查看: 7680|回复: 19
[求助中]
希捷ST2000DL003 CC3C 错误代码分析
发表于 2017-3-30 23:52:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Boot 0x40M
Spin Up[0x000246DF]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
RECOVERED Op=0900 Resp=0005
(P) SATA Reset
  MediaPartition:
                        Host LBA  Length    Disc LBA  Length   Start Cyl  Head
       Media Partition  00000000  0099A9C0  00000000  00133538  00000000  00000000
               MC       00000000  0098A148  00000000  00131429  00000000  00000000
               MSP      00991F38  00000C98  001323E7  00000193  000001D0  00000005
        User Partition  0099A9C0            00133538            000001C5  00000005
MCMainPOR: Start:
Check MCMT Version: Current
MCInitialize: Start:  Buffer Words VBM: 00000210
ClearMC: Start Full  Media Cache size in host blks 00989680..........
ClearMC:  Completed, Last LBA 00989680
MC Area is re-initialized.
MCInitialize:  MC Cleared
MCInitialize:  MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize:  MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize:  MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS]
MC Seg Disc and Cache Nodes:  40134924  40132A34
Seg Write Preamble VBM start: 000011B2 end: 000011D9
  Footer - start: 000011DB end: 00001202
Seg Read Preamble VBM - start: 00001204 end: 0000122B
  Footer - start: 0000122D end: 00001254
MCInitialize: Init complete:
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 00000022
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
MSP MainPOR:
MSP Init Metadata
     Buf Bytes/VBM 00000210  DBA Base 40000000
     Metadata size in bytes 0040
     Num Segments 0064
     Logical Sector Alignment 00000000
MSP Reconstruction
MSP Read ScratchPad Section 0000  DiscLBA 001323E7  BlkSize 00000C80  Num Segments 00000064  DiscLba 001323E7
     No valid segments found
MSP MSP Main Store Verify  Reconstruction Status 10003000
     Reconstruction Status 00003000
MSP Init ScratchPad on DiscDiscLBA 001323E7  DiscSize 00000190  PhyBlkLBA 00991F38  BlkSize 00000C80
     Write MSP Segment   PhyBlkLBA 00991F38  BlkSize 00000C80  DiscLba 001323E7  RW_RTL FFFFFFFF
MSP MainPOR: Complete
MSP MainPOR: Feature Enabled...
     ScratchPad restore NOT required
发表于 2017-3-30 23:53:26 | 只看该作者 �
F3 T>/TJ  CAP:    (P1=00) Validation Key: 00000020   (P1=01) HDA Serial Number: 5YD70KFY   (P1=02) PCBA Serial Number: 0000M2143M7B   (P1=03) PCBA Part Number: Invalid   (P1=04) Head Count: 06   (P1=05) Node Name Validation Key: 01   (P1=06) Node Name: 50 00 C5 00 44 C8 D1 B7    (P1=07) Product Family ID: 4F   (P1=08) Product Family ID: 02   (P1=09) PCBA Build Code: Invalid   (P1=0A) ASIC Info:             FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF 00    (P1=0B) Firmware Key: FF FF FF FF FF FF FF FF FF FF FF FF FF FF    (P1=0C) Firmware Key Checksum: FFFF   (P1=0D) Date of Manufacture: 11072011   (P1=0E) Destroked Buf Size Index: 03   (P1=0F) Final Mfg Op: Invalid   (P1=10) Final Mfg Erc: Undefined   (P1=11) System Area Prep State: FE   (P1=12) SPT Auto Run Delay: 00   (P1=13) Reserved: 00   (P1=14) Checksum: FFFF   (P1=15) External Model Number: ST2000DL003-9VT166                         (P1=16) Internal Model Number: ST2000DL003-9VT166                         (P1=17) IDEMA Capacity: E8E088B0   (P1=18) Reserved1:             FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF              FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
发表于 2017-3-30 23:54:08 | 只看该作者 �
二楼是硬盘信息
发表于 2017-3-31 00:06:01 | 只看该作者 �
很想帮你,实在无能为力
发表于 2017-3-31 07:43:18 | 只看该作者 �
实在是看不懂。楼主你这个是用什么软件分析到的吗?
