- 积分
- 119
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2026-9-12
- 精华
12V 5A的监控电源板,带载能力极差。空载测输出12.1V,接上一个12V小灯泡(大概2A),电压直接掉到 9.5V。如果再带个摄像头,直接断电保护。
我已经换了以下元件,还是不行:
主开关管(10N60)换了新的。
次级整流肖特基管(SB2040)换了。
输出端四个25V 470uF滤波电容全换了高频低阻的。
前级300V大电容测了,容量正常。
吸收回路(RCD)的二极管和瓷片电容(102/1kV)也都换了。
现在测主控芯片(OB2269)的VCC供电,带载时一直在9V-12V之间跳变,好像是在打嗝保护。请问大佬们,这是不是变压器内部匝间短路了?或者光耦(817)和431反馈环路有暗病
weibo.com/ttarticle/p/show?id=2309405363705998344350
weibo.com/ttarticle/p/show?comment=1&id=2309405363705998344350
weibo.com/ttarticle/p/show?id=2309405363706031898680
weibo.com/ttarticle/p/show?comment=1&id=2309405363706031898680
weibo.com/ttarticle/p/show?id=2309405363706061521033
weibo.com/ttarticle/p/show?comment=1&id=2309405363706061521033
weibo.com/ttarticle/p/show?id=2309405363706095075336
weibo.com/ttarticle/p/show?comment=1&id=2309405363706095075336
weibo.com/ttarticle/p/show?id=2309405363706124173342
weibo.com/ttarticle/p/show?comment=1&id=2309405363706124173342
weibo.com/ttarticle/p/show?id=2309405363706153795832
weibo.com/ttarticle/p/show?comment=1&id=2309405363706153795832
weibo.com/ttarticle/p/show?id=2309405363706187350029
weibo.com/ttarticle/p/show?comment=1&id=2309405363706187350029
weibo.com/ttarticle/p/show?id=2309405363706216710230
weibo.com/ttarticle/p/show?comment=1&id=2309405363706216710230
weibo.com/ttarticle/p/show?id=2309405363706245808258
weibo.com/ttarticle/p/show?comment=1&id=2309405363706245808258
weibo.com/ttarticle/p/show?id=2309405363706279362590
weibo.com/ttarticle/p/show?comment=1&id=2309405363706279362590
weibo.com/ttarticle/p/show?id=2309405363706338083070
weibo.com/ttarticle/p/show?comment=1&id=2309405363706338083070
weibo.com/ttarticle/p/show?id=2309405363706371637280
weibo.com/ttarticle/p/show?comment=1&id=2309405363706371637280
weibo.com/ttarticle/p/show?id=2309405363706400997438
weibo.com/ttarticle/p/show?comment=1&id=2309405363706400997438
weibo.com/ttarticle/p/show?id=2309405363706430619780
weibo.com/ttarticle/p/show?comment=1&id=2309405363706430619780
weibo.com/ttarticle/p/show?id=2309405363706464174242
weibo.com/ttarticle/p/show?comment=1&id=2309405363706464174242
weibo.com/ttarticle/p/show?id=2309405363706493534257
weibo.com/ttarticle/p/show?comment=1&id=2309405363706493534257
weibo.com/ttarticle/p/show?id=2309405363706526826559
weibo.com/ttarticle/p/show?comment=1&id=2309405363706526826559
weibo.com/ttarticle/p/show?id=2309405363706556448920
weibo.com/ttarticle/p/show?comment=1&id=2309405363706556448920
weibo.com/ttarticle/p/show?id=2309405363706589741091
weibo.com/ttarticle/p/show?comment=1&id=2309405363706589741091
weibo.com/ttarticle/p/show?id=2309405363706619363571
weibo.com/ttarticle/p/show?comment=1&id=2309405363706619363571
weibo.com/ttarticle/p/show?id=2309405363706652655698
weibo.com/ttarticle/p/show?comment=1&id=2309405363706652655698
weibo.com/ttarticle/p/show?id=2309405363706682015894
weibo.com/ttarticle/p/show?comment=1&id=2309405363706682015894
weibo.com/ttarticle/p/show?id=2309405363706720026763
weibo.com/ttarticle/p/show?comment=1&id=2309405363706720026763
weibo.com/ttarticle/p/show?id=2309405363706749386856
weibo.com/ttarticle/p/show?comment=1&id=2309405363706749386856
weibo.com/ttarticle/p/show?id=2309405363706782941300
weibo.com/ttarticle/p/show?comment=1&id=2309405363706782941300
