ZXCVWtest
查看: 1763|回复: 4
SONY S26C 掉电
发表于 2009-11-7 14:35:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
我的一台SONY S26C 开机瞬间掉电,到0.2A的时候就马上掉下来了,待机3V 5V都正常,电池也放过电,会是哪个问题呢,SONY的真头疼,望高手解答
发表于 2009-11-7 15:13:31 | 只看该作者 �
图纸呢,修这样的机器有图快点
发表于 2009-11-7 15:55:50 | 只看该作者 �
0.2应该还在南桥做下南桥还有信号没发出去吧
发表于 2009-11-8 03:12:33 | 只看该作者 �
please change the south bridge but you have to use nh82801dbm ad not fw82801dbm as the stepping of the south bridge is different laptop will come on but not boot.this is a common problem with all vgn-s series laptop for southbridge get short due to usb.
发表于 2009-11-8 03:14:59 | 只看该作者 �
please replace southbridge as usb get short this is a common problem with entire vgn-s series.also you have to use nh82891dbm and not fw82801dbm because of intel stepping is different in both chips.
