查看: 3057|回复: 3
显卡15针图数据表
发表于 2010-2-6 00:10:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 埃及 来自 埃及
VGA=Video Graphics Adapter or Video Graphics Array.
Videotype: Analogique.
VGA (31.5 KHz - 640x480)
SVGA (35-37 KHz - 800x600)
15 PIN HIGHDENSITY D-SUB FEMALE Prise 15 broches D-SUB HIGHDENSITY femelle de la carte video.
15 PIN HIGHDENSITY D-SUB MALE Prise 15 broches D-SUB HIGHDENSITY male du cable de l'écran.
Pin         Name         Dir         Description
1         RED         OUT         Red Video (75 ohm, 0.7 V p-p)
2         GREEN         OUT         Green Video (75 ohm, 0.7 V p-p)
3         BLUE         OUT         Blue Video (75 ohm, 0.7 V p-p)
4         ID2         IN         Monitor ID Bit 2
5         GND         ------         Ground
6         RGND         ------         Red Ground
7         GGND         ------         Green Ground
8         BGND         ------         Blue Ground
9         KEY         -         Key (No pin)
10         SGND         ------         Sync Ground
11         ID0         IN         Monitor ID Bit 0
GND=Color; NC=Mono
12         ID1 or SDA         IN         Monitor ID Bit 1
NC=Color; GND=Mono
Some systems only uses ID0 for monitor ID
13         HSYNC or CSYNC         OUT         Horizontal Sync (or Composite Sync)
14         VSYNC         OUT         Vertical Sync
15         ID3 or SCL         IN         Monitor ID Bit 3
Note: Direction is Computer relative Monitor.
发表于 2010-2-6 01:19:06 | 只看该作者 来自: 广东深圳 来自 广东深圳
整个中文的还行,E文瞧着累
发表于 2010-2-7 15:24:13 | 只看该作者 来自: 内蒙古包头 来自 内蒙古包头
发表于 2010-3-14 15:03:29 | 只看该作者 来自: 广东 来自 广东
hello,LZ,can you send the  VGA interface circuit drawing  to me. Please e-mail to "pentiumxia@126.com". The   VGA interface circuit drawing above is not so clear,.
