查看: 1090|回复: 0
清除BISO
头像被屏蔽
发表于 2011-9-1 22:18:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
JP KEYBOARD ON OFF
UK(GR) KEYBOARD ON ON
Password Override ( CMOS / RTC Data ) Jumper Setting
Password Override Pin #4
RTC Battery Normal OFF
Clear (RTC) DATA ON
Before doing password override, take off AC adapter and battery first.
CD-ROM Master / Slave Select
CD-ROM Pin #6
Master OFF
Slave ON
Pin # 1 & # 5 are N/A Pin for reserve
Y810如何清pwd
键盘接口处有跳线,将SW1拨到8即可clear bios pwd
S180如何清pwd
SW1 4
Password Normal OFF
Clear Password ON
Y520 BIOS 密码清除
To switch "SW1","1-->ON", we can by pass the password checking.
(beside audio DJ control panel FPC connecter)
K71:
拔CMOS电池,如果不能清除,需要将电池的两个接口短路(时间比较久)。
E360
Dip Switch (SW3)
KeyboardSelect1 Bit1Refer to the below table 1.K/B controllerPort 60*1
KeyboardSelect2 Bit2Refer to the below table 1.K/B controllerPort 61*1
Sign On Loge Bit3 Base on customer request K/B controllerPort 63*1
Password Bit4 This bit is for password override. ON: Override OFF: Available (factory setting)K/BControllerPort 64
For M/B version Bit5ReservedK/B controllerPort 62*1
Reserve Bit6ReservedN.C
CSEL Bit7ON : connect to GNDOFF : NC
RTC Clear Bit8ON : COMS SRAM ClearOFF : Reserved