发表于 2017-3-31 20:46:14 | 只看该作者 �
发表于 2017-3-31 20:52:15 | 只看该作者 �
F3 T>/TJ
CAP:
  (P1=01) HDA Serial Number: 5YD728W0
  (P1=02) PCBA Serial Number: 0000K201CYNT
  (P1=06) Node Name: 50 00 C5 00 44 C3 1C 4E
  (P1=0A) ASIC Info:
  (P1=0D) Date of Manufacture: 11082011
  (P1=18) Reserved1:
F3 T>/1N8
                                              DERP
  dec                                         error  DERP
Hours -     LBA       R  Theta Z EC       Cmd type  retry temp count  type
     0 -  1D20CAA3     9 358D  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CB62     9 4539  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CC21     9 54E5  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CCE0     9 6492  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CD9F     9 7397  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CE5E     9 8343  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CF1D     9 92F0  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CFDC     9 A29C  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D09B     9 B249  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D15A     9 C1F5  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D219     9 D1A1  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D2D8     9 E14E  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D397     9 F053  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D456     9    0  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D515     9  FAC  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D5D4     9 1F58  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D693     9 2F05  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D752     9 3EB1  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D811     9 4E5E  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D8D0     9 5E0A  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20D98F     9 6D0F  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20C9E4     9 25E0  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DF87     9 E9CB  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E046     9 F978  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E105     9  924  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E1C6     9 18D0  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E283     9 287D  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E342     9 3829  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E401     9 47D6  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E4C0     9 5782  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E57F     9 6687  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E63E     9 7634  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E6FD     9 85E0  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20E7BC     9 958D  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20C925     9 1634  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DA4E     9 7CBC  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DB0D     9 8C68  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DBCC     9 9C14  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DC8B     9 ABC1  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DD4A     9 BB6D  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DE09     9 CB1A  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DEC8     9 DAC6  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20DF87     9 E9CB  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E046     9 F978  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E105     9  924  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E1C4     