查看: 3870|回复: 2
这样卡在SPT全读了,硬盘能用多久?
发表于 2015-6-14 19:08:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东 来自 广东
2015/6/12 9:06:28 Power On Reset Immediate - SUCCESS by
2015/6/12 9:23:59 C4 - 磁头读写参数/飞檐高度调整 - SUCCESS by
2015/6/12 9:23:59 C3 - 调整磁道密度 - Start
2015/6/12 10:29:47 C3 - 调整磁道密度 - SUCCESS by
2015/6/12 10:29:47 C8 - 调整扇区密度 - Start
2015/6/12 10:48:18 C8 - 调整扇区密度 - SUCCESS by
2015/6/12 10:48:18 C4 - 磁头读写参数/飞檐高度调整 - Start
2015/6/12 11:23:36 C4 - 磁头读写参数/飞檐高度调整 - SUCCESS by
2015/6/12 11:23:36 B1 - 快速扫描/测试用户区 - Start
2015/6/12 11:29:00 B1 - 快速扫描/测试用户区 - SUCCESS by
2015/6/12 11:29:00 1008 -  - Start
2015/6/12 11:35:42 1008 -  - SUCCESS by
2015/6/12 11:35:42 C4 - 磁头读写参数/飞檐高度调整 - Start
2015/6/12 11:48:31 C4 - 磁头读写参数/飞檐高度调整 - SUCCESS by
2015/6/12 11:48:31 D1 - 扫描缺陷(写)并加入LOG - Start
2015/6/12 13:53:26 D1 - 扫描缺陷(写)并加入LOG - SUCCESS by
2015/6/12 13:53:26 DD - 增益校准 - Start
2015/6/12 13:54:28 DD - 增益校准 - SUCCESS by
2015/6/12 13:54:28 DB - 扫描缺陷(读)并加入LOG - Start
2015/6/12 18:47:51 DB - 扫描缺陷(读)并加入LOG - SUCCESS by
2015/6/12 18:47:51 D5 - 测试簇 - Start
2015/6/12 18:56:58 D5 - 测试簇 - SUCCESS by
2015/6/12 18:56:58 D4 - 测试磁道缺陷 - Start
2015/6/12 19:23:32 D4 - 测试磁道缺陷 - SUCCESS by
2015/6/12 19:23:32 3300 -  - Start
2015/6/12 19:26:23 3300 -  - SUCCESS by
2015/6/12 19:26:23 3301 -  - Start
2015/6/12 19:28:11 3301 -  - SUCCESS by
2015/6/12 19:28:11 C4 - 磁头读写参数/飞檐高度调整 - Start
2015/6/12 19:28:48 C4 - 磁头读写参数/飞檐高度调整 - SUCCESS by
2015/6/12 19:28:48 B9 - 低级格式化 - Start
2015/6/12 20:58:20 B9 - 低级格式化 - NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG
2015/6/12 20:58:20 3402 -  - Start
2015/6/12 20:59:20 3402 -  - SUCCESS by
2015/6/12 20:59:20 D7 - PE扫描测试 - Start
2015/6/12 21:01:45 D7 - PE扫描测试 - SUCCESS by
2015/6/12 21:01:45 3402 -  - Start
2015/6/12 21:02:46 3402 -  - SUCCESS by
2015/6/12 21:02:46 BA - SPT全读 - Start
2015/6/12 22:58:44 Disable PST Mode - OK
2015/6/12 22:59:03 Disable PST Mode - OK
2015/6/12 22:59:12 Disable PST Mode - OK
2015/6/12 22:59:25 Disable PST Mode - OK
2015/6/12 22:59:38 Power On Reset Immediate - SUCCESS by
2015/6/13 9:04:23 All Steps: 45, Current: 23
2015/6/13 9:04:50 Clear IBI Abort Code - SUCCESS by
2015/6/13 9:04:50 Set SelfScan Step to 24 - OK
2015/6/13 9:04:51 Enable PST Mode - OK
2015/6/13 9:05:01 Power On Reset Immediate - SUCCESS by
2015/6/13 9:05:36 BC - STP Depop - SUCCESS by
2015/6/13 9:05:36 3501 -  - Start
2015/6/13 13:12:43 3501 -  - SUCCESS by
2015/6/13 13:12:43 B9 - 低级格式化 - Start
2015/6/13 13:15:16 B9 - 低级格式化 - NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG
2015/6/13 13:15:16 BA - SPT全读 - Start
2015/6/13 13:22:07 BA - SPT全读 - SUCCESS by
2015/6/13 13:22:07 3302 -  - Start
2015/6/13 13:23:31 3302 -  - SUCCESS by
2015/6/13 13:23:31 2900 -  - Start
2015/6/13 13:23:32 2900 -  - SUCCESS by
2015/6/13 13:23:32 DC - 结束校准 - Start
2015/6/13 14:09:10 Power On Reset Immediate - FFFF=NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG  - NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG - NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG - -
2015/6/13 14:09:13 Power On Reset Immediate - FFFF=NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG  - NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG - NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG - -
2015/6/13 14:09:13 Disable PST Mode - SUCCESS by
2015/6/13 14:09:37 Disable PST Mode - OK
2015/6/13 14:09:43 Disable PST Mode - OK
2015/6/13 14:09:54 Power On Reset Immediate - SUCCESS by
2015/6/13 14:10:02 Clear IBI Abort Code - SUCCESS by
Soft Error Counter - has been cleared
Soft Error Total Counter - has been cleared
2015/6/13 14:10:07 Clear IBI Soft Error Counter - SUCCESS by
发表于 2015-6-14 21:39:29 | 只看该作者 来自: 中国 来自 中国
没有数据就扔掉。
出盘了呀,为什么要扔掉?,全盘扫描一个坏点也没有,绿点只有一个78MS  详情 回复 发表于 2015-6-14 21:41
发表于 2015-6-14 21:41:12 | 只看该作者 来自: 广东 来自 广东
xsp1980 发表于 2015-6-14 21:39
没有数据就扔掉。
