查看: 19|回复: 0
航嘉电源跳闸损坏,无待机电压
发表于 昨天 22:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
故障电源为客户主机拆下的航嘉电源,客户反馈故障起因是跳闸。万用表初测:紫线、绿线都没有待机电压;拆开外壳目视检查,板上无明显炸机、烧毁痕迹。
逐项检测后锁定损坏元件:保险丝、开关管、331 1KV 陶瓷电容。维修代换方案:开关管网购同型号更换;331 1KV 陶瓷电容使用 471K 1KV 陶瓷电容代换。
元件更换完成后上电,待机电压恢复正常;短接绿线、黑线强制开机,测量 3.3V、5V、12V、-12V 各路输出电压全部正常,带负载测试稳定,故障修复,维修完成。
weibo.com/ttarticle/p/show?id=2309405359473786487142
weibo.com/ttarticle/p/show?id=2309405359473748476457
weibo.com/ttarticle/p/show?comment=1&id=2309405359473748476457
weibo.com/ttarticle/p/show?id=2309405359473823973882
weibo.com/ttarticle/p/show?comment=1&id=2309405359473786487142
weibo.com/ttarticle/p/show?comment=1&id=2309405359473823973882
weibo.com/ttarticle/p/show?id=2309405359473861984344
weibo.com/ttarticle/p/show?id=2309405359473899471075
weibo.com/ttarticle/p/show?comment=1&id=2309405359473861984344
weibo.com/ttarticle/p/show?comment=1&id=2309405359473899471075
weibo.com/ttarticle/p/show?comment=1&id=2309405359473937481841
weibo.com/ttarticle/p/show?id=2309405359473937481841
weibo.com/ttarticle/p/show?id=2309405359473974968444
weibo.com/ttarticle/p/show?id=2309405359474008785146
weibo.com/ttarticle/p/show?comment=1&id=2309405359473974968444
weibo.com/ttarticle/p/show?id=2309405359474046533805
weibo.com/ttarticle/p/show?comment=1&id=2309405359474008785146
weibo.com/ttarticle/p/show?comment=1&id=2309405359474046533805
weibo.com/ttarticle/p/show?comment=1&id=2309405359474084282598
weibo.com/ttarticle/p/show?id=2309405359474084282598
weibo.com/ttarticle/p/show?comment=1&id=2309405359474159518101
weibo.com/ttarticle/p/show?id=2309405359474159518101
weibo.com/ttarticle/p/show?id=2309405359474197528786
weibo.com/ttarticle/p/show?id=2309405359474235277491
weibo.com/ttarticle/p/show?comment=1&id=2309405359474235277491
weibo.com/ttarticle/p/show?comment=1&id=2309405359474197528786
weibo.com/ttarticle/p/show?id=2309405359474272763991
weibo.com/ttarticle/p/show?comment=1&id=2309405359474272763991
weibo.com/ttarticle/p/show?id=2309405359474310774871
weibo.com/ttarticle/p/show?comment=1&id=2309405359474310774871
weibo.com/ttarticle/p/show?id=2309405359474348523557
weibo.com/ttarticle/p/show?comment=1&id=2309405359474348523557
weibo.com/ttarticle/p/show?id=2309405359474382078233
weibo.com/ttarticle/p/show?comment=1&id=2309405359474382078233
weibo.com/ttarticle/p/show?id=2309405359474419564861
weibo.com/ttarticle/p/show?comment=1&id=2309405359474419564861
weibo.com/ttarticle/p/show?id=2309405359474490868306
weibo.com/ttarticle/p/show?id=2309405359474457575576
weibo.com/ttarticle/p/show?comment=1&id=2309405359474457575576
weibo.com/ttarticle/p/show?comment=1&id=2309405359474490868306
weibo.com/ttarticle/p/show?comment=1&id=2309405359474528878955
weibo.com/ttarticle/p/show?id=2309405359474528878955
weibo.com/ttarticle/p/show?id=2309405359474566627576
weibo.com/ttarticle/p/show?comment=1&id=2309405359474566627576
weibo.com/ttarticle/p/show?id=2309405359474683806041
weibo.com/ttarticle/p/show?comment=1&id=2309405359474683806041
weibo.com/ttarticle/p/show?comment=1&id=2309405359474721554532
weibo.com/ttarticle/p/show?id=2309405359474721554532
weibo.com/ttarticle/p/show?id=2309405359474759565379
weibo.com/ttarticle/p/show?id=2309405359474797051924
