查看: 5898|回复: 10
没事研究一下 FLUKE105B 100M示波表修主板够用了吧
发表于 2010-7-26 15:44:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
准备收块表大家来给看看合适不参数:Fluke 105B 100 MHz ScopeMeter Series II
Fluke 105B Features:
■High-Contrast, Backlit Display
■Automatic Setup Measurements: 40
■Waveform and Screen image transfers to a PC and Remote Operation
■Screen Image Transfers to a PC
■Signal Generator/Component Tester Output
■On-line Help (information)
■4 Hour NiCad Battery and Charger
■Optically Isolated RS-232C Interface for Printer and PC (PM 9080 cable required)
■PC Software & PM 9080 Cable
■Hard Carrying Case
Multimeter Features:
■5 MHz DMM Measurements & Full Waveform
■Autoranging
■Min Max TrendPlot with New Time and Date Stamp
■Advanced Measurements: Temp., Current, RPM, % Duty, Pulse Width, dB, Hz, % Scale, Amps, Watts, and more
■True-rms Volts
■Diode Test (up to 2.8V)
■Continuity Beeper
Oscilloscope Features:
■Bandwidth: 100 MHz
■Maximum Repetitive Sample Rate: 5 GS/s
■Maximum Time Resolution: 200 ps
■Number of Channels: 2
■Continuous Autoset
■Video Triggering, NTSC, PAL. SECAM, & Hi Resolution Video (l& field selectable)
■ScopeRecord
? in 30k Memory; (Time base ≥20 ms/div)
■Glitch Capture down to 40 ns
■Time/Division: 5 ns/div to 60 sec/div
■Volts/Division: 1 mV/div to 100 V/div
■Pre & Post Trigger: -20 to +640 div
■Trigger Delay: Cycles, Event, Time & Zoom
■Envelope Mode: Min/Max
■Gray Scale Waveform Display
■Cursor Measurements
■Waveform Mathematics: Integrate, +, -, filter
■Measure Amps with Optional Current Clamps
■Screen Memory: 10
■Waveform Memory: 20
■Setup Memory: 40
发表于 2010-7-26 17:33:37 | 只看该作者 �
长见识了,干啥用啊!波形能看到吗?
发表于 2010-7-26 18:08:50 | 只看该作者 �
比较小巧 携带方便 多少米?
发表于 2010-7-26 20:24:38 | 只看该作者 �
这表还真没用过,多少米呀?
发表于 2010-7-26 21:02:14 | 只看该作者 �
这表第一次见 参数全英文谁看得懂啊 发个中文的研究研究 呵呵
发表于 2010-7-26 21:23:43 | 只看该作者 �
哇!这真的是示波器吗?有波形吗?什么地方买的?多少钱啊?
发表于 2010-7-26 21:25:34 | 只看该作者 �
是新的吗,最少1W块现大洋
发表于 2010-7-26 23:48:12 | 只看该作者 �
这个表用起来是很方便精度还可以,可是配件的价格吓人哦。电池好像要2K多。。
发表于 2010-7-27 08:04:26 | 只看该作者 �
我表我一直用着,采样还低了点,老式的继电器转换。
发表于 2010-7-27 10:04:53 | 只看该作者 �
想收来修主板,就是不知道合适不,高手给推荐一个吧。
发表于 2010-7-27 10:13:40 | 只看该作者 �
没用过,来围观下。。。。这个要1W。。。好吓人。。
