查看: 2339|回复: 5
[显卡维修]
求助用r3测过X550花屏的显卡,是哪个显存导致?
发表于 2011-8-15 19:47:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 36 37 39 48 49 51 52 53 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDB0 32 33 34 35 36 37 38 39 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : PASS
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 36 37 38 39 48 49 50 51 ...
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
    failing bit : MDB0 35 36 37 38 39 48 49 50 ...
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDB0 34 35 36 37 38 39
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
TEST RESULT SUMMARY:
RV370/M22 A13 (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
    Error ID G0VB023
    Error ID G0VB024
    Error ID G0VB025
    Error ID G0VB028
    Error ID G0VC006
    Error ID G0VC009
    Error ID G0VC018
    Error ID G0VC021
    Error ID G0VC052
    Error ID G0VC057
    Error ID G0TR055
    Error ID G0TR014
    Error ID G0TR010
Failure detected.
发表于 2011-8-15 19:59:23 | 只看该作者 �
显存正面的顺序是U2            U1
                                             U8
                                              U12
反面的顺序是Su2            Su3
SU5
SU7
发表于 2011-8-15 20:01:03 | 只看该作者 �
B区从32开始报错。你这是全面检测,时间长,没必要,只要选一项检测就可以了。
发表于 2011-8-15 20:17:18 | 只看该作者 �
屏幕有些花,看不全选项。所以。。
选取哪项快些的?是SU2有问题?
发表于 2011-8-15 20:57:41 | 只看该作者 �
选7、8都快,至于是那个显存问题,要看显存脚位的排布,可以做实验来判断
发表于 2011-8-15 21:10:46 | 只看该作者 �
受十一期荣生的指点,在下用的是7选项测试,效果很不错,方便快捷