9 18D0  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E284     9 287D  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E342     9 3829  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E401     9 47D6  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E4C0     9 5782  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E57F     9 6687  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E63E     9 7634  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E6FD     9 85E0  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E7BC     9 958D  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CB63     9 4539  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20E283     9 287D  0 43110081   0  FF     FF   10     1  BGMS dos rewrite
     0 -  1D20CAA6     9 358D  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CB6A     9 45E0  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CC21     9 54E5  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CCE0     9 6492  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CD9F     9 7397  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CE5E     9 8343  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CF1D     9 92F0  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CFDC     9 A29C  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D09B     9 B249  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D15A     9 C1F5  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D21D     9 D1A1  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D2D8     9 E14E  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D397     9 F053  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D456     9    0  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D515     9  FAC  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D5D4     9 1F58  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D693     9 2F05  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D752     9 3EB1  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D811     9 4E5E  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D8D0     9 5E0A  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D990     9 6DB6  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20C9E4     9 25E0  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CAB6     9 36DB  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CC2C     9 558D  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CCE1     9 6492  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CDA1     9 743E  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D15D     9 C1F5  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D22D     9 D2F0  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D398     9 F0FA  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D697     9 2F05  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D753     9 3EB1  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D8D1     9 5E0A  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D21A     9 D1A1  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D2D9     9 E14E  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D698     9 2FAC  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D98F     9 6D0F  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DA4E     9 7CBC  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DB0D     9 8C68  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DBCD     9 9C14  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DC8B     9 ABC1  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DD4A     9 BB6D  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DE09     