weibo.com/ttarticle/p/show?comment=1&id=2309405359474759565379
weibo.com/ttarticle/p/show?comment=1&id=2309405359474797051924
weibo.com/ttarticle/p/show?comment=1&id=2309405359474830868844
weibo.com/ttarticle/p/show?id=2309405359474830868844
weibo.com/ttarticle/p/show?id=2309405359483307557044
weibo.com/ttarticle/p/show?comment=1&id=2309405359483307557044
weibo.com/ttarticle/p/show?id=2309405359483349237908
weibo.com/ttarticle/p/show?id=2309405359483391180867
weibo.com/ttarticle/p/show?comment=1&id=2309405359483349237908
weibo.com/ttarticle/p/show?comment=1&id=2309405359483391180867
weibo.com/ttarticle/p/show?id=2309405359483429192085
weibo.com/ttarticle/p/show?comment=1&id=2309405359483429192085
weibo.com/ttarticle/p/show?id=2309405359483475329420
weibo.com/ttarticle/p/show?id=2309405359483517009938
weibo.com/ttarticle/p/show?comment=1&id=2309405359483475329420
weibo.com/ttarticle/p/show?comment=1&id=2309405359483517009938
weibo.com/ttarticle/p/show?id=2309405359483554758930
weibo.com/ttarticle/p/show?comment=1&id=2309405359483554758930
weibo.com/ttarticle/p/show?id=2309405359483592507705
weibo.com/ttarticle/p/show?comment=1&id=2309405359483592507705
weibo.com/ttarticle/p/show?id=2309405359483634451021
weibo.com/ttarticle/p/show?comment=1&id=2309405359483634451021
weibo.com/ttarticle/p/show?id=2309405359483676655785
weibo.com/ttarticle/p/show?comment=1&id=2309405359483676655785
weibo.com/ttarticle/p/show?id=2309405359483718598745
weibo.com/ttarticle/p/show?id=2309405359483756085900
weibo.com/ttarticle/p/show?comment=1&id=2309405359483718598745
weibo.com/ttarticle/p/show?comment=1&id=2309405359483756085900
weibo.com/ttarticle/p/show?id=2309405359483798028701
weibo.com/ttarticle/p/show?comment=1&id=2309405359483798028701
weibo.com/ttarticle/p/show?id=2309405359483836039545
weibo.com/ttarticle/p/show?id=2309405359483873526192
weibo.com/ttarticle/p/show?comment=1&id=2309405359483836039545
weibo.com/ttarticle/p/show?comment=1&id=2309405359483873526192
weibo.com/ttarticle/p/show?id=2309405359483915468867
weibo.com/ttarticle/p/show?comment=1&id=2309405359483915468867
weibo.com/ttarticle/p/show?id=2309405359483953217917
weibo.com/ttarticle/p/show?comment=1&id=2309405359483953217917
weibo.com/ttarticle/p/show?id=2309405359483995423176
weibo.com/ttarticle/p/show?comment=1&id=2309405359483995423176
weibo.com/ttarticle/p/show?id=2309405359484037104081
weibo.com/ttarticle/p/show?comment=1&id=2309405359484037104081
weibo.com/ttarticle/p/show?id=2309405359484087697479
weibo.com/ttarticle/p/show?comment=1&id=2309405359484087697479
weibo.com/ttarticle/p/show?id=2309405359484125184380
weibo.com/ttarticle/p/show?comment=1&id=2309405359484125184380
weibo.com/ttarticle/p/show?id=2309405359484171583490
weibo.com/ttarticle/p/show?comment=1&id=2309405359484171583490
weibo.com/ttarticle/p/show?id=2309405359484209070620
weibo.com/ttarticle/p/show?comment=1&id=2309405359484209070620
weibo.com/ttarticle/p/show?id=2309405359484251275488
weibo.com/ttarticle/p/show?comment=1&id=2309405359484251275488
weibo.com/ttarticle/p/show?comment=1&id=2309405359484292956804
weibo.com/ttarticle/p/show?id=2309405359484292956804
weibo.com/ttarticle/p/show?id=2309405359484334899621
weibo.com/ttarticle/p/show?comment=1&id=2309405359484334899621
