查看: 4359|回复: 4
拯救者14 15 ISK 的BIOS
发表于 2016-1-17 16:10:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
提供个BIOS,给需要的朋友们
拯救者14 15 ISK 的BIOS  0KCN23WW
具体更新说明在里面有文件
Updated Date        2015/11/09
Software name           0KCN23WW
Support models             Rescuer-14ISK/15ISK
Operating Systems              Microsoft Windows 10 64bit
Whatthispackagedoes:
BIOS, abbreviation of Basic Input / Output System, is integrated in ROM chip on main board, which contains the basic
Input/output program, system configuration information, system startup self-check and pre-setup programs.
BIOS provides most basic low-level hardware operations; it is the connection between software and hardware, and interfacing window of hardware and operating system.
Note: Make note of any settings you have changed in the BIOS Configuration Utility. These settings may have to be re-entered after updating the BIOS.
Attention: Do not power off or restart your computer during the BIOS flashing process, which will cause serious damage and improper functioning of your computer.
Print this file so that you can refer to it during the installation.
拯救者14 15 ISK 0KCN23WW.part2.rar (265.08 KB, 下载次数: 35)
发表于 2016-2-2 15:50:17 | 只看该作者 �
还有另一个呢?少传了一个,两个一样的
发表于 2016-3-22 10:56:40 | 只看该作者 �
根本不能解压,扯淡
发表于 2018-3-9 09:59:11 | 只看该作者 �
是官方的还是分离好的bios
发表于 2019-4-2 14:05:38 | 只看该作者 �
没有分卷1,两个文件是一样的。。。。。。