9 CB1A  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DEC8     9 DAC6  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20C925     9 1634  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20C9ED     9 2687  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CAA5     9 358D  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CB76     9 4687  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20CC2A     9 558D  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20D694     9 2F05  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DA4F     9 7CBC  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
     0 -  1D20DBCC     9 9C14  0 43110081   0  FF     FF   13     1  BGMS dos rewrite
F3 1>/TV2
System Slip Defect List
                             log log   log     phys   phys
        LBA    span   cumm   cyl  hd  sctr zn   cyl   sctr     SFI
           0      0      0     0  0     0   0  26B77     0 FFFFFFFF            0
       3B41F   B9E1   B9E1     0  1     0   1  2622C     0 FFFFFFFF        46E00
       7683E   B9E1  173C2     0  2     0   2  26E8C     0 FFFFFFFF        8DC00
       B1C5D   B9E1  22DA3     0  3     0   3  26C08     0 FFFFFFFF        D4A00
       ED07C   B9E1  2E784     0  4     0   4  2931B     0 FFFFFFFF       11B800
      12849B   B9E1  3A165     0  5     0   5  28F44     0 FFFFFFFF       162600
      1638BA   B9E1  45B46   120  0     0   6  26C97     0 FFFFFFFF       1A9400
      19ECD9   B9E1  51527   120  1     0   7  2634C     0 FFFFFFFF       1F0200
      1DA0F8   B9E1  5CF08   120  2     0   8  26FAC     0 FFFFFFFF       237000
      215517   B9E1  688E9   120  3     0   9  26D28     0 FFFFFFFF       27DE00
      250936   B9E1  742CA   120  4     0   A  2943B     0 FFFFFFFF       2C4C00
      28BD55   B9E1  7FCAB   120  5     0   B  29064     0 FFFFFFFF       30BA00
Head 0: entries      2        slips     B9E1
Head 1: entries      2        slips    173C2
Head 2: entries      2        slips    173C2
Head 3: entries      2        slips    173C2
Head 4: entries      2        slips    173C2
Head 5: entries      2        slips    173C2
  Total Entries      C  Total Slips    7FCAB
F3 T>/TV4
Reassigned Sectors List
Entries: 0001, Alts: 0000, Removed: 0000, Pending: 0006
Idx  LBA          PBA          LLLCHS of LBA PLPCHS of PBA SFI    Hours Msecs  Status   BBM Mask
0000 000013BF93C1 00001D32E045 ------.-.---- 040CBE.1.008E 07C5D4 ----- ------ 00010000 00001111
F3 T>/TV40
Nonresident GList                     9 entries returned
Total entries available: 9
      PBA      Len  Flags  Phy Cyl Hd  PhySctr    SFI
    13C0466A   488      0    2673B  2      0    67204
    13C04C14   122      0    26736  2      0    D9336
    13C05524   122      0    2672E  2      0    A9BEE
    13CADC46   122      0    268BA  2      0    6AC6C
    13CAE1F0   244      0    268B5  2      0    DCD9E
    13CAE9DE   244      0    268AE  2      0    9694C
    13CAF0AA   122      0    268A8  2      0    397F0
    13CB01A8   122      0    26899  2      0    A9BEE
    13CB03EC   122      0    26897  2      0    D7602
F3 T>/2x0
User Partition
LBAs 00000000-1D326C3F
PBAs 00000000-1D5B8470
HdSkew 006E, CylSkew 0032
ZonesPerHd 11
Head 0, PhyCyls 000000-041644, LogCyls 000000-040A5E
     Physical      Logical       Sec   Sym   Sym      Data
  Zn Cylinders     Cylinders     Track Wedge Track    Rate
  00 000000-003670 000000-003670 0193  09D5  0013B5E8 1625.156
  01 003671-0076C6 003671-0076C6 0188  0992  00133200 1582.968
  02 0076C7-00C028 0076C7-00C028 0175  0925  00125F58 1514.531
  03 00C029-010C88 00C029-010C88 016B  08E2  0011D978 1471.406
