查看: 8|回复: 0
[SSD硬盘]
三星840 PRO老盘突然不认,短接进ROM无反应,有必要上PC3000吗
发表于 16 分钟前 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
三星840 PRO(2014年的老盘了,MLC颗粒),说是正常关机后,第二天开机BIOS里死活认不到这块盘。
上电测了接口供电5V正常,但主控芯片(MDX)摸上去完全没有温度。
尝试了经典的短接ROM点位(板子上大概在闪存旁边那两个小孔),插上电脑的设备管理器依然毫无反应。
换了几个USB转接盒和直连台式机SATA口,都不认。
这种主控完全没温度的,是不是主控芯片内部供电短路彻底挂了?客户里面有重要的工作文档。如果不搞PC3000,用普通的编程器直接夹住旁边的Flash颗粒,能把数据导出来吗?这种故障一般恢复成功率多高
weibo.com/ttarticle/p/show?comment=1&id=2309405364407155949600
weibo.com/ttarticle/p/show?id=2309405364407155949600
weibo.com/ttarticle/p/show?id=2309405364407378247834
weibo.com/ttarticle/p/show?comment=1&id=2309405364407378247834
weibo.com/ttarticle/p/show?id=2309405364408552652859
weibo.com/ttarticle/p/show?comment=1&id=2309405364408552652859
weibo.com/ttarticle/p/show?id=2309405364408594595951
weibo.com/ttarticle/p/show?comment=1&id=2309405364408636801103
weibo.com/ttarticle/p/show?id=2309405364408636801103
weibo.com/ttarticle/p/show?comment=1&id=2309405364408678481956
weibo.com/ttarticle/p/show?id=2309405364408724619278
weibo.com/ttarticle/p/show?comment=1&id=2309405364408724619278
weibo.com/ttarticle/p/show?id=2309405364408762630341
weibo.com/ttarticle/p/show?id=2309405364412780511353
weibo.com/ttarticle/p/show?comment=1&id=2309405364412780511353
weibo.com/ttarticle/p/show?id=2309405364412822716456
weibo.com/ttarticle/p/show?comment=1&id=2309405364412822716456
weibo.com/ttarticle/p/show?id=2309405364412860203052
weibo.com/ttarticle/p/show?comment=1&id=2309405364412860203052
weibo.com/ttarticle/p/show?id=2309405364412902408213
weibo.com/ttarticle/p/show?id=2309405364412939894886
weibo.com/ttarticle/p/show?comment=1&id=2309405364412939894886
weibo.com/ttarticle/p/show?id=2309405364412981837830
weibo.com/ttarticle/p/show?comment=1&id=2309405364412981837830
weibo.com/ttarticle/p/show?id=2309405364413028237418
weibo.com/ttarticle/p/show?id=2309405364413069918210
weibo.com/ttarticle/p/show?comment=1&id=2309405364413069918210
weibo.com/ttarticle/p/show?id=2309405364413107929211
weibo.com/ttarticle/p/show?comment=1&id=2309405364413107929211
weibo.com/ttarticle/p/show?id=2309405364413145678021
weibo.com/ttarticle/p/show?comment=1&id=2309405364413187358818
weibo.com/ttarticle/p/show?id=2309405364413187358818
weibo.com/ttarticle/p/show?id=2309405364413229301840
weibo.com/ttarticle/p/show?comment=1&id=2309405364413308993615
weibo.com/ttarticle/p/show?comment=1&id=2309405364413346742352
weibo.com/ttarticle/p/show?id=2309405364413346742352
weibo.com/ttarticle/p/show?id=2309405364413388947511
weibo.com/ttarticle/p/show?id=2309405364413426434143
weibo.com/ttarticle/p/show?comment=1&id=2309405364413426434143
weibo.com/ttarticle/p/show?id=2309405364413468639238
weibo.com/ttarticle/p/show?id=2309405364413506388038
weibo.com/ttarticle/p/show?id=2309405364413544136924
weibo.com/ttarticle/p/show?id=2309405364413586079778
weibo.com/ttarticle/p/show?comment=1&id=2309405364413586079778
weibo.com/ttarticle/p/show?comment=1&id=2309405364413623566517
weibo.com/ttarticle/p/show?id=2309405364413623566517
weibo.com/ttarticle/p/show?id=2309405364413665771633
