- 积分
- 592
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-7-12
- 精华
发表于 2008-9-4 14:20:59
只看该作者
来自: 江苏镇江 来自 江苏镇江
Title: BIOS update for P4SD-LA motherboard
Version: 3.25 - 04/27/2004
Description:
Update to BIOS 3.25 for the P4SD-LA motherboard.
Purpose: Critical Update
Category: BIOS
Operating System:
Windows XP Home
Windows XP Professional
Windows XP Media Center Edition
Language(s):
Global English
Fixes:
- Resolves intermittent hang when attempting to resume from standby mode.
- Resolves a system delay when switching the CPU fan speed.
Prerequisites:
N/A
How To Use:
1. Download the BIOS update.
2. Double-click the BIOS update icon and then click NEXT.
3. Accept the license terms and then click NEXT.
4. If an Overwrite Protection message appears, click YES TO ALL.
5. Click OK at the Windows Based BIOS Update window.
6. Click YES at the next Windows Based BIOS Update window and then wait for update to complete.
7. At the Windows Based BIOS Update window, click YES to restart your PC.
8. If you see the following message during the restart of your PC, continue with the remaining steps; otherwise you are done with the update.
0251: System CMOS checksum bad - Default configuration used
9. Press and hold F1 for a few seconds to open the BIOS Setup.
10. Press F5 for a few seconds, choose YES, and then press Enter to load the BIOS defaults. (Use the arrow keys to choose YES, if necessary.)
11. Press F10 for a few seconds, choose YES, and then press Enter to exit the BIOS Setup and save your changes. (Use the arrow keys to choose YES, if necessary.)
12. Press Enter to confirm the save.
13. If you see a System Settings Change message prompting you to restart your PC, click YES to restart the PC again.
Copyright © 2004 Hewlett-Packard Development Company, L.P. |
325.rar
390.5 KB, 下载次数: 32, 下载积分: 下载分 -2 分, 下载 1 次
