查看: 7032|回复: 12
求华硕代工的HP主板主板制造商: 华硕 P4SD-LA HP 名称: Yale-UL6E 的BIOS
发表于 2008-9-4 13:14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
http://h10025.www1.hp.com/ewfrf/ ... mpid=reg_R1002_CNZH
发表于 2008-9-4 14:20:59 | 只看该作者 �
Title: BIOS update for P4SD-LA motherboard
Version: 3.25 - 04/27/2004
Description:
Update to BIOS 3.25 for the P4SD-LA motherboard.
Purpose: Critical Update
Category: BIOS
Operating System:
Windows XP Home
Windows XP Professional
Windows XP Media Center Edition
Language(s):
Global English
Fixes:
- Resolves intermittent hang when attempting to resume from standby mode.
- Resolves a system delay when switching the CPU fan speed.
Prerequisites:
N/A
How To Use:
1.  Download the BIOS update.
2.  Double-click the BIOS update icon and then click NEXT.
3.  Accept the license terms and then click NEXT.
4.  If an Overwrite Protection message appears, click YES TO ALL.
5.  Click OK at the Windows Based BIOS Update window.
6.  Click YES at the next Windows Based BIOS Update window and then wait for update to complete.
7.  At the Windows Based BIOS Update window, click YES to restart your PC.
8.  If you see the following message during the restart of your PC, continue with the remaining steps; otherwise you are done with the update.
0251: System CMOS checksum bad - Default configuration used
9.   Press and hold F1 for a few seconds to open the BIOS Setup.
10. Press F5 for a few seconds, choose YES, and then press Enter to load the BIOS defaults. (Use the arrow keys to choose YES, if necessary.)
11. Press F10 for a few seconds, choose YES, and then press Enter to exit the BIOS Setup and save your changes. (Use the arrow keys to choose YES, if necessary.)
12. Press Enter to confirm the save.
13. If you see a System Settings Change message prompting you to restart your PC, click YES to restart the PC again.
Copyright © 2004 Hewlett-Packard Development Company, L.P.
325.rar
390.5 KB, 下载次数: 32, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2008-9-4 21:49:14 | 只看该作者 �
"天黑了吗"的兄弟~!你说那个好像不行啊~!我刷过了~1
发表于 2008-9-4 21:58:54 | 只看该作者 �
同样称4SD-LA的主板在HP中有多款~!都称P4SD-LA 但主板是不一样的~!我的主板也称4SD-LA 但 HP 称:Yale-UL6E  也就是:HP Pavilion j3 台式电脑系列  J318CN \J316CN\J312CN 所用的主板~!谁有它们的BIOS~!求救~!!求救~!!求救~!!求救~!!
发表于 2008-9-6 11:46:41 | 只看该作者 �
谁有~!P4SD-LA就是 HP Pavilion j3 台式电脑系列  J318CN \J316CN\J312CN 所用的主板的     BIOS  ~!!!急救中~!!!!急救中~!!!!急救中~!!!!急救中~!!!!
发表于 2008-9-6 21:29:23 | 只看该作者 �
J318CN 的BIOS
328.rar
404.51 KB, 下载次数: 34, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2008-9-8 16:03:16 | 只看该作者 �
谢谢~!流浪的船长兄弟~!我刷看看行吗?
发表于 2008-11-22 11:19:45 | 只看该作者 �
我的主板是HP M8LA9Q ,跑00,不知上面有没有我的BIOS
发表于 2008-11-22 11:31:25 | 只看该作者 �
好不容易下载了一个325.rar,怎么解压失败
发表于 2008-11-22 14:06:07 | 只看该作者 �
发表于 2008-11-22 14:10:00 | 只看该作者 �
如果你刷了你上的BIOS还不行,最好把原BIOS刷回来,然后把1394芯片拆下来,应该可以解决,些板很容易烧此芯片。在南桥左边
发表于 2008-12-21 21:09:01 | 只看该作者 �
怎么样下啊?
发表于 2008-12-23 22:09:15 | 只看该作者 �
刷不了呀..不对.
