查看: 2032|回复: 2
[显卡维修]
一块AGP9800PRO 玩游戏花屏测试结果请高手帮忙看一下
发表于 2010-12-16 18:06:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
华硕 9800PRO 双256,看电影网页之类的一点也没事,只要玩游戏,就会花屏,这是r3memid的测试请高手帮忙看一下。
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[2  ] Data line toggle (GUI)                              : PASS
[1  ] Fill                                                : PASS
[3  ] RW column (GUI)                                     : PASS
[4  ] RW page (GUI)                                       : PASS
[5  ] RW channel (GUI)                                    : PASS
[6  ] Data mask                                           : PASS
[7  ] Macro + Micro8x2 tiling read                        : PASS
[8  ] Macro + Micro4x4 tiling write                       : PASS
[9  ] Byte swap macro+micro8x2 read                       : PASS
[10 ] Byte swap macro+micro4x4 write                      : PASS
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : PASS
[15 ] Line slopes/dir/P/solid                             : PASS
TEST RESULT SUMMARY:
R360 (0x4e48) detected.
256M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : PASS
    Error ID G0TR055
Failure detected.
发表于 2010-12-16 18:40:05 | 只看该作者 �
先用软件,降频使用看看再说
发表于 2010-12-16 21:38:06 | 只看该作者 �
没报错 R3114 手动测试1和2项看看
