查看: 2546|回复: 12
问前辈们下面这个是哪个显存出问题了
发表于 2013-6-30 18:46:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
MATS version G98_BETA1.  Testing G92 with 512 MB of memory.
Errors found.  Use .Status() or .PrintErrors() for more info.
This message will only appear once.
   LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
FBA[31: 0]           0            0            0
FBA[63:32]           0            0            0
FBB[31: 0]           0            0            0
FBB[63:32]           0      1712512            0
FBC[31: 0]           0            0            0
FBC[63:32]           0            0            0
FBD[31: 0]           0            0            0
FBD[63:32]           0            0            0
External Bank 0 Failing bits:
   B36
Read    Error Count: 0
Write   Error Count: 1712512
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  UNKNOWN
B36      428128           0           0
B36      428128           0           0
B36      428128           0           0
B36      428128           0           0
ADDRESS  EXPECTED  ACTUAL  REREAD1  REREAD2  FAILBITS TYPE  P L E I ROW  COL BO
0222faac 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d7 3
0222faa8 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d6 2
0222faa4 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d5 1
0222faa0 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d4 0
0222fa8c 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d3 3
0222fa88 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d2 2
0222fa84 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d1 1
0222fa80 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 1d0 0
0222eaac 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 157 3
0222eaa8 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 156 2
0222eaa4 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 155 1
0222eaa0 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 154 0
0222ea8c 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 153 3
0222ea88 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 152 2
0222ea84 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 151 1
0222ea80 00000000 00000010 00000010 00000010 00000010 WRITE B 1 0 5 0111 150 0
0222daac 00000000 00000010 00000010 00000010 000
应该是最下面那颗  发表于 2013-6-30 19:12
发表于 2013-6-30 18:52:57 | 只看该作者 �
你这个是用什么软件测试的?笔记本的能测试么?
发表于 2013-6-30 19:55:50 | 只看该作者 �
怎么感觉看上去发霉了
发表于 2013-6-30 20:05:37 | 只看该作者 �
楼主用的什么软件啊
发表于 2013-6-30 20:42:17 | 只看该作者 �
这个是2G的显卡吧!你这个测试我看不懂哦,又是什么一个东东啊。求解释啊
实DOS版显卡核心测试软件——刚才回复错了  详情 回复 发表于 2013-6-30 21:24
一看就知道你直接跳过主板学的笔记本,远程实地课件均有介绍!  详情 回复 发表于 2013-6-30 20:49
发表于 2013-6-30 20:49:36 | 只看该作者 �
实DOS版显卡核心测试软件,没有实践过,我现在还很菜的  详情 回复 发表于 2013-6-30 21:21
的确哦,呵呵,直接学的笔记本,这个是什么东西呢  发表于 2013-6-30 21:03
发表于 2013-6-30 21:21:50 | 只看该作者 �
实DOS版显卡核心测试软件,没有实践过,我现在还很菜的{:3_53:}
呵呵,我直接没有见过,更不知道怎么用了,有时间研究研究  发表于 2013-6-30 21:31
发表于 2013-6-30 21:24:37 | 只看该作者 �
实DOS版显卡核心测试软件——刚才回复目标错了
发表于 2013-6-30 22:17:35 | 只看该作者 �
笔记本的也有哦
发表于 2013-6-30 22:23:03 | 只看该作者 �
这是台式显卡吧?
没用过这种软件
建议去板卡区问下吧
发表于 2013-7-1 08:27:46 | 只看该作者 �
个人感觉M8  以前修过一样差不多的 也是B组错 不过是B组的0到31之间的是M5!B2应该是M8  !1个点包错  有可能BGA空焊
发表于 2013-7-1 09:27:36 | 只看该作者 �
一个点的写入错误,看着像是M7吧?
发表于 2013-7-1 09:59:32 | 只看该作者 �
有时间 用用这个软件