weibo.com/ttarticle/p/show?id=2309405359484376842430
weibo.com/ttarticle/p/show?comment=1&id=2309405359484376842430
weibo.com/ttarticle/p/show?comment=1&id=2309405359484414853576
weibo.com/ttarticle/p/show?id=2309405359484414853576
weibo.com/ttarticle/p/show?id=2309405359486906007732
weibo.com/ttarticle/p/show?comment=1&id=2309405359486906007732
weibo.com/ttarticle/p/show?id=2309405359486943756547
weibo.com/ttarticle/p/show?comment=1&id=2309405359486943756547
weibo.com/ttarticle/p/show?id=2309405359486977573359
weibo.com/ttarticle/p/show?comment=1&id=2309405359486977573359
weibo.com/ttarticle/p/show?id=2309405359487015321990
weibo.com/ttarticle/p/show?comment=1&id=2309405359487015321990
weibo.com/ttarticle/p/show?id=2309405359487053070655
weibo.com/ttarticle/p/show?comment=1&id=2309405359487053070655
weibo.com/ttarticle/p/show?id=2309405359487090556969
weibo.com/ttarticle/p/show?comment=1&id=2309405359487090556969
weibo.com/ttarticle/p/show?id=2309405359487128305680
weibo.com/ttarticle/p/show?comment=1&id=2309405359487128305680
weibo.com/ttarticle/p/show?id=2309405359487161860367
weibo.com/ttarticle/p/show?comment=1&id=2309405359487161860367
weibo.com/ttarticle/p/show?id=2309405359487199871149
weibo.com/ttarticle/p/show?comment=1&id=2309405359487199871149
weibo.com/ttarticle/p/show?id=2309405359487237357746
weibo.com/ttarticle/p/show?comment=1&id=2309405359487237357746
weibo.com/ttarticle/p/show?id=2309405359487275106326
weibo.com/ttarticle/p/show?comment=1&id=2309405359487275106326
weibo.com/ttarticle/p/show?id=2309405359487308661015
weibo.com/ttarticle/p/show?comment=1&id=2309405359487308661015
weibo.com/ttarticle/p/show?id=2309405359487346671853
weibo.com/ttarticle/p/show?comment=1&id=2309405359487346671853
weibo.com/ttarticle/p/show?id=2309405359487384158275
weibo.com/ttarticle/p/show?comment=1&id=2309405359487384158275
weibo.com/ttarticle/p/show?comment=1&id=2309405359487421907012
weibo.com/ttarticle/p/show?id=2309405359487421907012
weibo.com/ttarticle/p/show?id=2309405359487459655769
weibo.com/ttarticle/p/show?comment=1&id=2309405359487459655769
weibo.com/ttarticle/p/show?id=2309405359487497666616
weibo.com/ttarticle/p/show?comment=1&id=2309405359487497666616
weibo.com/ttarticle/p/show?id=2309405359487535415306
weibo.com/ttarticle/p/show?comment=1&id=2309405359487535415306
weibo.com/ttarticle/p/show?id=2309405359487572901946
weibo.com/ttarticle/p/show?comment=1&id=2309405359487572901946
weibo.com/ttarticle/p/show?id=2309405359487610913174
weibo.com/ttarticle/p/show?comment=1&id=2309405359487610913174
weibo.com/ttarticle/p/show?id=2309405359487648661617
weibo.com/ttarticle/p/show?comment=1&id=2309405359487648661617
weibo.com/ttarticle/p/show?id=2309405359487686148170
weibo.com/ttarticle/p/show?comment=1&id=2309405359487686148170
weibo.com/ttarticle/p/show?id=2309405359487724158986
weibo.com/ttarticle/p/show?comment=1&id=2309405359487724158986
weibo.com/ttarticle/p/show?id=2309405359487757451545
weibo.com/ttarticle/p/show?comment=1&id=2309405359487757451545
weibo.com/ttarticle/p/show?id=2309405359487795200315
weibo.com/ttarticle/p/show?comment=1&id=2309405359487795200315
weibo.com/ttarticle/p/show?id=2309405359487837143166