weibo.com/ttarticle/p/show?id=2309405363706812039355
weibo.com/ttarticle/p/show?comment=1&id=2309405363706812039355
weibo.com/ttarticle/p/show?id=2309405363706845593650
weibo.com/ttarticle/p/show?comment=1&id=2309405363706845593650
weibo.com/ttarticle/p/show?id=2309405363706879148038
weibo.com/ttarticle/p/show?comment=1&id=2309405363706879148038
weibo.com/ttarticle/p/show?id=2309405363706908770356
weibo.com/ttarticle/p/show?comment=1&id=2309405363706908770356
weibo.com/ttarticle/p/show?id=2309405363706937868450
weibo.com/ttarticle/p/show?comment=1&id=2309405363706937868450
weibo.com/ttarticle/p/show?id=2309405363706971684999
weibo.com/ttarticle/p/show?comment=1&id=2309405363706971684999
weibo.com/ttarticle/p/show?id=2309405363707001045145
weibo.com/ttarticle/p/show?comment=1&id=2309405363707001045145
weibo.com/ttarticle/p/show?id=2309405363707034599493
weibo.com/ttarticle/p/show?comment=1&id=2309405363707034599493
weibo.com/ttarticle/p/show?id=2309405363707063959729
weibo.com/ttarticle/p/show?comment=1&id=2309405363707063959729
weibo.com/ttarticle/p/show?id=2309405363707093319828
weibo.com/ttarticle/p/show?comment=1&id=2309405363707093319828
weibo.com/ttarticle/p/show?id=2309405363707126612073
weibo.com/ttarticle/p/show?comment=1&id=2309405363707126612073
weibo.com/ttarticle/p/show?id=2309405363707156234456
weibo.com/ttarticle/p/show?comment=1&id=2309405363707156234456
weibo.com/ttarticle/p/show?id=2309405363707189788717
weibo.com/ttarticle/p/show?comment=1&id=2309405363707189788717
weibo.com/ttarticle/p/show?id=2309405363707269480493
weibo.com/ttarticle/p/show?comment=1&id=2309405363707269480493
weibo.com/ttarticle/p/show?id=2309405363707307229247
weibo.com/ttarticle/p/show?comment=1&id=2309405363707307229247
weibo.com/ttarticle/p/show?id=2309405363707349172261
weibo.com/ttarticle/p/show?comment=1&id=2309405363707349172261
weibo.com/ttarticle/p/show?id=2309405363707382726781
weibo.com/ttarticle/p/show?comment=1&id=2309405363707382726781
weibo.com/ttarticle/p/show?id=2309405363707420213261
weibo.com/ttarticle/p/show?comment=1&id=2309405363707420213261
weibo.com/ttarticle/p/show?id=2309405363707457962047
weibo.com/ttarticle/p/show?comment=1&id=2309405363707457962047
weibo.com/ttarticle/p/show?id=2309405363707491778644
weibo.com/ttarticle/p/show?comment=1&id=2309405363707491778644
weibo.com/ttarticle/p/show?id=2309405363707525333156
weibo.com/ttarticle/p/show?comment=1&id=2309405363707525333156
weibo.com/ttarticle/p/show?id=2309405363707558887570
weibo.com/ttarticle/p/show?comment=1&id=2309405363707558887570
weibo.com/ttarticle/p/show?id=2309405363707592179779
weibo.com/ttarticle/p/show?comment=1&id=2309405363707592179779
weibo.com/ttarticle/p/show?id=2309405363707630190597
weibo.com/ttarticle/p/show?comment=1&id=2309405363707630190597
weibo.com/ttarticle/p/show?id=2309405363707663745042
weibo.com/ttarticle/p/show?comment=1&id=2309405363707663745042
weibo.com/ttarticle/p/show?id=2309405363707697299475
weibo.com/ttarticle/p/show?comment=1&id=2309405363707697299475
weibo.com/ttarticle/p/show?id=2309405363707852488725
weibo.com/ttarticle/p/show?comment=1&id=2309405363707852488725
weibo.com/ttarticle/p/show?id=2309405363707881848990
weibo.com/ttarticle/p/show?comment=1&id=2309405363707881848990
