查看: 1042|回复: 2
toshiba m205
发表于 2010-7-28 02:46:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
hello,
i have toshiba sat m205 invetec board when using charger and batt the laptop hangs.if you use only adapter then works in windows no problem orif you use only battery then works ok.but when use charger ad battery the hags in windows.i have 2 pcs with same problem.
thanks for help
发表于 2010-7-28 09:43:25 | 只看该作者 �
  adapter detect or exchange problems
发表于 2010-7-28 09:44:41 | 只看该作者 �
The attempt replaces the cpu electric capacity