  04 010C89-015A76 010C89-015A76 015B  0882  00112068 1412.343
  05 015A77-019C1E 015A77-019C1E 0158  086D  0010F518 1398.750
  06 019C1F-01E240 019C1F-01E240 0150  0830  00107EF8 1360.312
  07 01E241-02291E 01E241-02291E 0140  07D8  000FCFC0 1304.062
  08 02291F-026B76 02291F-026B76 012B  0755  000ECDD8 1220.625
  09 026DB7-02B2B6 026B77-02B076 0120  070C  000E4018 1175.156
  0A 02B2B7-02F10E 02B077-02EECE 010B  068E  000D4610 1095.000
  0B 02F10F-03286D 02EECF-03262D 0100  064B  000CC420 1052.812
  0C 03286E-0360F9 03262E-035EB9 00F4  05FF  000C2E80 1005.000
  0D 0360FA-039079 035EBA-038E39 00E5  059F  000B7180  943.593
  0E 03907A-03BEBB 038E3A-03BC7B 00DD  0570  000B14F8  914.062
  0F 03BEBC-03EFAC 03BC7C-03ED6C 00CD  050D  000A5210  851.718
  10 03EFAD-041644 03ED6D-040A5E 00C6  04E0  0009FB70  823.593
Head 1, PhyCyls 000000-0415EE, LogCyls 000000-040A7E
  00 000000-003623 000000-003623 019B  0A0E  00142818 1662.187
  01 003624-0074B7 003624-0074B7 0193  09D5  0013BBD0 1627.500
  02 0074B8-00BB56 0074B8-00BB56 0185  0983  00131868 1574.531
  03 00BB57-010616 00BB57-010616 0181  096A  0012E928 1559.062
  04 010617-015125 010617-015125 016D  08EE  0011F310 1479.843
  05 015126-0191C5 015126-0191C5 0162  08A9  00116F28 1437.656
  06 0191C6-01D845 0191C6-01D845 0152  0848  0010AE38 1375.781
  07 01D846-021F23 01D846-021F23 0143  07EB  000FF720 1316.250
  08 021F24-02622B 021F24-02622B 0133  0786  000F3240 1252.968
  09 02646C-02AA7F 02622C-02A83F 0120  070C  000E4018 1175.156
  0A 02AA80-02EACF 02A840-02E88F 0112  06B9  000D9CB0 1122.187
  0B 02EAD0-0323F0 02E890-0321B0 0105  0668  000CFD38 1071.562
  0C 0323F1-035E97 0321B1-035C57 00F6  060B  000C4620 1012.031
  0D 035E98-038F17 035C58-038CD7 00E5  059F  000B7180  943.593
  0E 038F18-03BD59 038CD8-03BB19 00D9  0556  000ADFD0  897.187
  0F 03BD5A-03EF56 03BB1A-03ED16 00CD  050D  000A5210  851.718
  10 03EF57-0415EE 03ED17-040A7E 00C6  04E0  0009FB70  823.593
Head 2, PhyCyls 000000-041C71, LogCyls 000000-041161
  00 000000-00370A 000000-00370A 0193  09D5  0013B5E8 1625.156
  01 00370B-0077BA 00370B-0077BA 018C  09AD  00136920 1600.312
  02 0077BB-00C0B7 0077BB-00C0B7 017E  0959  0012C3C0 1547.343
  03 00C0B8-010D17 00C0B8-010D17 0172  090D  00122E20 1499.062
  04 010D18-015B05 010D18-015B05 015F  0896  001145D0 1424.531
  05 015B06-019D05 015B06-019D05 0155  085A  0010CFB0 1386.562
  06 019D06-01E441 019D06-01E441 0143  07EA  000FF330 1315.312
  07 01E442-022BDB 01E442-022BDB 0134  078B  000F3630 1254.375
  08 022BDC-026E8B 022BDC-026E8B 0122  071D  000E5F98 1185.468
  09 0270CC-02B6DF 026E8C-02B49F 0117  06D8  000DDDA8 1143.281
  0A 02B6E0-02F687 02B4A0-02F447 0109  0681  000D2C78 1086.562
  0B 02F688-032F5D 02F448-032D1D 00FD  0639  000C9EB8 1041.093
  0C 032F5E-0368D0 032D1E-036690 00EF  05E0  000BEF80  984.375
  0D 0368D1-039810 036691-0395D0 00E0  0580  000B3088  922.968
  0E 039811-03C5D6 0395D1-03C396 00D9  0556  000ADFD0  897.187
  0F 03C5D7-03F641 03C397-03F401 00C9  04F2  000A1CE8  834.375
  10 03F642-041C71 03F402-041161 00BF  04B5  0009A4D0  795.468
Head 3, PhyCyls 000000-041E58, LogCyls 000000-04136C
  00 000000-003670 000000-003670 0180  0963  0012D578 1552.968
  01 003671-0076C6 003671-0076C6 0174  0918  00123FD8 1504.687
  02 0076C7-00BEF9 0076C7-00BEF9 0168  08CA  0011A840 1455.937
  03 00BEFA-010AF1 00BEFA-010AF1 0159  0873  0010FCF8 1401.093
  04 010AF2-0158DF 010AF2-0158DF 0150  083B  00109A88 1369.218
  05 0158E0-019A87 0158E0-019A87 0148  0807  00102858 1332.656
  06 019A88-01E165 019A88-01E165 0130  0773  000F04F8 1238.437
  07 01E166-0228FF 01E166-0228FF 0126  0732  000E8500 1197.187
