查看: 4962|回复: 4
[维修求助]
iphone x 日志分析
发表于 2020-5-25 16:28:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
求助高手看一下是什么问题谢谢,
  "panicString" : "panic(cpu 0 caller 0xfffffff0183ac2a8): userspace watchdog timeout: no successful checkins from com.apple.backboardd in 180 seconds\nservice: com.apple.backboardd, total successful checkins since load (180 seconds ago): 1, last successful checkin: 180 seconds ago\nservice: com.apple.mediaserverd, total successful checkins since load (180 seconds ago): 1, last successful checkin: 180 seconds ago\nservice: com.apple.logd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: com.apple.thermalmonitord, total successful checkins since load (180 seconds ago): 15, last successful checkin: 0 seconds ago\nservice: com.apple.runningboardd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\n\nDebugger message: panic\nMemory ID: 0x6\nOS version: 17C54\nKernel version: Darwin Kernel Version 19.2.0: Mon Nov  4 17:47:00 PST 2019; root:xnu-6153.60.66~39\/RELEASE_ARM64_T8015\nKernel UUID: 3346FA02-7FF2-37D9-8D39-331FBEAEF7FB\niBoot version: iBoot-5540.60.11\nsecure boot?: YES\nPaniclog version: 13\nKernel slide:     0x000000000f83c000\nKernel text base: 0xfffffff016840000\nmach_absolute_time: 0x10f44bb7e\nEpoch Time:        sec       usec\n  Boot    : 0x5ec77a64 0x000efd0c\n  Sleep   : 0x00000000 0x00000000\n  Wake    : 0x00000000 0x00000000\n  Calendar: 0x5ec77b1a 0x000dc564\n\nTotal cpu_usage: 48061758\nThread task pri cpu_usage\n0xffffffe000d96488 watchdogd 97 0\n0xffffffe0044d2ef8 runningboardd 37 0\n0xffffffe0044d2488 runningboardd 37 0\n0xffffffe002faa488 watchdogd 31 0\n0xffffffe000c0a488 kernel_task 0 0\n\nPanicked task 0xffffffe002107000: 155 pages, 3 threads: pid 52: watchdogd\nPanicked thread: 0xffffffe000d96488, backtrace: 0xffffffe04e4d30e0, tid: 1025\n\t\t  lr: 0xfffffff0173fe824  fp: 0xffffffe04e4d3120\n\t\t  lr: 0xfffffff0173fe684  fp: 0xffffffe04e4d3190\n\t\t  lr: 0xfffffff0175137f0  fp: 0xffffffe04e4d3240\n\t\t  lr: 0xfffffff0179f9610  fp: 0xffffffe04e4d3250\n\t\t  lr: 0xfffffff0173fe000  fp: 0xffffffe04e4d35c0\n\t\t  lr: 0xfffffff0173fe348  fp: 0xffffffe04e4d3610\n\t\t  lr: 0xfffffff018876a4c  fp: 0xffffffe04e4d3630\n\t\t  lr: 0xfffffff0183ac2a8  fp: 0xffffffe04e4d3650\n\t\t  lr: 0xfffffff0183abfd4  fp: 0xffffffe04e4d3670\n\t\t  lr: 0xfffffff017991154  fp: 0xffffffe04e4d36d0\n\t\t  lr: 0xfffffff017999e94  fp: 0xffffffe04e4d3860\n\t\t  lr: 0xfffffff0174e419c  fp: 0xffffffe04e4d3980\n\t\t  lr: 0xfffffff017403d0c  fp: 0xffffffe04e4d39e0\n\t\t  lr: 0xfffffff0173db5dc  fp: 0xffffffe04e4d3a60\n\t\t  lr: 0xfffffff0173f2638  fp: 0xffffffe04e4d3b10\n\t\t  lr: 0xfffffff01750a2d8  fp: 0xffffffe04e4d3bd0\n\t\t  lr: 0xfffffff017513918  fp: 0xffffffe04e4d3c80\n\t\t  lr: 0xfffffff0179f9610  fp: 0xffffffe04e4d3c90\n\t\t  lr: 0x00000001a75c8634  fp: 0x0000000000000000\n\n"}
发表于 2020-5-25 21:00:52 | 只看该作者 �
电池尾插震动逐一排查
发表于 2020-5-26 01:30:48 来自迅维网APP | 只看该作者 �
电池  检测角 弄过两台X
发表于 2020-5-26 08:50:42 来自迅维网APP | 只看该作者 �
这个怎么看呀?你们怎么那么厉害呀?
发表于 2020-5-26 14:49:21 来自迅维网APP | 只看该作者 �
在设置数据分析内有祥细的
