ZXCVWtest
查看: 5592|回复: 12
[显卡维修]
ATI显卡刷BIOS软件 atiflash v3.60
 关闭 [复制链接]
发表于 2008-8-20 13:29:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
ATI显卡刷BIOS软件
最新版本 V3.60
ATIFLASH.EXE
[3.60]
  - Use SCLK to flash BIOS on RV730 only (SCLK will be scaled down while flashing the BIOS)
[3.59]
  - Add RV730 support
[3.58]
  - fix pa paramter, synchornize the same behaviour as ATIWinFlash
[3.57]
  - Add R700 Support
  - Reduce size
[3.56]
  - fix corrupted zip file. Same releaes as 3.55
[3.55]
  - add option (excl_memtrain_dtable) to keep memory training information while flashing new bios
  - add partial check for -pavbpn
[3.54]
  - Add "nw" in help
[3.53]
  - Add unique identifier for Ry7xx
[3.52]
  - Add RV770 device ID support
[3.51]
  - add -AMD flag to allow searching for devices with AMD vendor ID
[3.50]
  - update SPI write sequence to check for both WREN and BUSY bits to be deasserted before verifying the     write (solves issues seen with intermittent write failures)
[3.49]
  - update description for RV670 slave devices to identify uniquely on Gemini boards
[3.48]
  - correctly print Old and New P/N when flashing with newer bioses
[3.47]
  - explicitly identify RV635 ASICs
[3.46]
  - fix problems with GPIO19 asserting the CTF signal on RV670 boards
[3.45]
  - fix problems with crashes on some systems when flashing onto blank ROMs
[3.43]
  - added -pavbpn (allows the use of -pa with VBIOS PN)
  - added support for new ROM used by multimedia cards (Quito and Lima)
[3.42]
  - fix -mb command for Ry6xx
[3.41]
  - fix Ry6xx SST support
[3.40]
  - fix RV610 + Rialto hang issue
[3.39]
  - fix RV610 write issue
[3.38]
  - Add Quito support
[3.35]
  - resolved -i/-ai corruption issue
[3.34]
  - -ai now displays full PCI ID information
  - ATMEL flash procedurce redesigned for stability/reduced overall flash time
  - -ai -scansii combination will report SST/ATMEL firmware revision
[3.33]
  - internal release
[3.32]
  -add flashing over 128KB
[3.31]
  -resolved pak issues with SST/ATMEL
[3.30]
  -update device ID support for RV630/M76 & 0x000 for Ry6xx
[3.29]
  -add new option -pak to build flash package
[3.28] 11/02/06
  -add new option -fa to force flashing if the ROM is already programmed
  -add new option -fm to force flashing if legacy memory config mismatch
  -add new option -fs to force flashing if SSID mismatch
  -add new option -fp to force flashing if BIOS P/N mismatch
  -add new command -pa to search and program multiple adapters according to
   BIOS P/N
  -add new option -padevid to search for adapters of a specific PCI device
   ID when used with -pa command
  -add new option -passid to search for adapters of a specific subsystem
  -add new option -pasvid to search for adapters of a specific subsystem
   vendor ID when used with -pa command
Older revisions
[3.00]  09/08/04
  - initial release
[3.01]  09/16/04
  - adjust bus scanning sequence
[3.02]  09/30/04
  - add Rialto support
[3.03]  10/19/04
  - fix issues for Rialto
[3.04]  12/01/04
  - remove 32K limit for Rialto
[3.05]  12/09/04
  - add RN50 support
[3.06]  03/03/05
  - fix issue in flashing secondary adapters
[3.07]  03/15/05
  - fix SST support with -sst option
  - fix infinite looping on write failure
[3.08]  04/05/05
  - display BIOS P/N in -i option
[3.09]  04/29/05
  - add -mi command to modify SSID in ROM image
  - add support R530
[3.10]  09/30/05
  - support write-protected sector on 128k serial flash ROMs
  - add RIO support
[3.11]  11/11/05
  - mask out GENERICD pad output register clear to avoid setting VDDC on A520xx-20 PCB
[3.12]  11/14/05
  - add verified LIMA support
[3.13]  02/03/06
  - add new option -mb for modifying BIOS SSID, SVID, BIOS P/N and bootup message
[3.14] 02/13/06
  - add update SiImage firmware
[3.15] 02/24/06
    - add support for Warhol (RV570/M68/RV560/M67) device IDs
  - mask out GPIO[6..3] clear to avoid overwriting MVP settings on RV570/RV560
[3.16] 04/24/06
  -allow autodetect and/or pin specification for SiImage firmware updating
[3.17] 05/23/06
    -fix issues with sst ROMs
[3.18] 05/26/06
    -fix SiImage Firmware update issue
[3.19] 06/02/06
    -improve SiImage Firmware process
[3.20] 06/09/06
    -Add new options, -reboot, -pci, -pcie, -agp, -noagp, -nopcie
  -Fix SiI1930 Mobile FW Update issues
[3.21]
  -add new command -ai, advanced information
  -add new options -log, -logappend
  -reformat help menu, help menu appears with use of -h, /h, -? or /?
[3.22]
  -add display more BIOS information when flashing
  -add reboot message when flashing completed successfully
[3.23]
  -fix minor message issue
[3.24]
  -Update Lima Support
[3.25]
   -Add RV550/M71 Support
atiflash360.zip
162.21 KB, 下载次数: 264, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2008-8-20 16:35:31 | 只看该作者 �
支持,好!!!!!!!!!1
参与人数 1下载分 -10 收起 理由
天黑了吗 -10 骗分帖
发表于 2008-8-26 22:00:07 | 只看该作者 �
回复 #1 走来走去 的帖子
下载下来留用,谢谢版主
发表于 2008-9-5 15:02:41 | 只看该作者 �
下载下来留用,谢谢版主
发表于 2008-9-5 15:03:06 | 只看该作者 �
下载下来留用,谢谢版主
参与人数 1下载分 -10 收起 理由
天黑了吗 -10 重复发帖
发表于 2008-9-5 19:12:08 | 只看该作者 �
不过咯。需要这个11
参与人数 1下载分 -10 收起 理由
天黑了吗 -10 骗分帖
发表于 2008-9-8 15:37:36 | 只看该作者 �
支持.....................
参与人数 1下载分 -10 收起 理由
天黑了吗 -10 不遵守版规
发表于 2008-9-9 10:52:46 | 只看该作者 �
回复 #1 走来走去 的帖子
支持,好!!!!!!!!!1
参与人数 1下载分 -10 收起 理由
天黑了吗 -10 不遵守版规
发表于 2008-10-19 19:41:16 | 只看该作者 �
谢谢
谢谢楼主正好要用这个软件
发表于 2008-10-20 10:50:53 | 只看该作者 �
谢谢楼主正好要用这个软件
参与人数 1下载分 -10 收起 理由
天黑了吗 -10 难道就没有自己的思想吗?
发表于 2008-10-22 18:59:15 | 只看该作者 �
下载下来留用,谢谢版主
参与人数 1下载分 -10 收起 理由
天黑了吗 -10 打几个字那么困难吗?
发表于 2008-12-1 11:48:19 | 只看该作者 �
谢谢,不过不知道怎么使用,在DOS下用还是W下用
发表于 2008-12-2 00:28:47 | 只看该作者 �
下载下来备用,以免不测,呵呵,谢谢版主
