查看: 18143|回复: 9
广达SW9\TW9 主板BIOS QL4Q3F82--WIN7版(官方发布)
发表于 2011-9-6 00:30:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
SW9SW/TW9SW/QL4SW/SW9DB/SW9D/QL2D/SW9U/QL2U/TW9D/QL24D/TW9U/QL4U准系统系列笔记本bios Q3F82 WINDOWS 7版
适用部分机型:
优雅A560-i7  优雅A460-i5 | 优雅A550-i5 | 优雅A550-i3
海尔T6
提示:A560系列是Q44Q3F82,此包为自动识别的,不符合不会刷黑。
再此警告,刷机有风险,需谨慎
附件包含2M和4M BIOS
DOS下运行QL4Q3F82.bat
压缩包包含
:TW9U准系统 Q44Q3F82.fd
:TW9D准系统Q42Q3F82.fd  HASEE SLIC2.1
:SW9U准系统Q44Q3F82.fd
:SW9D准系统Q42Q3F82.fd HASEE SLIC2.1
:TW9SW准系统Q44Q3F82.fd
:SW9SW准系统Q44Q3F82.fd
QUICK SUMMARY OF FUNCTIONAL CHANGES  or Fixed  QITS  issues :
A.   System BIOS
No.        QITS No.         Comments
1        None        Modify hotkey function for third party OSD
2        None        Modify max level of the P-state for Arrandale
3        None        Modify AVC touch pad HID for TW9A
4        None        Modify AVC touch pad detect function for reducing detect times
5        None        Add 4M SPI ROM EN25F32100H2P support
6        None        Add EC checksum check function
7        None        Add internal keyboard disable function for LG OSD
8        None        Add 3G card hotkey support and WLAN, bluetooth hotkey protection
9        None        Modify brightness for smart indicator can’t slide to level 1
10        None        Disable AES for LG request
11        None        Fix QL4 sometimes hang on HDD password dialog after warm reboot
12        None        Disable WLAN ASPM for CB
13        None        Hidden model name in flashing BIOS
14        None        Modify memory dim name string in setupmenu
15        None        Enable Intel HDMI Audio device in setupmenu
16        None        Remove NVIF support for brightness in Win7
17        None        Modify TJ90 throttling temperature to 83 degree
18        None        Clear RTC_WAK flag after S5
19        None        Modify IRQ of the PEG root port to fix high definition audio device yellow bang when Clarksfield CPU mount on HM55
20        None        Modify SLP display item in setupmenu
21        None        Add Haier Dolby support
22        None        Add  EON EN25F16 EN25F40 ROM part support
23        None        Fix OSD does not show not exist when disable Bluetooth or WLAN
24        None        Fix Realtek control panel does not support SRS for LG
25        None        Remove S4 resume time reduce function
26        None        Modify PCIE port 5 hardware scan notice function
27        None        Fix Arrandale processor sighting 3622219 for flashing BIOS by Insyde Winflash
28        None        Fix Clark and HM55 S4 long run failed
29        None        Fix can’t input HDD password after warm reset
30        None        Fix S3 resume login sound lag issue by modifying sleep time from 300 ms to 1000 ms
31        None        Support EC native version OSD function for LG
32        None        Add Insyde cmos checksum solution
33        None        Add PCIE port 5 scan delay time
34        None        Fix Logo appear garbage when pushing F2 or F10
35        None        Fix can’t install OS in IDE mode
36        None        Add 2M/4M BIOS ROM identify item at address 2M 0x0018CA30 is 0x02 and 4M 0x0x0038CA30 is 0x04
37        None        Add nVIDIA WMI1 function for optimus platform
38        None        Modify BIOS code to let UMA and SG platform use the same code base
39        None        Fix the screen will show garbage on UMA platform when hot plug CRT device
40        None        Add Insyde chipset and kernel CMOS area checksum function
41        None        Lock Intel ME and add Insyde update IGNITION/FUll sku ME binary function
B .KBC BIOS
1        None        Add Fan self test routine
2        None        Disable internal keypad when disable flag is set by BIOS
3        None        Modify QL2/TW9 Fan table
4        None        Modify Fan start volage at 2.53V, and initial CPU thermal at 53'C
5        None        Modify Tj90 shutdown temperature at 95'C
6        None        Update QL2 CPU and VGA fan table
7        None        Update RF/3G hotkey behavior. ( hotkey Fn + F2 for shot time is enable/disable RF, over 1.5 second is enable/disable 3G)
8        None        Add TW9 1st step Fan speed of UMA platform
9        None        Modify Q80 threshold from 85'C to 75'C
10        None        Modify QL2 VGA fan table
11        None        Modify mute off delay time to 400ms.(HW request).
12        None        Remove TPD work around function. (KBD hang up when AVC TPD device is remove after resume.)
13        None        Sync NumLk function.
14        None        EC according WOL flag to turn on/off Lan power in AC mode, and turn off Lan power in DC mode when system is shutdown
QL4Q3F82WIN7.part1.rar (1.91 MB, 下载次数: 276)
发表于 2011-9-22 19:15:19 | 只看该作者
这个是现在最新的????
发表于 2018-1-3 13:06:18 | 只看该作者
为了这个帖子专门注册缴费。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
发表于 2019-7-21 19:08:11 | 只看该作者
这个是现在最新的????
发表于 2019-10-10 17:57:55 来自迅维网APP | 只看该作者
真的好难找啊!
发表于 2019-10-27 15:49:19 | 只看该作者
_P8B75-V 2.04
发表于 2021-1-26 14:49:31 | 只看该作者
电脑时间乱蹦,下个刷下试试,
发表于 2021-1-26 14:52:53 | 只看该作者
不知是否可以,老机子了,闲着没事弄一下
发表于 2021-1-27 17:53:43 | 只看该作者
不知是否可以,老机子了,闲着没事弄一下不知是否可以,老机子了,闲着没事弄一下
发表于 2024-5-4 20:37:05 | 只看该作者
咋找的BIOS
