查看: 6103|回复: 19
菜鸟的问题:如何测INTER原厂板上的基本工作条件
 关闭 [复制链接]
发表于 2006-9-6 05:58:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 浙江温州 来自 浙江温州
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Tahoma; mso-hansi-font-family: Tahoma; mso-bidi-font-family: Tahoma;">请问老师和各位高手,我有一</span><span lang="EN-US" style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: Tahoma;">INTER<chmetcnv unitname="g" sourcevalue="845" hasspace="False" negative="False" numbertype="1" tcsc="0" wst="on"></chmetcnv>845G<chmetcnv></chmetcnv></span><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Tahoma; mso-hansi-font-family: Tahoma; mso-bidi-font-family: Tahoma;">的原厂板,不走代码,开机一会儿,</span><span lang="EN-US" style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: Tahoma;">BQ边上的场管烫手</span><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Tahoma; mso-hansi-font-family: Tahoma; mso-bidi-font-family: Tahoma;">。在场管上测主供电有</span><span lang="EN-US" style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: Tahoma;">1.61V</span><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Tahoma; mso-hansi-font-family: Tahoma; mso-bidi-font-family: Tahoma;">输出,但上假负载此板不亮,小弟学艺不精,想请问老师和高手们,如何在上</span><span lang="EN-US" style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: Tahoma;">CPU</span><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Tahoma; mso-hansi-font-family: Tahoma; mso-bidi-font-family: Tahoma;">的情况下测他的基本工作条件?因为</span><span lang="EN-US" style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: Tahoma;">BGA</span><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: Tahoma; mso-hansi-font-family: Tahoma; mso-bidi-font-family: Tahoma;">的座,背面没有针脚。</span></p>
[此贴子已经被作者于2006-9-6 16:31:39编辑过]
发表于 2006-9-6 05:59:42 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>贴个全图吧</p><img src="attachments/dvbbs/2006-9/2006952202517948.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-9/2006952202517948.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><br/>
[此贴子已经被作者于2006-9-5 22:00:28编辑过]
会员12 该用户已被删除
3#
发表于 2006-9-6 06:12:17 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
<p><span lang="EN-US" style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: tahoma;">INTER<chmetcnv unitname="g" sourcevalue="845" hasspace="False" negative="False" numbertype="1" tcsc="0" wst="on"></chmetcnv>845G<chmetcnv></chmetcnv></span><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: tahoma; mso-hansi-font-family: tahoma; mso-bidi-font-family: tahoma;">的原厂板,不上CPU是不加电;</span></p><p><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: tahoma; mso-hansi-font-family: tahoma; mso-bidi-font-family: tahoma;"></span></p><p><span style="FONT-SIZE: 9pt; COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: tahoma; mso-hansi-font-family: tahoma; mso-bidi-font-family: tahoma;">请问:你上CPU后,上电主板复位没有?</span></p>
发表于 2006-9-6 06:17:35 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>测试卡不走代码,我用的是那种金叶的烂卡,上电后就一5V的灯亮,其他都没有。弱弱的问版主一下,还有什么办法测有没有复位啊?</p>[em04]
会员12 该用户已被删除
5#
发表于 2006-9-6 06:19:55 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
<p>测试,IDE第一脚,在短接RESET的同时,第一脚电平有没有电平跳变?</p>
发表于 2006-9-6 06:24:32 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>谢谢,我马上就测</p>
发表于 2006-9-6 06:33:50 | 只看该作者 来自: 浙江温州 来自 浙江温州
没有复位.
[此贴子已经被作者于2006-9-6 9:05:38编辑过]
发表于 2006-9-6 17:27:17 | 只看该作者 来自: 浙江温州 来自 浙江温州
<img src="attachments/dvbbs/2006-9/2006969195774956.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-9/2006969195774956.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><br/>上图红圈中的场管18N06开机一会儿烫得厉害,它输出1.45V。这管子可以用什么型号的代换?
发表于 2006-9-8 18:03:38 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>加电后南北桥不是很烫,是正常的温度,这是不是还不一定是桥坏,是吗孙老师?现在一加电就是那只18N06L的管烫得不行,吹下来测过,坏了。手上没有这种型号的,上了个45N03L的,不行。</p>
发表于 2006-9-6 20:37:37 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>红圈内的管子就是给南北桥提供1.5V电压的,它不是一般的烫,是换它,还是别的地方有短路?</p>
发表于 2006-9-7 03:17:48 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>&nbsp;<img src="attachments/dvbbs/2006-9/20069619172455717.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-9/20069619172455717.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><br/></p><p>上图红色圈中的贴片电容的阻值为22,兰色圈中的贴片电容的阻值为0,这会不会是北桥的问题啊?</p>
会员12 该用户已被删除
12#
发表于 2006-9-7 06:51:45 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
<p>你用60N03L换,试试.看有没有复位.</p><p></p><p>关注中.!</p>
发表于 2006-9-7 07:34:38 | 只看该作者 来自: 广西南宁 来自 广西南宁
75N03L可以代换
发表于 2006-9-7 08:44:34 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>好的,谢谢两位,换完了再回复!</p>
发表于 2006-9-7 18:27:26 | 只看该作者 来自: 广西南宁 来自 广西南宁
<p>蓝色圈中电容两端数值为0</p><p>那么你可以打下这个输出发烫的管子的对地数值,如果为0的话,就是桥挂了</p><p>北桥 或者 南桥 </p>
发表于 2006-9-7 18:40:38 | 只看该作者 来自: 浙江温州 来自 浙江温州
<p>孙老师,发烫管输出脚的对地阻值为0.加电测有1.5V输出,在兰色圈中的贴片电容上也能测到1.5V电压。</p>
会员12 该用户已被删除
17#
发表于 2006-9-8 04:44:10 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
<p>桥挂了,别修了.</p>
发表于 2006-9-8 05:24:32 | 只看该作者 来自: 浙江温州 来自 浙江温州
受益匪浅,谢谢各位的帮助!
发表于 2006-9-8 10:39:22 | 只看该作者 来自: 广西南宁 来自 广西南宁
加电后,北桥或者南桥会发烫的,桥挂了
会员12 该用户已被删除
20#
发表于 2006-9-9 16:09:29 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
<p>45N03L的电压够了,但电流不够.换个同型试试. </p><p>据现象:桥坏的可能性不大.</p>
