查看: 8206|回复: 5
烦请高手详解八脚BIOS引脚含义
发表于 2010-5-31 13:49:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
烦请高手详解八脚BIOS引脚含义
发表于 2010-5-31 17:31:10 | 只看该作者 �
你电脑里没有安装看PDF文件的软件。
发表于 2010-5-31 13:56:45 | 只看该作者 �
1 片选 当cpu选中他就会拉低 2spi的接受发送叫主入从出 你就理解成数据交换的线吧 有不规则的波形 3 写保护 4  8 不用解释了吧 5 和2相对的主入从出 6 时钟
发表于 2010-5-31 14:00:01 | 只看该作者 �
SCK Serial Clock To provide the timing of the serial interface.
Commands, addresses, or input data are latched on the rising edge of the clock input, while output
data is shifted out on the falling edge of the clock input.
SI Serial Data Input
To transfer commands, addresses, or data serially into the device.
Inputs are latched on the rising edge of the serial clock.
SO Serial Data Output
To transfer data serially out of the device.
Data is shifted out on the falling edge of the serial clock.
CE# Chip Enable The device is enabled by a high to low transition on CE#. CE# must remain low for the duration of any command sequence.
WP# Write Protect The Write Protect (WP#) pin is used to enable/disable BPL bit in the status register.
HOLD# Hold To temporarily stop serial communication with SPI flash memory without resetting the device.
VDD Power Supply To provide power supply (3.0-3.6V).
VSS Ground
http://www.semiconductorstore.com/pdf/newsite/siliconstorage/25LF020A334CSAE_DS.pdf
发表于 2010-5-31 14:06:11 | 只看该作者 �
非常感谢!
发表于 2010-5-31 15:49:14 | 只看该作者 �
又有收获,感谢基地小组!
另外,张老您的文件,可以下载!但是,不知何故打不开!
