- 积分
- 330
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2007-10-13
- 精华
以下是Intel对PWROK信号描述的原文,供大家参考:
PWROK Signal
The PWROK input should go active based on the core supply voltages becoming valid.
PWROK should go active no sooner than 100 ms after Vcc3_3 and Vcc1_5 have reached their nominal values.
Note:
1. SYSRESET# is recommended for implementing the system reset button. This saves
external logic that is needed if the PWROK input is used. Additionally, it allows for
better handling of the SMBus and processor resets, and avoids improperly reporting power failures.
2. If the PWROK input is used to implement the system reset button, the ICH7 does
not provide any mechanism to limit the amount of time that the processor is held in
reset. The platform must externally ensure that maximum reset assertion specifications are met.
3. If a design has an active-low reset button electrically AND’d with the PWROK signal from the power supply and the processor’s voltage regulator module the ICH7 PWROK_FLR bit will be set. The ICH7 treats this internally as if the RSMRST# signal had gone active. However, it is not treated as a full power failure. If PWROK goes inactive and then active (but RSMRST# stays high), then the ICH7 reboots
(regardless of the state of the AFTERG3 bit). If the RSMRST# signal also goes low
before PWROK goes high, then this is a full power failure, and the reboot policy is
controlled by the AFTERG3 bit.
4. PWROK and RSMRST# are sampled using the RTC clock. Therefore, low times that are less than one RTC clock period may not be detected by the ICH7.
5. In the case of true PWROK failure, PWROK goes low first before the VRMPWRGD. |