  08 022900-026C07 022900-026C07 0118  06DB  000DD9B8 1142.343
  09 026E48-02B4B7 026C08-02B277 0108  067A  000D1AC0 1080.937
  0A 02B4B8-02F4B3 02B278-02F273 00F6  0610  000C4C08 1014.843
  0B 02F4B4-032E1F 02F274-032BDF 00E9  05BB  000BAC90  962.812
  0C 032E20-0368C6 032BE0-036686 00DD  056F  000B0D18  911.250
  0D 0368C7-039906 036687-0396C6 00CF  0518  000A61D0  856.406
  0E 039907-03C70A 0396C7-03C4CA 00C2  04C9  0009C648  806.250
  0F 03C70B-03F8C4 03C4CB-03F684 00B7  0483  00093C78  761.718
  10 03F8C5-041E58 03F685-04136C 00AE  044C  0008D030  727.031
Head 4, PhyCyls 000000-045C94, LogCyls 000000-0450E8
  00 000000-003AF3 000000-003AF3 017C  094B  0012A440 1537.031
  01 003AF4-007F81 003AF4-007F81 0174  0918  00123FD8 1504.687
  02 007F82-00CC70 007F82-00CC70 0168  08CA  0011A840 1455.937
  03 00CC71-011CE0 00CC71-011CE0 0160  089D  00114FA8 1427.343
  04 011CE1-016EE8 011CE1-016EE8 0154  0853  0010BFF0 1380.937
  05 016EE9-01B508 016EE9-01B508 0148  0807  00102858 1332.656
  06 01B509-02004E 01B509-02004E 0139  07AD  000F7728 1275.000
  07 02004F-024BF2 02004F-024BF2 012D  0761  000EE770 1229.062
  08 024BF3-02931A 024BF3-02931A 011D  06FD  000E1EA0 1164.375
  09 02955B-02DF62 02931B-02DD22 010D  0699  000D5BB8 1101.562
  0A 02DF63-0322FA 02DD23-0320BA 00FE  063C  000CA2A8 1042.031
  0B 0322FB-035EBE 0320BB-035C7E 00F4  05FF  000C2A90 1003.125
  0C 035EBF-039B80 035C7F-039940 00E1  0588  000B3E50  927.187
  0D 039B81-03CE00 039941-03CBC0 00D8  054D  000ACC20  890.625
  0E 03CE01-03FF68 03CBC1-03FD28 00D1  0525  000A7D60  865.312
  0F 03FF69-0433C0 03FD29-043180 00C4  04D3  0009DBF0  813.281
  10 0433C1-045C94 043181-0450E8 00B9  0490  00095808  770.625
Head 5, PhyCyls 000000-04603F, LogCyls 000000-045463
  00 000000-003AA6 000000-003AA6 0184  097D  001306B0 1568.906
  01 003AA7-007F34 003AA7-007F34 017A  0939  001280D0 1525.781
  02 007F35-00CBBE 007F35-00CBBE 016E  08F8  001208B8 1487.343
  03 00CBBF-011C96 00CBBF-011C96 0164  08B5  001180E0 1443.281
  04 011C97-016E35 011C97-016E35 015F  0896  001145D0 1424.531
  05 016E36-01B245 016E36-01B245 0148  0807  00102858 1332.656
  06 01B246-01FD2D 01B246-01FD2D 0136  0797  000F4BD8 1261.406
  07 01FD2E-024873 01FD2E-024873 0128  0742  000EA678 1207.968
  08 024874-028F43 024874-028F43 011D  06FD  000E1EA0 1164.375
  09 029184-02DB8B 028F44-02D94B 0110  06AB  000D7D30 1112.343
  0A 02DB8C-031FCB 02D94C-031D8B 0101  0650  000CCA08 1054.687
  0B 031FCC-035CBB 031D8C-035A7B 00F1  05EC  000C0528  990.937
  0C 035CBC-039B98 035A7C-039958 00E4  059B  000B65B0  940.312
  0D 039B99-03CF58 039959-03CD18 00D8  054D  000ACC20  890.625
  0E 03CF59-04017A 03CD19-03FF3A 00CC  0507  000A4250  846.093
  0F 04017B-04369B 03FF3B-04345B 00BE  04AF  00099510  790.312
  10 04369C-04603F 04345C-045463 00B5  0478  000928C8  755.625
F3 2>/2T880
WARNING: Drive MC Area has been modified by serial port.
MC area must be re-initialized to ensure MC control data is valid
DO NOT SHIP WITHOUT FIRST RE-INITIALIZE MC AREA!
        Cyl   Head  MnZn  Throughput
Hd  Zn  Skew  Skew  Skew  (MB/s)
0   00  32    6E    69    150.538
0   01  32    6E    69    146.432
0   02  32    6E    69    139.371
0   03  32    6E    69    135.613
0   04  32    6E    69    129.637
0   05  32    6E    69    128.512
0   06  32    6E    69    125.520
0   07  32    6E    69    119.544
0   08  32    6E    69    111.713
0   09  32    6E    69    107.594
0   0A  32    6E    69     99.756
0   0B  32    6E    69     95.658
0   0C  32    6E    69     91.165
0   0D  32    6E    69     85.566
0   0E  32    6E    69     82.578
0   0F  32    6E    69     76.600
0   10  32    6E    69     73.981
1   00  32    6E    69    153.508
