketing name information on the external file "atiref.dat"
         The file will include the Asic name, device ID, marketing name and sub system device ID.
         here is the sample of the file entry:
         RV630, 0x9100, ATI Radeon x5000, 0x1234
      - It will display the final flash result on the same dialog box if there is more than 1 card,
        it will only ask user to reboot the system when all flash are done.
[2.0.0.9] - fix pa check parameters
[2.0.0.8] - Add RV770 support
[2.0.0.7] - fixed pak option to have popup error when infile is missing
      - add option (excl_memtrain_dtable) to keep memory training information while flashing new bios
      - add partial check for -pavbpn
      - fixed part number display on screen
[2.0.0.6] - update help menu
[2.0.0.5] - add quite mode for saving Rom & display error message when error during saving/flashing bios.
[2.0.0.4] - add quite mode for flashing ROM
[2.0.0.2]
  - fixed -padevid -passid -pasvid flags when used with the -pak option
[2.0.0.1]
  - fixed labelling on second cards to use correct description
  - add -quiet flag to eliminate all message boxes while flashing
[2.0]
  - fixed errors with reboot prompts when multiple products
  - fixed errors when reporting engine and memory clocks
[1.2.6.1]
  - fixed 'Error reading ROM' errors on Ry6xx products
[1.2.6]
  - added -pavbpn so you can use -pa and supply the VBIOS PN
[1.2.5]
  - resolved -pa issue with -padevid specified
  - removed old/new memory information when displayed after programming (only     applies to legacy Bios) and replaced with old/new device id
[1.2.4]
  - resolved PCI rom access for M66
[1.2.3]
  - Added support for FireGL V3350
  - -ai now displays full PCI ID information
  - asic revision now displays 'N/A' by default
[1.2.2]
  -added support for fireMV
[1.2.1]
  -resolved corrupted -ai output
[1.2.0]
  - resolved command line issues
  - removal of help button
[1.1.9]
  - resolved spaces in file path issues
  - added support for /h /?
[1.1.8]
-ported custom packaging functionality from ATIFlash:
    -pak <File>             Package an executable for BIOS update according to
                            the commands in <File>.
                            Config file example:
                               outfile = update.exe
                               banner = "Update v1.0"
                               infile = a123.bin
                               command = -pa infile
- now -h for help + improved command line handling
- cleaned up help message box
[1.1.7]
-added following functionality
    -fa             Force flashing bypassing already-programmed check.
    -fm             Force flashing bypassing BIOS memory config check.
    -fs             Force flashing bypassing BIOS SSID check.
    -fp             Force flashing bypassing BIOS P/N check.
    -pa <File>              Write BIOS image <File> to all appropriate adapters.
    -padevid=<ID>   Use with -pa command to update adapters of specific device ID.
    -passid=<ID>    Use with -pa command to update adapters of specific SSID.
    -pasvid=<ID>    Use with -pa command to update adapters of specific SVID.
[1.1.6]
  -added SiI1930 support for new architecture
[1.1.5]
  -now supports all command line options available in ATIFlash V1.26
[1.1.4]
  -Include the Support for RV550/M71
[1.1.3]
  -fix sst ROM flash issues
[1.1.2]
  -changing displayed value for New VBOIS Image Size
  -from ROM executable size to ROM file size
[1.1.1]
  -add support for 96k BIOS images
[1.1.0]
  - removing the 'force' option
[1.0.9]
  -add support for EMT 64 bit machines
[1.0.8]
  -fix display of total/free system memory on 1Gig+ machines
  -update calculation of total video memory
[1.0.7]
  -fix issue with backlight blanking on certain LVDS designs.
[1.0.6]
  -support write-protected sector on 128k serial flash ROMs
  -improved localization support
  -IA64 support
[1.0.5]
  -disable dynamic clock gating during flash
  -force gfx link to L0 during flash
  -change loading for flash library
[1.0.4]
-corrected RV200 ROM detection
-add support for RV530/RV515
-add VMSIZE flag for Dell branch
[1.0.3]
  -re-enable P/N for Dell branch
  -add support for Windows XP64
  -corrected issues found during QA
[1.0.2]
  -enable advanced page
  -complete localization
  -add SSID/SVID moidication support
[1.0.1]
  -add support for Intel HT CPU
  -add additional info on main interface(VBIOS P/N, lenght, CRC)
  -display marketing name for active videocard
  -partial localization
  -remove P/N for Dell branch
[1.0.0]
-initial release
winflash2012.zip
381.68 KB, 下载次数: 199, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2008-8-20 13:45:18 | 只看该作者 �
界面图片
这个是运行界面的图片
发表于 2008-8-26 22:03:05 | 只看该作者 �
回复 #1 走来走去 的帖子
楼主辛苦  谢谢 很好的资料
发表于 2008-9-4 13:47:24 | 只看该作者 �
不错..谢谢楼主的分享.
发表于 2008-9-9 11:49:25 | 只看该作者 �
楼主辛苦  谢谢 很好的资料
发表于 2008-12-25 23:32:56 | 只看该作者 �
x800能不能支持啊?
