查看: 2421|回复: 2
[显卡维修]
在在发asus6600gt显卡花屏2结果
 关闭 [复制链接]
发表于 2007-11-18 12:29:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广西钦州 来自 广西钦州
拆掉U8后。测得结果
Errors found.  Use .Status() or .PrintErrors() for more info.
This message will only appear once.
   LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
FBA[31: 0]      931737     20199113            0
FBA[63:32]     1061344     24233082            0
External Bank 0 Failing bits:
   A00 A01 A02 A03 A04 A05 A06 A07 A08 A09 A10 A11 A12 A13 A14 A15
   A16 A17 A18 A19 A20 A21 A22 A23 A24 A25 A26 A27 A28 A29 A30 A31
   A32 A33 A34 A35 A36 A37 A38 A39 A40 A41 A42 A43 A44 A45 A46 A47
   A48 A49 A50 A51 A52 A53 A54 A55 A56 A57 A58 A59 A60 A61 A62 A63
Read    Error Count: 1993081
Write   Error Count: 44432195
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  UNKNOWN
A00     4100751      105424           0
A00     4033907      199219           0
A00     4161982       47526           0
A00     4032193      185335           0
A01     2055619       81558           0
A01     2021956      140760           0
A01     2090397       30447           0
A01     2019536      107808           0
A02     4100760      105401           0
A02     1900100      203771           0
A07     2021944      140752           0
A07     2090424       30428           0
A07     2019634      107732           0
A08     4100702      105435           0
A08     4033816      199288           0
A08     4161928       47568           0
A08     4032102      185408           0
A09     2055570       81569           0
A09     2021866      152308           0
A09     2090343       30489           0
A09     2019477      121077           0
A10     4100711      105412           0
A10     4033797      205908           0
A10     4161937       47555           0
A10     4032171      193343           0
A11     2055579       81546           0
A11     2021845      140843           0
A11     2090352       30476           0
A11     2019479      107849           0
A12     4100712      105427           0
A12     4033824      199266           0
A12     4161946       47562           0
A12     4032166      185364           0
A13     2055580       81561           0
A13     2021873      140807           0
A13     2090361       30483           0
A13     2019509      107837           0
A14     4100721      105404           0
A14     4033804      199280           0
A14     4161955       47549           0
A14     4032200      185332           0
A15     2055589       81538           0
A15     3912236      247865           0
A15     2090370       30470           0
A15     2021319      153203           0
A16     4100784      105383           0
A20     4162041       47483           0
A20     1930990      156132           0
A21     2055662       81509           0
A21     2022084      140626           0
A21     2090456       30404           0
A21     2019704      107672           0
A22     4100817       99649           0
A22     4034016      202994           0
A24     4032206      185316           0
A25     2055603       81528           0
A25     2021985      140717           0
A25     2090384       30452           0
A25     2019549      107789           0
A26     4100744      105371           0
A26     4033916      199190           0
A31     3912200      261559           0
A31     2090411       30433           0
A31     2021425      166247           0
A35     2030018       98757           0
A36     4016375      195619           0
A36     4022264      177378           0
A36     4036329      175646           0
A36     4042284      169162           0
A37     2020727      122137           0
A55     2030161       91019           0
A56     4016243      195637           0
A56     4022285      181213           0
A56     4036388      175581           0
A56     4042233      170575           0
A57     2020595      122155           0
A57     2018100      114374           0
A57     2029772       91773           0
A57     2030024       91148           0
A58     4016243      195637           0
A58     4022248      181248           0
A58     4036412      175557           0
A58     4042240      170564           0
A59     2020595      122155           0
A59     2018063      114409           0
A59     2029796       91749           0
A59     2030031       91137           0
A60     4016314      195582           0
A60     4022332      177286           0
A60     4036424      175551           0
A60     4042302      169124           0
A61     2020666      122100           0
A61     2018147      114339           0
A61     2029808       91743           0
A61     2030076       91100           0
A62     4016314      195582           0
A62     4022296      175825           0
A62     4036448      175527           0
A62     2013273      117047           0
A63     2020666      122100           0
A63     2018110      114374           0
A63     2029832       91719           0
A63     2030083       91089           0
发表于 2007-11-20 17:23:44 | 只看该作者 来自: 福建福州 来自 福建福州
感觉你这片只要吹下gpu可能就好了,现在解决怎么样了?
发表于 2007-11-21 19:55:17 | 只看该作者 来自: 广西钦州 来自 广西钦州
不行啊。把显存焊回,催了GPU还是不行????????“
