查看: 6566|回复: 12
[笔记本电脑]
超级简单全自动合成me方法,秒合
头像被屏蔽
发表于 2020-6-27 08:16:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
超级简单全自动合成me方法,秒合
使用图形操作是不是很繁琐?其实用一条命令就能瞬间搞定。
DOS窗口合成过程大概如下:
Intel (R) Flash Image Tool. Version: 11.8.65.3606
Copyright (c) 2013 - 2019, Intel Corporation. All rights reserved.
6/26/2020 - 7:57:43 涓嬪崍
Using vsccommn.bin with timestamp 20:10:49 05/01/2019 GMT
Command Line: fit -f orig.bin -o good.bin -me me.bin -b
Log file written to fit.log
Decomposed SKU Value: "Intel (R) H Series Chipset - H No Emulation".
Decomposed PCH Strap Length: 0x58
Warning: The ME FW image loaded has been pulled from a previously booted system. Some FW settings will not be allowed to be changed.
Writing map file D:\temp\Intel CSME System Tools v11 r32\Flash Image Tool\WIN32\orig\orig.map
Executing pre-build actions
Building objects
Processing attribute: BuildSettings
Processing attribute: FlashLayout
Committing CSE configuration.
Building image with Chipset Initialization version: 176.11
Processing attribute: FlashSettings
Processing attribute: IntelMeKernel
Processing attribute: IntelAmt
Processing attribute: PlatformProtection
Processing attribute: IntegratedTouch
Processing attribute: Icc
Processing attribute: NetworkingConnectivity
Processing attribute: FlexIo
Processing attribute: InternalPchBuses
Processing attribute: Gpio
Processing attribute: Power
Processing attribute: IntegratedSensorHub
Processing attribute: Debug
Processing attribute: CpuStraps
Executing post-build actions
Full Flash image written to D:\temp\Intel CSME System Tools v11 r32\Flash Image Tool\WIN32\good.bin
Writing map file D:\temp\Intel CSME System Tools v11 r32\Flash Image Tool\WIN32\good.map
下面给出命令:
fit -f input.bin -o output.bin -me mefile.bin –b
意思就是:
fit -f 原机备份BIOS.bin -o 改好ME的BIOS.bin -me ME文件.bin –b
fit:请使用mea程序分析原机ME版本,然后找到正确的fit版本程序
input.bin: 请使用烧录器读取原机BIOS
output.bin: 本次合成的BIOS,请使用烧录器烧录回原机
mefile.bin: 请使用mea程序分析原机ME版本,然后去ME库中找到对应干净ME,这个我就不教你了。
所有路径/文件名不能有中文或特殊字符,请保持干净、简短。
参与人数 2下载分 +8 +5 收起 理由
天意wx + 3 给愿意分享经验的人加分!
兄弟电脑电器 + 5 + 5 做一个教程发上来
头像被屏蔽
发表于 2020-6-27 09:22:17 | 只看该作者 �
看来 海的来个录像
参与人数 1下载分 +4 收起 理由
天意wx + 4 期待录像
回复 支持 0 反对 1
发表于 2020-6-27 09:21:19 | 只看该作者 �
看不懂
发表于 2020-6-27 09:39:38 来自迅维网APP | 只看该作者 �
akcn 发表于 2020-06-27 09:22
看来 海的来个录像
一年前做了脚本,现在还是手动,因为bug无法跳过,只能手动改,比如技嘉
发表于 2021-11-20 21:59:50 来自迅维网APP | 只看该作者 �
希望你能做个教程,今天改了一个11代的,也合成了,查看me里面已经初始化了,怎么改都是已初始化
发表于 2021-11-21 09:37:13 | 只看该作者 �
我一般是HEX直接编辑
发表于 2021-11-21 10:32:06 | 只看该作者 �
学习学习。。。。。。。。。。。。。
发表于 2021-11-21 10:50:38 | 只看该作者 �
感谢分享,学习了。。。
发表于 2021-12-3 15:39:00 | 只看该作者 �
不会弄 能不能稍微 说明白一点
发表于 2021-12-3 16:44:54 | 只看该作者 �
这个是脚本吗
发表于 2021-12-3 23:22:31 | 只看该作者 �
看到这么多英文有点晕,还是图形界面简单
发表于 2021-12-4 17:54:20 | 只看该作者 �
1有点蒙 英文
发表于 2021-12-5 22:14:41 | 只看该作者 �
英文倒是都能看懂,就是不懂编程,至少我孟看懂这些操作是在弄啥,
