查看: 1635|回复: 2
[拆机体验]
Iphone 6s/7 disassemble and reassemble complete teardown for repairing
发表于 2017-9-19 09:26:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
hi guys today i am going to guide youabout iPhone 7,in which i would like to show you about all accessories and howto remove and refit them
iphone 7 and 7 plus are same to disassemble
THE MAIN WIEW
STEP 1:
in this step you can see that you must remove two 3.4 mm screws with a finescrew driver same like iPhone 6 or 6s on the bottom edge of iPhone 7
STEP 2
before you use suction cup to remove the display please use hot air for 10seconds carefully to not demenge display then carefully use suction cup and aplastic stick to remove display
STEP 3
now lift up the display slowly not more than 10 grade because there are ribboncables on the right edge
STEP 4
pull up the display from left side to upwards like to opne a book carefullyotherwise you can damage front camera and touch cables are still connected inthe right side of motherboard
STEP 5
now remove all screws which are highlighted and there are tow types ofscrews 2.4 mm and other are 1.2 mm,be careful to not exchangethe screws
STEP 6
now remove also other two screws size 1.3 mm andbecareful to not exchange these to other screws to avoid to damage screw holesand motherboard
STEP 7
now remove the display assembly carefully
STEP 8
now here remove the 1.9 mm screws and put them carefully separatefrom other screws
STEP 9
remove 1.6 mm screws to remove TAPTIC ENGINE
over i have told all about to remove display you must be careful to remove all the parts and refit them and i recommend to all friends to never exchange the screws
I have tried my best to make this thread and hope that it will be helpful to all hardware friends
if you like the thread only press thanks button
参与人数 2下载分 +1 +11 收起 理由
新照不轩 + 10 英文拆机贴~~6 的都没谁了.....
名不好起 + 1 + 1 老司机!双击666+关注.....
发表于 2017-9-19 09:43:24 | 只看该作者 �
楼主不会说中文吗
发表于 2017-9-19 10:30:32 | 只看该作者 �
中文翻译下,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
