查看: 1644|回复: 0
[索尼(SONY)]
您可以查看索尼液晶电视电源这样。
发表于 2016-3-10 23:04:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 亚太地区 来自 亚太地区
You can view this Sony LCD TV power.
1: Disconnect the LED board or motherboard and plug the inverter.
2: a jump from one foot to do STBY3.3 V to pin 3 POWER_ON (1K resistor is the best,
3: Connect the 12-volt watt or 10-watt light bulb glow lamp 35 AUTO then, and may be fined.
If the light flashes, then you need to replace the main part of the capacitance
And replace all MOSFET