weibo.com/ttarticle/p/show?id=2309405363707915141131
weibo.com/ttarticle/p/show?comment=1&id=2309405363707915141131
weibo.com/ttarticle/p/show?id=2309405363707944763587
weibo.com/ttarticle/p/show?comment=1&id=2309405363707944763587
weibo.com/ttarticle/p/show?id=2309405363707978317859
weibo.com/ttarticle/p/show?comment=1&id=2309405363707978317859
weibo.com/ttarticle/p/show?id=2309405363708007415907
weibo.com/ttarticle/p/show?comment=1&id=2309405363708007415907
weibo.com/ttarticle/p/show?id=2309405363708070330485
weibo.com/ttarticle/p/show?comment=1&id=2309405363708070330485
weibo.com/ttarticle/p/show?id=2309405363708103884811
weibo.com/ttarticle/p/show?comment=1&id=2309405363708103884811
weibo.com/ttarticle/p/show?id=2309405363708137439293
weibo.com/ttarticle/p/show?comment=1&id=2309405363708137439293
weibo.com/ttarticle/p/show?id=2309405363708166799470
weibo.com/ttarticle/p/show?comment=1&id=2309405363708166799470
weibo.com/ttarticle/p/show?id=2309405363708200353900
weibo.com/ttarticle/p/show?comment=1&id=2309405363708200353900
weibo.com/ttarticle/p/show?id=2309405363708234170395
weibo.com/ttarticle/p/show?comment=1&id=2309405363708234170395
weibo.com/ttarticle/p/show?id=2309405363708296822888
weibo.com/ttarticle/p/show?comment=1&id=2309405363708296822888
weibo.com/ttarticle/p/show?id=2309405363708326445259
weibo.com/ttarticle/p/show?comment=1&id=2309405363708326445259
weibo.com/ttarticle/p/show?id=2309405363708359737381
weibo.com/ttarticle/p/show?comment=1&id=2309405363708359737381
weibo.com/ttarticle/p/show?id=2309405363708389097599
weibo.com/ttarticle/p/show?comment=1&id=2309405363708389097599
weibo.com/ttarticle/p/show?id=2309405363708418457644
weibo.com/ttarticle/p/show?comment=1&id=2309405363708418457644
weibo.com/ttarticle/p/show?id=2309405363708452274189
weibo.com/ttarticle/p/show?comment=1&id=2309405363708452274189
weibo.com/ttarticle/p/show?id=2309405363708544286725
weibo.com/ttarticle/p/show?comment=1&id=2309405363708544286725
weibo.com/ttarticle/p/show?id=2309405363708573909129
weibo.com/ttarticle/p/show?comment=1&id=2309405363708573909129
weibo.com/ttarticle/p/show?id=2309405363708607201292
weibo.com/ttarticle/p/show?comment=1&id=2309405363708607201292
weibo.com/ttarticle/p/show?id=2309405363708641017973
weibo.com/ttarticle/p/show?comment=1&id=2309405363708641017973
weibo.com/ttarticle/p/show?id=2309405363708670378130
weibo.com/ttarticle/p/show?comment=1&id=2309405363708670378130
weibo.com/ttarticle/p/show?id=2309405363708745875676
weibo.com/ttarticle/p/show?comment=1&id=2309405363708745875676
weibo.com/ttarticle/p/show?id=2309405363708779429926
weibo.com/ttarticle/p/show?comment=1&id=2309405363708779429926
weibo.com/ttarticle/p/show?id=2309405363708808790142
weibo.com/ttarticle/p/show?comment=1&id=2309405363708808790142
weibo.com/ttarticle/p/show?id=2309405363708837888190
weibo.com/ttarticle/p/show?comment=1&id=2309405363708837888190
weibo.com/ttarticle/p/show?id=2309405363708871442536
weibo.com/ttarticle/p/show?comment=1&id=2309405363708871442536
weibo.com/ttarticle/p/show?id=2309405363708901064855
weibo.com/ttarticle/p/show?comment=1&id=2309405363708901064855
weibo.com/ttarticle/p/show?id=2309405363708934357002
weibo.com/ttarticle/p/show?comment=1&id=2309405363708934357002
