查看: 1821|回复: 4
解放WIN7,关闭自动排列
发表于 2016-1-28 20:57:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河南信阳 来自 河南信阳
解放WIN7 关闭自动排列
    很多人习惯自定义文件夹或文件档案的排列顺序,XP系统是没问题的,但是到了WIN7.....却常被它的自动化给搞的不知如何是好,所以呢这里就是要教大家如何关闭WIN7的自动排列功能。
方法很简单,就是看图说明,复制运行代码..然后稍作一下设定,就可以搞定了
复制以下代码,另存为  关闭自动排列.bat
  • @echo off
  • :: Created by: Shawn Brink
  • :: http://www.sevenforums.com
  • :: Tutorial:  http://www.sevenforums.com/tutor ... rrange-disable.html
  • :: To reset all folders to default folder views
  • Reg Delete "HKCU\Software\Microsoft\Windows\Shell\BagMRU" /F
  • Reg Delete "HKCU\Software\Microsoft\Windows\Shell\Bags" /F
  • Reg Delete "HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags" /F
  • Reg Delete "HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU" /F
  • Reg Delete "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU" /F
  • Reg Delete "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags" /F
  • Reg Delete "HKCU\Software\Classes\Wow6432Node\Local Settings\Software\Microsoft\Windows\Shell\Bags" /F
  • Reg Delete "HKCU\Software\Classes\Wow6432Node\Local Settings\Software\Microsoft\Windows\Shell\BagMRU" /F
  • :: To kill and restart explorer
  • taskkill /f /im explorer.exe
  • start explorer.exe
  • CLS
  • echo.
  • echo.
  • echo Please wait for explorer to restart. No need to do anything.
  • echo.
  • TIMEOUT 10
  • :: To open the Computer window
  • explorer.exe shell:MyComputerFolder
  • :: Disable Auto Arrange for CompressedFolder (zipped) folder
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{80213e82-bcfd-4c4f-8817-bb27601267a9}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{80213e82-bcfd-4c4f-8817-bb27601267a9}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{80213e82-bcfd-4c4f-8817-bb27601267a9}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Contacts folder template
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{de2b70ec-9bf7-4a93-bd3d-243f7881d492}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{de2b70ec-9bf7-4a93-bd3d-243f7881d492}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{de2b70ec-9bf7-4a93-bd3d-243f7881d492}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Documents folder template
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{7D49D726-3C21-4F05-99AA-FDC2C9474656}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{7D49D726-3C21-4F05-99AA-FDC2C9474656}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{7D49D726-3C21-4F05-99AA-FDC2C9474656}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Games Explorer folder
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{b689b0d0-76d3-4cbb-87f7-585d0e0ce070}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{b689b0d0-76d3-4cbb-87f7-585d0e0ce070}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{b689b0d0-76d3-4cbb-87f7-585d0e0ce070}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for General Items folder template
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{5C4F28B5-F869-4E84-8E60-F11DB97C5CC7}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{5C4F28B5-F869-4E84-8E60-F11DB97C5CC7}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{5C4F28B5-F869-4E84-8E60-F11DB97C5CC7}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Libraries folder
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{C4D98F09-6124-4fe0-9942-826416082DA9}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{C4D98F09-6124-4fe0-9942-826416082DA9}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{C4D98F09-6124-4fe0-9942-826416082DA9}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Music folder template
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{94D6DDCC-4A68-4175-A374-BD584A510B78}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{94D6DDCC-4A68-4175-A374-BD584A510B78}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{94D6DDCC-4A68-4175-A374-BD584A510B78}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Pictures folder template
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{B3690E58-E961-423B-B687-386EBFD83239}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{B3690E58-E961-423B-B687-386EBFD83239}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{B3690E58-E961-423B-B687-386EBFD83239}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Printers folder
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{2c7bbec6-c844-4a0a-91fa-cef6f59cfda1}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{2c7bbec6-c844-4a0a-91fa-cef6f59cfda1}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{2c7bbec6-c844-4a0a-91fa-cef6f59cfda1}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Searches folder
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{0b0ba2e3-405f-415e-a6ee-cad625207853}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{0b0ba2e3-405f-415e-a6ee-cad625207853}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{0b0ba2e3-405f-415e-a6ee-cad625207853}" /V Mode /T REG_DWORD /D 4 /F
  • :: Disable Auto Arrange for Videos folder template
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{5FA96407-7E77-483C-AC93-691D05850DE8}" /V FFLAGS /T REG_dWORD /D 1124073476 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{5FA96407-7E77-483C-AC93-691D05850DE8}" /V LogicalViewMode /T REG_dWORD /D 1 /F
  • REG ADD "HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell\{5FA96407-7E77-483C-AC93-691D05850DE8}" /V Mode /T REG_DWORD /D 4 /F
直接执行 关闭自动排列.bat ,屏幕上会出现Dos窗口画面在跑,
跑完之后自动关闭窗口也会自动重新启动
explorer,接下来就可以在自由的拖曳排列档案。
关闭自动排列后..再稍做一下设置,就可以开始享受如XP一样自在的自定义文件与档案的排列顺序了!!
当然..如果想恢复原本WIN7的自动排列,可以另外复制下面的代码,另存 恢复自动排列.bat
  • @echo off
文章转载ittk论坛
参与人数 1下载分 +2 收起 理由
whxwhx119 + 2
发表于 2016-1-29 09:19:01 | 只看该作者 来自: 河南安阳 来自 河南安阳
很实用,满足了一些客户的需求。
是的,感谢支持  详情 回复 发表于 2016-1-29 11:55
发表于 2016-1-29 11:55:34 | 只看该作者 来自: 河南信阳 来自 河南信阳
whxwhx119 发表于 2016-1-29 09:19
很实用,满足了一些客户的需求。
是的,感谢支持
发表于 2016-1-29 12:04:52 | 只看该作者 来自: 广东东莞 来自 广东东莞
楼主牛,学习了
文章是转载的  详情 回复 发表于 2016-1-29 12:07
发表于 2016-1-29 12:07:08 | 只看该作者 来自: 河南信阳 来自 河南信阳
jmdna 发表于 2016-1-29 12:04
楼主牛,学习了
文章是转载的
