查看: 797|回复: 1
mats测试结果高手分析一下
发表于 2022-8-2 21:14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
mats version 400.184.  Testing GK104 with 20 MB of memory starting with 0 MB.
Read    Error Count: 0
Write   Error Count: 33
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0            0            0            0
FBIOA1            0           32            0
FBIOB0            0            1            0
FBIOB1            0            0            0
FBIOC0            0            0            0
FBIOC1            0            0            0
FBIOD0            0            0            0
FBIOD1            0            0            0
Failing Bits:
   A032 A033 A034 A035 A036 A037 A038 A039 A040 A041 A042 A043 A044 A045 A046 A047
B002 B003 B007 B011 B012 B013 B014 B015
=== MEMORY ERRORS BY BIT ===
P : Partition (FBIO)
                                            READ 0 READ 1 READ ?
P BIT READ ERRORS WRITE ERRORS UNKNOWN ERRS EXP. 1 EXP. 0 EXP. ?
A 032           0           16            0      4     12      0
A 033           0           16            0      4     12      0
A 034           0           14            0      4     10      0
A 035           0           14            0      6      8      0
A 036           0           11            0      3      8      0
A 037           0           16            0      1     15      0
A 038           0           22            0      2     20      0
A 039           0            8            0      8      0      0
A 040           0           24            0      0     24      0
A 041           0           24            0      0     24      0
A 042           0           24            0      0     24      0
A 043           0            8            0      8      0      0
A 044           0            8            0      8      0      0
A 045           0            8            0      8      0      0
A 046           0            8            0      8      0      0
A 047           0            8            0      8      0      0
B 002           0            1            0      1      0      0
B 003           0            1            0      1      0      0
B 007           0            1            0      1      0      0
B 011           0            1            0      1      0      0
B 012           0            1            0      1      0      0
B 013           0            1            0      1      0      0
B 014           0            1            0      1      0      0
B 015           0            1            0      1      0      0
=== MEMORY ERRORS BY ADDRESS ===
ADDRESS : Failing memory address, or buffer offset if starting with 'X+'
T : Type of memory error: W = write, R = read
S : Subpartition
B : Bank
E : Beat
   ADDRESS EXPECTED   ACTUAL  REREAD1  REREAD2 FAILBITS TPSBE  ROW COL                                                      BIT(s)
00000032f8 00000000 00000773 00000773 00000773 00000773 WA146 0000 003                     A032,A033,A036,A037,A038,A040,A041,A042
00000032f0 00000000 00000765 00000765 00000765 00000765 WA144 0000 003                          A032,A034,A037,A038,A040,A041,A042
00000032e8 00000000 00000763 00000763 00000763 00000763 WA142 0000 003                          A032,A033,A037,A038,A040,A041,A042
00000032e0 00000000 0000076f 0000076f 0000076f 0000076f WA140 0000 003                A032,A033,A034,A035,A037,A038,A040,A041,A042
00000032d8 00000000 00000772 00000772 00000772 00000772 WA146 0000 002                          A033,A036,A037,A038,A040,A041,A042
00000032d0 00000000 00000770 00000770 00000770 00000770 WA144 0000 002                               A036,A037,A038,A040,A041,A042
00000032c8 00000000 00000720 00000720 00000720 00000720 WA142 0000 002                                         A037,A040,A041,A042
00000032c0 00000000 00000768 00000768 00000768 00000768 WA140 0000 002                               A035,A037,A038,A040,A041,A042
0000003278 00000000 00000754 00000754 00000754 00000754 WA146 0000 013                               A034,A036,A038,A040,A041,A042
0000003270 00000000 00000752 00000752 00000752 00000752 WA144 0000 013                               A033,A036,A038,A040,A041,A042
0000003268 00000000 0000074c 0000074c 0000074c 0000074c WA142 0000 013                               A034,A035,A038,A040,A041,A042
0000003260 00000000 00000745 00000745 00000745 00000745 WA140 0000 013                               A032,A034,A038,A040,A041,A042
0000003258 00000000 00000744 00000744 00000744 00000744 WA146 0000 012                                    A034,A038,A040,A041,A042
0000003250 00000000 00000743 00000743 00000743 00000743 WA144 0000 012                               A032,A033,A038,A040,A041,A042
0000003248 00000000 0000074f 0000074f 0000074f 0000074f WA142 0000 012                     A032,A033,A034,A035,A038,A040,A041,A042
0000003240 00000000 00000749 00000749 00000749 00000749 WA140 0000 012                               A032,A035,A038,A040,A041,A042
00000032b8 00000000 00000763 00000763 00000763 00000763 WA146 0000 001                          A032,A033,A037,A038,A040,A041,A042
00000032b0 00000000 00000775 00000775 00000775 00000775 WA144 0000 001                     A032,A034,A036,A037,A038,A040,A041,A042
00000032a8 00000000 00000773 00000773 00000773 00000773 WA142 0000 001                     A032,A033,A036,A037,A038,A040,A041,A042
00000032a0 00000000 00000720 00000720 00000720 00000720 WA140 0000 001                                         A037,A040,A041,A042
0000003298 00000000 0000076f 0000076f 0000076f 0000076f WA146 0000 000                A032,A033,A034,A035,A037,A038,A040,A041,A042
0000003290 00000000 0000074e 0000074e 0000074e 0000074e WA144 0000 000                          A033,A034,A035,A038,A040,A041,A042
0000003288 00000000 00000720 00000720 00000720 00000720 WA142 0000 000                                         A037,A040,A041,A042
0000003280 00000000 0000073a 0000073a 0000073a 0000073a WA140 0000 000                          A033,A035,A036,A037,A040,A041,A042
0000003300 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WB040 0000 010                     B002,B003,B007,B011,B012,B013,B014,B015
0000003200 ffffffff ffff0772 ffff0772 ffff0772 0000f88d WA140 0000 010                A032,A034,A035,A039,A043,A044,A045,A046,A047
0000003208 ffffffff ffff076f ffff076f ffff076f 0000f890 WA142 0000 010                          A036,A039,A043,A044,A045,A046,A047
0000003210 ffffffff ffff0775 ffff0775 ffff0775 0000f88a WA144 0000 010                     A033,A035,A039,A043,A044,A045,A046,A047
0000003218 ffffffff ffff0774 ffff0774 ffff0774 0000f88b WA146 0000 010                A032,A033,A035,A039,A043,A044,A045,A046,A047
0000003220 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WA140 0000 011                A033,A035,A036,A039,A043,A044,A045,A046,A047
0000003228 ffffffff ffff073a ffff073a ffff073a 0000f8c5 WA142 0000 011                A032,A034,A038,A039,A043,A044,A045,A046,A047
0000003230 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WA144 0000 011 A032,A033,A034,A035,A036,A038,A039,A043,A044,A045,A046,A047
0000003238 ffffffff ffff0753 ffff0753 ffff0753 0000f8ac WA146 0000 011                A034,A035,A037,A039,A043,A044,A045,A046,A047
If you are getting failure for first MB of FB then try option -no_scan_out
Error Code = 00000001
请高手指导一下是哪的问题
发表于 2022-8-2 23:09:26 | 只看该作者 �
错误 A1 B0
