Ñ¸Î¬Íø
²é¿´: 2744|»Ø¸´: 4
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
[ÏÔ¿¨Î¬ÐÞ]
M/N ÀØ·ç9550 CH»Æ½ð°æ 256M DDR»¨ÆÁ
[¸´ÖÆÁ´½Ó]
Ìø×ªµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2009-12-4 19:57:45 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º ¹ãÎ÷ÄÏÄþ À´×Ô ¹ãÎ÷ÄÏÄþ
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØÈ¨ÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
R3µÄ²âÊÔ½á¹ûÈçÏÂ:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 16 17 18 19 20 21 22 23 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST PASSED
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
¸ßÊÖ°ïÎÒ¿´ÊÇÄĸöоƬ³ö¹ÊÕÏ
·¢±íÓÚ 2009-12-5 22:23:56 | Ö»¿´¸Ã×÷Õß À´×Ô£º ½­ËÕËÕÖÝ À´×Ô ½­ËÕËÕÖÝ
Í·Ïñ±»ÆÁ±Î
3#
·¢±íÓÚ 2009-12-7 15:07:05 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ãÎ÷¹ó¸Û À´×Ô ¹ãÎ÷¹ó¸Û
ÎÒÒ²ÏëѧÏÔ¿¨£¬ÓÃʲôÈí¼þ²â£¿×îºÃ´øÊ¹ÓÃ˵Ã÷
4#
·¢±íÓÚ 2009-12-7 18:26:19 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÁÉÄþÉòÑô À´×Ô ÁÉÄþÉòÑô
Ïëѧ¾ÍºÃºÃѧϰ£¬¼ÈÈ»À´ÁË£¬¿Ï¶¨»áÓÐÊÕ»ñµÄ
5#
·¢±íÓÚ 2009-12-8 23:31:06 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«¹ãÖÝ À´×Ô ¹ã¶«¹ãÖÝ
ÓÖѧµ½Ò»µãÀ²¡¤¡¤¡¤¡¤¡¤¡¤¡¤¡¤              ¶à·¢µãÐÂÌû°¡£¬°æÖ÷
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ
оƬËÑË÷
¿ìËٻظ´