weibo.com/ttarticle/p/show?comment=1&id=2309405364413665771633
weibo.com/ttarticle/p/show?comment=1&id=2309405364413703520432
weibo.com/ttarticle/p/show?id=2309405364413745463320
weibo.com/ttarticle/p/show?comment=1&id=2309405364413745463320
weibo.com/ttarticle/p/show?id=2309405364413820698738
weibo.com/ttarticle/p/show?comment=1&id=2309405364413820698738
weibo.com/ttarticle/p/show?id=2309405364413862903858
weibo.com/ttarticle/p/show?id=2309405364413900652584
weibo.com/ttarticle/p/show?comment=1&id=2309405364413900652584
weibo.com/ttarticle/p/show?id=2309405364413942333472
weibo.com/ttarticle/p/show?comment=1&id=2309405364413980344389
weibo.com/ttarticle/p/show?id=2309405364413980344389
weibo.com/ttarticle/p/show?id=2309405364414017831222
weibo.com/ttarticle/p/show?comment=1&id=2309405364414017831222
weibo.com/ttarticle/p/show?comment=1&id=2309405364414060036149
weibo.com/ttarticle/p/show?comment=1&id=2309405364414097522811
weibo.com/ttarticle/p/show?id=2309405364414139465735
weibo.com/ttarticle/p/show?id=2309405364414177214586
weibo.com/ttarticle/p/show?comment=1&id=2309405364414177214586
weibo.com/ttarticle/p/show?comment=1&id=2309405364414219419656
weibo.com/ttarticle/p/show?id=2309405364414219419656
weibo.com/ttarticle/p/show?id=2309405364414256906338
weibo.com/ttarticle/p/show?comment=1&id=2309405364414256906338
weibo.com/ttarticle/p/show?id=2309405364414294655284
weibo.com/ttarticle/p/show?comment=1&id=2309405364371319816309
weibo.com/ttarticle/p/show?comment=1&id=2309405364403339395361
weibo.com/ttarticle/p/show?comment=1&id=2309405364371127140426
weibo.com/ttarticle/p/show?comment=1&id=2309405364370246336737
weibo.com/ttarticle/p/show?id=2309405364435035488260
weibo.com/ttarticle/p/show?comment=1&id=2309405364435157123098
weibo.com/ttarticle/p/show?comment=1&id=2309405364434993807444
weibo.com/ttarticle/p/show?id=2309405364435157123098
weibo.com/ttarticle/p/show?id=2309405364435115180123
weibo.com/ttarticle/p/show?comment=1&id=2309405364435073499261
weibo.com/ttarticle/p/show?comment=1&id=2309405364435035488260
weibo.com/ttarticle/p/show?comment=1&id=2309405364435115180123
weibo.com/ttarticle/p/show?id=2309405364435073499261
weibo.com/ttarticle/p/show?id=2309405364434993807444
weibo.com/ttarticle/p/show?id=2309405364435199328329
weibo.com/ttarticle/p/show?comment=1&id=2309405364436289847389
weibo.com/ttarticle/p/show?id=2309405364436289847389
weibo.com/ttarticle/p/show?comment=1&id=2309405364435199328329
weibo.com/ttarticle/p/show?id=2309405364436369539275
weibo.com/ttarticle/p/show?comment=1&id=2309405364436331790338
weibo.com/ttarticle/p/show?comment=1&id=2309405364436369539275
weibo.com/ttarticle/p/show?id=2309405364436331790338
weibo.com/ttarticle/p/show?id=2309405364436411220095
weibo.com/ttarticle/p/show?comment=1&id=2309405364436411220095
weibo.com/ttarticle/p/show?id=2309405364438030483604
weibo.com/ttarticle/p/show?comment=1&id=2309405364436457619514
weibo.com/ttarticle/p/show?id=2309405364436457619514
weibo.com/ttarticle/p/show?comment=1&id=2309405364438030483604