1   01  32    6E    69    150.546
1   02  32    6E    69    145.316
1   03  32    6E    69    129.076
1   04  32    6E    69    136.349
1   05  32    6E    69    132.246
1   06  32    6E    69    126.288
1   07  32    6E    69    120.680
1   08  32    6E    69    114.685
1   09  32    6E    69    107.594
1   0A  32    6E    69     91.724
1   0B  32    6E    69     97.502
1   0C  32    6E    69     91.910
1   0D  32    6E    69     85.561
1   0E  32    6E    69     81.083
1   0F  32    6E    69     76.597
1   10  32    6E    69     73.996
2   00  32    6E    69    150.555
2   01  32    6E    69    121.340
2   02  32    6E    69    142.708
2   03  32    6E    69    112.411
2   04  32    6E    69    117.455
2   05  32    6E    69     94.742
2   06  32    6E    69    120.734
2   07  32    6E    69    115.076
2   08  32    6E    69    108.354
2   09  32    6E    69    104.280
2   0A  32    6E    69     99.047
2   0B  32    6E    69     94.544
2   0C  32    6E    69     89.301
2   0D  32    6E    69     75.047
2   0E  32    6E    69     81.116
2   0F  32    6E    69     75.149
2   10  32    6E    69     71.376
3   00  32    6E    69    143.430
3   01  32    6E    69    138.970
3   02  32    6E    69    134.475
3   03  32    6E    69    128.888
3   04  32    6E    69    125.496
3   05  32    6E    69    122.532
3   06  32    6E    69    113.567
3   07  32    6E    69    109.830
3   08  32    6E    69    104.605
3   09  32    6E    69     98.609
3   0A  32    6E    69     91.948
3   0B  32    6E    69     87.072
3   0C  32    6E    69     82.573
3   0D  32    6E    69     77.342
3   0E  32    6E    69     72.505
3   0F  32    6E    69     68.392
3   10  32    6E    69     65.031
4   00  32    6E    69    141.940
4   01  32    6E    69    138.958
4   02  32    6E    69    134.497
4   03  32    6E    69    131.490
4   04  32    6E    69    127.022
4   05  32    6E    69    122.540
4   06  32    6E    69    116.933
4   07  32    6E    69    112.453
4   08  32    6E    69    106.479
4   09  32    6E    69    100.500
4   0A  32    6E    69     94.899
4   0B  32    6E    69     91.165
4   0C  32    6E    69     84.072
4   0D  32    6E    69     80.705
4   0E  32    6E    69     78.100
4   0F  32    6E    69     73.251
4   10  32    6E    69     69.141
5   00  32    6E    69    144.943
5   01  32    6E    69    141.199
5   02  32    6E    69    136.751
5   03  32    6E    69    132.987
5   04  32    6E    69    131.118
5   05  32    6E    69    122.546
5   06  32    6E    69    115.815
5   07  32    6E    69    110.589
5   08  32    6E    69    106.479
5   09  32    6E    69    101.618
5   0A  32    6E    69     96.022
5   0B  32    6E    69     90.046
5   0C  32    6E    69     85.194
5   0D  32    6E    69     80.701
5   0E  32    6E    69     76.236
5   0F  32    6E    69     70.983
5   10  32    6E    69     67.646
发表于 2017-3-31 20:52:54 | 只看该作者 �
高手指点下
发表于 2017-4-3 21:13:49 | 只看该作者 �
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA。。。。。。。。。。。。。。。。。。。。。。。
发表于 2017-4-4 00:36:36 来自迅维网APP | 只看该作者 �
段位很好,试试清smart g表,在重建译码器
发表于 2017-4-4 23:42:55 来自迅维网APP | 只看该作者 �
10楼帅哥,重建泽码器这个功能是哪个软件
发表于 2017-4-4 23:45:10 来自迅维网APP | 只看该作者 �
本人对这个软件功能不太清楚,重建译码器功能在哪?
发表于 2017-4-4 23:47:24 来自迅维网APP | 只看该作者 �
有没可以备份固件的工具?要新点盘能支持的最好
发表于 2017-4-5 21:38:55 | 只看该作者 �
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa....
发表于 2017-4-6 21:41:41 | 只看该作者 �
来啊,来人啊。。。。
发表于 2017-4-7 19:56:54 | 只看该作者 �
短接试试
发表于 2017-4-9 20:49:01 | 只看该作者 �
这个可以的
发表于 2017-4-9 20:52:28 | 只看该作者 �
看来对希捷盘没有什么好方法,我还有一堆有坏道的西数,苦于没有好的良方
发表于 2017-4-10 07:36:37 | 只看该作者 �
F3的盘不是这么容易搞的
发表于 2017-4-13 16:05:02 | 只看该作者 �
这个得有工具才能搞定,你这是报MCMT错误
