查看: 5469|回复: 3
TOPSTAR_N211.PM_BIOS(945PM_独立显卡 海尔W66).rar
发表于 2010-2-1 14:54:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
别人发的都不专业 W66 W66G W66N 全是混的,以下为专业的:
*        Topstar Notebook N211(PM) BIOS Change List       *
---------------------10-29-2007----------------------------
File:        106_12U_.11P                [Checksum =040C0CD4H]
System BIOS Version:1.06        Date: 10/29/2007
EC Version         :1.2U        Date: 06/03/2007
PCB :  N211PC-VERF
BIOS Change:
1. Change to release version from 106a
EC Change:
No change
File:        106a12U_.11P                [Checksum =03F56F62H]
System BIOS Version:1.06a        Date: 10/29/2007
PCB :  N211PC-VERF
BIOS Change:
1. Add TV support
EC Change:
No change
---------------------10-24-2007----------------------------
File:        105_12U_.11P                [Checksum =040bed49H]
System BIOS Version:1.05        Date: 10/24/2007
PCB :  N211PC-VERF
BIOS Change:
1. change BIOS ver from 105a
EC Change:
No change
---------------------10-23-2007----------------------------
File:        105a12U_.11P                [Checksum =040bfe1eH]
System BIOS Version:1.05a        Date: 10/23/2007
PCB :  N211PC-VERF
BIOS Change:
1. add support for dual chanel LVDS
EC Change:
No change
---------------------07-30-2007----------------------------
File:        104_12U_.11P                [Checksum =03F5664CH]
System BIOS Version:1.04        Date: 07/30/2007
PCB :  N211PC-VERF
BIOS Change:
1. add slp2.0 support
EC Change:
No change
---------------------07-18-2007----------------------------
File:        103_12U_.11P                [Checksum =0431FDACH]
System BIOS Version:1.03        Date: 07/18/2007
PCB :  N211PC-VERF
BIOS Change:
1.fix;bug S3 resume can't found 3945
2.fix;bug 2350 press 'pause' key when
EC Change:
No change
---------------------07-13-2007----------------------------
File:        102_12U_.11P                [Checksum =0431FDACH]
System BIOS Version:1.02        Date: 07/13/2007
PCB :  N211PC-VERF
BIOS Change:
1.fix:bug Driver CD can't find Modem
2.add support of Merom-L CPU
---------------------06-04-2007----------------------------
File:        101_12U_.11P                [Checksum =0431FDACH]
System BIOS Version:1.01        Date: 06/08/2007
PCB :  N211PC-VERF
BIOS Change:
1.Add support of realtek wireless lan
2.fix:bug blue screen when reboot
EC Change:
1.fix:bug Volume+/Volume- problem
---------------------05-14-2007----------------------------
File:        100_10U_.11P                [Checksum =0431FDACH]
System BIOS Version:1.00        Data: 05/14/2007
EC Version         :1.0U        Data: 05/14/2006
PCB :  N211PC-VERF
BIOS Change:
1.Change CRT to 100C for Tj85
2.Renew CMOS default time to current day
3.fix:bug can't into Newcard rom setup menu by press F4/Ctrl + s
4.Add new CPU micro code
EC Change:
1.Change read battery temperature using SMbus
---------------------04-26-2007----------------------------
File:        100G10UB.11P                [Checksum =0431FDACH]
System BIOS Version:1.00H        Data: 04/26/2007
EC Version         :1.0UB        Data: 04/11/2006
PCB :  N211PC-VERF
BIOS Change:
1.Try to fix reboot hang at post
2.Change SVID/SSID as company need
3.Turned off backlight with Fn+F7, can't turn on with Fn+F5,F6
EC Change:
No change
---------------------04-21-2007----------------------------
File:        100G10UB.11P                [Checksum =0434949FH]
System BIOS Version:1.00G        Data: 04/21/2007
PCB :  N211PC-VERF
BIOS Change:
1.fix:bug LCD backlight control
2.fix:bug with HDD password setting, can't resume from S3 in vista
EC Change:
No change
---------------------04-17-2007----------------------------
File:        100F10UB.11G                [Checksum =04340ECAH]
System BIOS Version:1.00F        Data: 04/19/2007
PCB :  N211PC-VERF
BIOS Change:
1.Not support USB wake up from S3/S4
2.fix:bug can't use media play/volume up/volume down button
EC Change:
No change
File:        100D10UB.11G                [Checksum =0433CA2FH]
System BIOS Version:1.00D        Data: 04/17/2007
PCB :  N211PC-VERF
BIOS Change:
Fix:bug Cardbus can't use in vista
Use new 883 verb table to support vista
EC Change:
No change
---------------------04-14-2007----------------------------
File:        100C10UB.11G                [Checksum =04338E77H]
System BIOS Version:1.00C        Data: 04/14/2007
PCB :  N211PC-VERF
BIOS Change:
1.Add support of new APP
2.Update DMI message
3.Fix:bug Card bus can't use
4.Add HDD password support for Vista
5.Add support of new CPU
6.Fix:bug can't use MiniPCIE card
7.Fix:bug Not MiniPci clock output
EC Change:
1. support new control center.
2. lock AC when BAT over vol.
---------------------04-08-2007----------------------------
File:100B10UA.11G                [Checksum =04252054H]
System BIOS Version:1.00B        Data: 04/05/2007
EC Version         :1.00B        Data: 04/08/2007
PCB :  N211C-VERF
BIOS Change:
1.Turn on the LCD
EC Change:
1.Can Power on
---------------------04-05-2007----------------------------
File:   100A10UA.11P            [Checksum =043E417CH]
System BIOS Version:1.00        Data: 04/05/2007
EC Version         :1.00        Data: 04/05/2007
PCB :  N211-VERF
BIOS Change:
1. Initial version for N211PCPM
EC Change:
1.Initial version for N211PC
589.61 KB, 下载次数: 192, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2014-8-25 09:33:38 | 只看该作者
想下载没分
发表于 2014-8-25 10:53:04 | 只看该作者
下载不下来,下载下来的是PHP页面
发表于 2017-5-11 07:58:32 | 只看该作者
收藏备用 。谢谢分享。