weibo.com/ttarticle/p/show?id=2309405364438072426523
weibo.com/ttarticle/p/show?comment=1&id=2309405364438072426523
weibo.com/ttarticle/p/show?comment=1&id=2309405364436499562565
weibo.com/ttarticle/p/show?id=2309405364436499562565
weibo.com/ttarticle/p/show?comment=1&id=2309405364438114369658
weibo.com/ttarticle/p/show?id=2309405364438114369658
weibo.com/ttarticle/p/show?id=2309405364438156312648
weibo.com/ttarticle/p/show?comment=1&id=2309405364438156312648
weibo.com/ttarticle/p/show?id=2309405364438198255643
weibo.com/ttarticle/p/show?comment=1&id=2309405364438198255643
weibo.com/ttarticle/p/show?comment=1&id=2309405364438244392971
weibo.com/ttarticle/p/show?id=2309405364438244392971
weibo.com/ttarticle/p/show?id=2309405364438374154376
weibo.com/ttarticle/p/show?comment=1&id=2309405364438374154376
weibo.com/ttarticle/p/show?id=2309405364438411903069
weibo.com/ttarticle/p/show?comment=1&id=2309405364438411903069
weibo.com/ttarticle/p/show?id=2309405364438454108221
weibo.com/ttarticle/p/show?id=2309405364438491594955
weibo.com/ttarticle/p/show?comment=1&id=2309405364438491594955
weibo.com/ttarticle/p/show?comment=1&id=2309405364438454108221
weibo.com/ttarticle/p/show?comment=1&id=2309405364438533800011
weibo.com/ttarticle/p/show?id=2309405364438533800011
weibo.com/ttarticle/p/show?id=2309405364438571548748
weibo.com/ttarticle/p/show?comment=1&id=2309405364439087185969
weibo.com/ttarticle/p/show?id=2309405364439087185969
weibo.com/ttarticle/p/show?comment=1&id=2309405364438571548748
weibo.com/ttarticle/p/show?id=2309405364439129391158
weibo.com/ttarticle/p/show?comment=1&id=2309405364439129391158
weibo.com/ttarticle/p/show?id=2309405364439171072089
weibo.com/ttarticle/p/show?comment=1&id=2309405364439171072089
weibo.com/ttarticle/p/show?id=2309405364439217471659
weibo.com/ttarticle/p/show?comment=1&id=2309405364439217471659
weibo.com/ttarticle/p/show?id=2309405364439263346776
weibo.com/ttarticle/p/show?comment=1&id=2309405364439263346776
weibo.com/ttarticle/p/show?comment=1&id=2309405364439305289747
weibo.com/ttarticle/p/show?id=2309405364439305289747
weibo.com/ttarticle/p/show?id=2309405364439347495048
weibo.com/ttarticle/p/show?comment=1&id=2309405364439397826562
weibo.com/ttarticle/p/show?comment=1&id=2309405364439347495048
weibo.com/ttarticle/p/show?id=2309405364439397826562
weibo.com/ttarticle/p/show?id=2309405364439439769643
weibo.com/ttarticle/p/show?comment=1&id=2309405364439439769643
weibo.com/ttarticle/p/show?id=2309405364439494033554
weibo.com/ttarticle/p/show?comment=1&id=2309405364439494033554
weibo.com/ttarticle/p/show?id=2309405364439540170894
weibo.com/ttarticle/p/show?comment=1&id=2309405364439540170894
weibo.com/ttarticle/p/show?id=2309405364439586308210
weibo.com/ttarticle/p/show?comment=1&id=2309405364439586308210
weibo.com/ttarticle/p/show?comment=1&id=2309405364439636901945
weibo.com/ttarticle/p/show?id=2309405364439682777204
weibo.com/ttarticle/p/show?comment=1&id=2309405364439682777204
weibo.com/ttarticle/p/show?id=2309405364439636901945
weibo.com/ttarticle/p/show?id=2309405364439728914514
