查看: 2445|回复: 5
[显卡维修]
艾尔莎 620TC MATS测试报告 会看的指点下
发表于 2011-9-4 17:47:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
显卡开始小花。 拆下检测 发现显存供电的两个电容 有点鼓~换了后 (进PE是不花了 还没进系统试)运行 mats 6 检测结果如下:
师父们帮我看下  现在还有问题吗?  要是有问题出在哪?
Tested from 0 MB to 128 MB.
    LANE     E_BANK0 ERRORS
FBA[31: 0]           35264
FBA[63:32]           35264
External Bank 0 Failing bits:
   A00 A01 A02 A03 A04 A05 A06 A07 A08 A09 A10 A11 A12 A13 A14 A15
   A16 A17 A18 A19 A20 A21 A22 A23 A24 A25 A26 A27 A28 A29 A30 A31
   A32 A33 A34 A35 A36 A37 A38 A39 A40 A41 A42 A43 A44 A45 A46 A47
   A48 A49 A50 A51 A52 A53 A54 A55 A56 A57 A58 A59 A60 A61 A62 A63
Read    Error Count: 0
Write   Error Count: 70528
Unknown Error Count: 0
ADDRESS  EXPECTED  ACTUAL  REREAD1  REREAD2  REREAD3  TYPE  P L E I ROW  COL BO
0001a8dc 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 2 000c 11b 3
0001a8d8 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 2 000c 11a 2
0001a8d4 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 2 000c 119 1
0001a8d0 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 2 000c 118 0
0001a8cc 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 2 000c 11b 3
0001a8c8 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 2 000c 11a 2
0001a8c4 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 2 000c 119 1
0001a8c0 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 2 000c 118 0
0000991c 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 1 0004 123 3
00009918 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 1 0004 122 2
00009914 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 1 0004 121 1
00009910 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 1 0004 120 0
0000990c 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 1 0004 123 3
00009908 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 1 0004 122 2
00009904 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 1 0004 121 1
00009900 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 1 0004 120 0
00008b5c 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 0 0004 16b 3
00008b58 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 0 0004 16a 2
00008b54 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 0 0004 169 1
00008b50 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 0 0004 168 0
00008b4c 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 0 0004 16b 3
00008b48 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 0 0004 16a 2
00008b44 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 0 0004 169 1
00008b40 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 0 0 0 0004 168 0
00000b5c 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 0 0000 16b 3
00000b58 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 0 0000 16a 2
00000b54 00000000 ffffffff ffffffff ffffffff ffffffff WRITE A 1 0 0 0000 169 1
发表于 2011-9-4 20:30:31 | 只看该作者 �
楼主真是的,直接进系统,跑下3Dmax不就完了嘛。
Write   Error Count: 70528 这句话的字面意思是     写错误数量 70528.有这么多错误?
请问一下,测试软件哪里有下啊,谢谢
显卡维修书本里 有带了测试程序~ 还有 bios  详情 回复 发表于 2011-9-4 21:15
发表于 2011-9-4 21:15:32 | 只看该作者 �
进系统测试主要是手上没有能用的 sata 硬盘~ 有的都是IDE的  但主板没有IDE接口 。所以没进系统测试~
发表于 2011-9-4 22:25:35 | 只看该作者 �
A区全报错了  做GPU吧
发表于 2011-9-4 22:30:18 | 只看该作者 �
你这个一看就多半是刀版的卡,只有A区的4颗显存。620TC是个什么型号?是6200TC吧,要不怎么用MATS6.看起来是4颗全错首先测显存的供电再测显存的参考电压。下次发帖要写清型号和显存的型号
发表于 2011-9-5 06:39:11 | 只看该作者 �
有坏区会报错坏区  全好的卡会报错一整片 你进系统跑下3D不就得了