weibo.com/ttarticle/p/show?comment=1&id=2309405359487837143166
weibo.com/ttarticle/p/show?id=2309405359487875154665
weibo.com/ttarticle/p/show?comment=1&id=2309405359487875154665
weibo.com/ttarticle/p/show?id=2309405359487917097528
weibo.com/ttarticle/p/show?comment=1&id=2309405359487917097528
weibo.com/ttarticle/p/show?id=2309405359487954846230
weibo.com/ttarticle/p/show?comment=1&id=2309405359487954846230
weibo.com/ttarticle/p/show?id=2309405359488256573602
weibo.com/ttarticle/p/show?id=2309405359488634323315
weibo.com/ttarticle/p/show?comment=1&id=2309405359488634323315
weibo.com/ttarticle/p/show?id=2309405359488672072254
weibo.com/ttarticle/p/show?comment=1&id=2309405359488672072254
weibo.com/ttarticle/p/show?id=2309405359488709820855
weibo.com/ttarticle/p/show?comment=1&id=2309405359488709820855
weibo.com/ttarticle/p/show?id=2309405359488747569534
weibo.com/ttarticle/p/show?comment=1&id=2309405359488747569534
weibo.com/ttarticle/p/show?id=2309405359488785055997
weibo.com/ttarticle/p/show?comment=1&id=2309405359488785055997
weibo.com/ttarticle/p/show?id=2309405359488822804793
weibo.com/ttarticle/p/show?comment=1&id=2309405359488860815818
weibo.com/ttarticle/p/show?id=2309405359488860815818
weibo.com/ttarticle/p/show?comment=1&id=2309405359488822804793
weibo.com/ttarticle/p/show?id=2309405359488902496462
weibo.com/ttarticle/p/show?id=2309405359488940245316
weibo.com/ttarticle/p/show?comment=1&id=2309405359488902496462
weibo.com/ttarticle/p/show?comment=1&id=2309405359488940245316
weibo.com/ttarticle/p/show?comment=1&id=2309405359488977993983
weibo.com/ttarticle/p/show?id=2309405359488977993983
weibo.com/ttarticle/p/show?comment=1&id=2309405359489015742562
weibo.com/ttarticle/p/show?id=2309405359489015742562
weibo.com/ttarticle/p/show?id=2309405359489053491382
weibo.com/ttarticle/p/show?comment=1&id=2309405359489053491382
weibo.com/ttarticle/p/show?id=2309405359489091502148
weibo.com/ttarticle/p/show?comment=1&id=2309405359489091502148
weibo.com/ttarticle/p/show?id=2309405359489124794522
weibo.com/ttarticle/p/show?comment=1&id=2309405359489124794522
weibo.com/ttarticle/p/show?id=2309405359489166737694
weibo.com/ttarticle/p/show?comment=1&id=2309405359489166737694
weibo.com/ttarticle/p/show?id=2309405359489204748322
weibo.com/ttarticle/p/show?comment=1&id=2309405359489204748322
weibo.com/ttarticle/p/show?comment=1&id=2309405359489242497050
weibo.com/ttarticle/p/show?id=2309405359489242497050
weibo.com/ttarticle/p/show?id=2309405359489275789816
weibo.com/ttarticle/p/show?comment=1&id=2309405359489275789816
weibo.com/ttarticle/p/show?id=2309405359489313538425
weibo.com/ttarticle/p/show?comment=1&id=2309405359489313538425
weibo.com/ttarticle/p/show?id=2309405359489351287190
weibo.com/ttarticle/p/show?comment=1&id=2309405359489351287190
weibo.com/ttarticle/p/show?id=2309405359489389035771
weibo.com/ttarticle/p/show?comment=1&id=2309405359489389035771
weibo.com/ttarticle/p/show?id=2309405359489427046476
weibo.com/ttarticle/p/show?comment=1&id=2309405359489427046476
weibo.com/ttarticle/p/show?id=2309405359489464533178
weibo.com/ttarticle/p/show?comment=1&id=2309405359489464533178
weibo.com/ttarticle/p/show?id=2309405359489502281796
weibo.com/ttarticle/p/show?comment=1&id=2309405359489502281796