weibo.com/ttarticle/p/show?comment=1&id=2309405364439728914514
weibo.com/ttarticle/p/show?id=2309405364439775051945
weibo.com/ttarticle/p/show?comment=1&id=2309405364439775051945
weibo.com/ttarticle/p/show?id=2309405364439821451286
weibo.com/ttarticle/p/show?comment=1&id=2309405364439821451286
weibo.com/ttarticle/p/show?id=2309405364439863394408
weibo.com/ttarticle/p/show?id=2309405364439905075336
weibo.com/ttarticle/p/show?comment=1&id=2309405364439863394408
weibo.com/ttarticle/p/show?comment=1&id=2309405364439905075336
weibo.com/ttarticle/p/show?id=2309405364439951212668
weibo.com/ttarticle/p/show?comment=1&id=2309405364439951212668
weibo.com/ttarticle/p/show?comment=1&id=2309405364439993155667
weibo.com/ttarticle/p/show?id=2309405364439993155667
weibo.com/ttarticle/p/show?id=2309405364440035098763
weibo.com/ttarticle/p/show?id=2309405364440077303985
weibo.com/ttarticle/p/show?comment=1&id=2309405364440077303985
weibo.com/ttarticle/p/show?comment=1&id=2309405364440035098763
weibo.com/ttarticle/p/show?id=2309405364440161190003
weibo.com/ttarticle/p/show?id=2309405364440118984779
weibo.com/ttarticle/p/show?comment=1&id=2309405364440118984779
weibo.com/ttarticle/p/show?comment=1&id=2309405364440161190003
weibo.com/ttarticle/p/show?id=2309405364440202870958
weibo.com/ttarticle/p/show?comment=1&id=2309405364440202870958
weibo.com/ttarticle/p/show?comment=1&id=2309405364440245076073
weibo.com/ttarticle/p/show?id=2309405364440332894223
weibo.com/ttarticle/p/show?comment=1&id=2309405364440291213338
weibo.com/ttarticle/p/show?id=2309405364440291213338
weibo.com/ttarticle/p/show?id=2309405364440245076073
weibo.com/ttarticle/p/show?comment=1&id=2309405364440332894223
weibo.com/ttarticle/p/show?comment=1&id=2309405364440375099395
weibo.com/ttarticle/p/show?id=2309405364440375099395
weibo.com/ttarticle/p/show?comment=1&id=2309405364440416780392
weibo.com/ttarticle/p/show?id=2309405364440416780392
weibo.com/ttarticle/p/show?id=2309405364440458985577
weibo.com/ttarticle/p/show?comment=1&id=2309405364440458985577
weibo.com/ttarticle/p/show?comment=1&id=2309405364440500928591
weibo.com/ttarticle/p/show?comment=1&id=2309405364440542609528
weibo.com/ttarticle/p/show?id=2309405364440542609528
weibo.com/ttarticle/p/show?id=2309405364440588746779
weibo.com/ttarticle/p/show?id=2309405364440500928591
weibo.com/ttarticle/p/show?comment=1&id=2309405364440634884136
weibo.com/ttarticle/p/show?comment=1&id=2309405364440588746779
weibo.com/ttarticle/p/show?id=2309405364440634884136
weibo.com/ttarticle/p/show?id=2309405364440677089353
weibo.com/ttarticle/p/show?comment=1&id=2309405364440677089353
weibo.com/ttarticle/p/show?id=2309405364440765169710
weibo.com/ttarticle/p/show?id=2309405364440723226671
weibo.com/ttarticle/p/show?comment=1&id=2309405364441008439444
weibo.com/ttarticle/p/show?comment=1&id=2309405364440723226671
weibo.com/ttarticle/p/show?comment=1&id=2309405364440765169710
weibo.com/ttarticle/p/show?id=2309405364441008439444
weibo.com/ttarticle/p/show?comment=1&id=2309405364440882348133
weibo.com/ttarticle/p/show?id=2309405364440882348133
