查看: 4487|回复: 31
The touchpad repair of Lenovo G460E
发表于 2013-11-21 22:36:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
                                Lenovo G460e                  FAULT:   TP does not work
DESCRIPTION:
   The keyboard connector and the touchpad interface have both been eroded by an unknown liquid !Two  capacitors connected to the touch panel have been completely corroded !
MAINTENANCE RECORDS:
Customer has recently replaced the KB  by himself !
REPAIR PROCESS:
    Firstly, I cleaned the both places with banana water very carefully !
     Secondly, I measured one pin of the touchpad interface with my multimeter , Unexpectedly ,the voltage of the pin was only 2.86v !
      Thirdly, I measured the voltage of the related pull-up resistor next to EC,found that,The multimeter showed the number of 5.03V!
        Finally,connected the  pull-up resistor  to the related point  without normal voltage on the touchpad with one Copper wire ,In addition, cut the wire that from the point to the anormal pin !
   That's all ! Thank you for watching........
                            The end
                    有事您Q我
参与人数 1下载分 -2 收起 理由
sw1238845 -2 反对外国人来这发帖!
发表于 2013-11-21 23:09:51 | 只看该作者 �
全是英文,哪个高手能翻译下了,拜托
发表于 2013-11-21 23:22:33 | 只看该作者 �
键盘改的线昨天问你没说今天来英文的
大哥,这是另外一台!不是昨天那台!那是HP!这是lenovo!  详情 回复 发表于 2013-11-21 23:31
发表于 2013-11-21 23:31:36 | 只看该作者 �
故障:TP不work8 X9 O4 S4 P6吨:Q)B'V
产品描述:
    键盘和触摸板接口连接都被不明液体侵蚀连接两个电容触摸面板已经完全被腐蚀!
维修记录:
客户最近已经取代了自己的KB!
   T + B2 B5 Q2 ^ 1`9 T#P + Z
维修过程:0宽* W%I4Ø,S0Ž
     首先,我非常仔细地用香蕉水清洗两地!
      不料,其次,我触摸板接口与我的万用表测量引脚,引脚的电压只有2.86V!
0 H-J7`,O&C *?&M(G0 R1Ž
       第三,我旁边的EC相关的上拉电阻,测量电压发现,万用表显示5.03V的数量!
:R&] / ^ 6号码:{1〜2点。 C#\。 O.ħ
         最后,上拉电阻连接到相关的点,而不在触摸板上与铜线的正常电压,另外,切割导线,从点到的异常可引脚与[5 | +升#X! Ÿ
'N&{%? E4 W4í
    这一切!感谢您的收看
老大!你以为这些翻译软件很准确吗!好多地方都翻译的不是那么回事!甚至念不通,,,明白???  详情 回复 发表于 2013-11-21 23:35
发表于 2013-11-21 23:31:52 | 只看该作者 �
发表于 2013-11-21 23:35:44 | 只看该作者 �
产 ...
发表于 2013-11-22 00:01:14 | 只看该作者 �
小斌,下会不要英文了,看不来OK
发表于 2013-11-22 00:09:19 | 只看该作者 �
产 ...
伙计,你做多久了!还问这种问题??还有我那帖子上已经写的清清楚楚了!
发表于 2013-11-22 00:12:11 | 只看该作者 �
!三娃! 发表于 2013-11-21 23:09
全是英文,哪个高手能翻译下了,拜托
兄弟,英文不过关还来修电脑!真是佩服!
发表于 2013-11-22 08:30:11 | 只看该作者 �
牛人啊  学习了
发表于 2013-11-22 08:58:44 | 只看该作者 �
英文不错, 就是彩色字看得有点蛋疼
是啊!这帖子可是花了我好几个小时啊!  详情 回复 发表于 2013-11-22 19:01
发表于 2013-11-22 09:05:04 | 只看该作者 �
是美国人来中国修电脑吗{:soso_e110:}
你这发型是外星球来到地球的吗。。。。。  详情 回复 发表于 2013-11-22 19:00
发表于 2013-11-22 10:10:46 | 只看该作者 �
{:soso_e127:}英文好,也不要在这里显摆吧。
晕!这叫显摆????  详情 回复 发表于 2013-11-22 18:59
发表于 2013-11-22 10:44:47 | 只看该作者 �
楼主  搞个英文干吗   看不懂  难道你要做唯一
还有一点就是我这样也可以给广大的迅维维修人员一点更新鲜的东西啊!让迅维多姿多彩起来!呵呵  详情 回复 发表于 2013-11-22 18:59
发表于 2013-11-22 10:45:49 | 只看该作者 �
呵呵,,要的就是英文!说白了 就是故意的!!唯一!那是必须的!我不喜欢走寻常路!  详情 回复 发表于 2013-11-22 18:57
发表于 2013-11-22 18:57:33 | 只看该作者 �
发表于 2013-11-22 18:59:35 | 只看该作者 �
发表于 2013-11-22 18:59:56 | 只看该作者 �
liudecai1984 发表于 2013-11-22 10:10
英文好,也不要在这里显摆吧。
晕!这叫显摆????
发表于 2013-11-22 19:00:43 | 只看该作者 �
邱大侠 发表于 2013-11-22 09:05
是美国人来中国修电脑吗
你这发型是外星球来到地球的吗。。。。。
发表于 2013-11-22 19:01:07 | 只看该作者 �
cl0912 发表于 2013-11-22 08:58
英文不错, 就是彩色字看得有点蛋疼
是啊!这帖子可是花了我好几个小时啊!
