set UMAROM=JE40D111.wph
set UMAWFEXE=JE40D111.EXE
set UMAWF64EXE=JE40D111.EXE
cls
if (%PROCESSOR_ARCHITECTURE%)==(x86) goto WindowsMode
if (%PROCESSOR_ARCHITECTURE%)==(AMD64) goto OSx64
OSMode
cd DOS
echo *** JE40_DN/HM42_DN BIOS Flash Utility ***
REM ***************************************************************
REM *** Just modify the above part ********************************
echo Notice:
echo 1. This procedure may replace your BIOS!
echo If you don't want to do it, press Ctrl-C to cancel.
echo 2. Make sure you plug in the AC adapter before flashing BIOS.
echo If not, DO NOT flash!
echo 3. This utility will check if the battery capacity is over 30%.
echo If not, it will stop to flash the BIOS.
pause