weibo.com/ttarticle/p/show?id=2309405363708963979395
weibo.com/ttarticle/p/show?comment=1&id=2309405363708963979395
weibo.com/ttarticle/p/show?id=2309405363708997533763
weibo.com/ttarticle/p/show?comment=1&id=2309405363708997533763
weibo.com/ttarticle/p/show?id=2309405363709026894066
weibo.com/ttarticle/p/show?comment=1&id=2309405363709026894066
weibo.com/ttarticle/p/show?id=2309405363709060448374
weibo.com/ttarticle/p/show?comment=1&id=2309405363709060448374
weibo.com/ttarticle/p/show?id=2309405363709089808570
weibo.com/ttarticle/p/show?comment=1&id=2309405363709089808570
weibo.com/ttarticle/p/show?id=2309405363709123362924
weibo.com/ttarticle/p/show?comment=1&id=2309405363709123362924
weibo.com/ttarticle/p/show?id=2309405363709186015348
weibo.com/ttarticle/p/show?comment=1&id=2309405363709186015348
weibo.com/ttarticle/p/show?id=2309405363709219831955
weibo.com/ttarticle/p/show?comment=1&id=2309405363709219831955
weibo.com/ttarticle/p/show?id=2309405363709253124158
weibo.com/ttarticle/p/show?comment=1&id=2309405363709253124158
weibo.com/ttarticle/p/show?id=2309405363709286940697
weibo.com/ttarticle/p/show?comment=1&id=2309405363709286940697
weibo.com/ttarticle/p/show?id=2309405363709316300935
weibo.com/ttarticle/p/show?comment=1&id=2309405363709316300935
weibo.com/ttarticle/p/show?id=2309405363709349593091
weibo.com/ttarticle/p/show?comment=1&id=2309405363709349593091
weibo.com/ttarticle/p/show?id=2309405363709378953325
weibo.com/ttarticle/p/show?comment=1&id=2309405363709378953325
weibo.com/ttarticle/p/show?id=2309405363709412769794
weibo.com/ttarticle/p/show?comment=1&id=2309405363709412769794
weibo.com/ttarticle/p/show?id=2309405363709441867857
weibo.com/ttarticle/p/show?comment=1&id=2309405363709441867857
weibo.com/ttarticle/p/show?id=2309405363709475684358
weibo.com/ttarticle/p/show?comment=1&id=2309405363709475684358
weibo.com/ttarticle/p/show?id=2309405363709508976686
weibo.com/ttarticle/p/show?comment=1&id=2309405363709508976686
weibo.com/ttarticle/p/show?id=2309405363709542793317
weibo.com/ttarticle/p/show?comment=1&id=2309405363709542793317
weibo.com/ttarticle/p/show?id=2309405363709580279828
weibo.com/ttarticle/p/show?comment=1&id=2309405363709580279828
weibo.com/ttarticle/p/show?id=2309405363709614096537
weibo.com/ttarticle/p/show?comment=1&id=2309405363709614096537
weibo.com/ttarticle/p/show?id=2309405363709651845171
weibo.com/ttarticle/p/show?comment=1&id=2309405363709651845171
weibo.com/ttarticle/p/show?id=2309405363709685399644
weibo.com/ttarticle/p/show?comment=1&id=2309405363709685399644
weibo.com/ttarticle/p/show?id=2309405363709718954144
weibo.com/ttarticle/p/show?comment=1&id=2309405363709718954144
weibo.com/ttarticle/p/show?id=2309405363709752246312
weibo.com/ttarticle/p/show?comment=1&id=2309405363709752246312
weibo.com/ttarticle/p/show?id=2309405363709789995031
weibo.com/ttarticle/p/show?comment=1&id=2309405363709789995031
weibo.com/ttarticle/p/show?id=2309405363709819355270
weibo.com/ttarticle/p/show?comment=1&id=2309405363709819355270
weibo.com/ttarticle/p/show?id=2309405363709857366145
weibo.com/ttarticle/p/show?comment=1&id=2309405363709857366145
weibo.com/ttarticle/p/show?id=2309405363709890658345
weibo.com/ttarticle/p/show?comment=1&id=2309405363709890658345
weibo.com/ttarticle/p/show?id=2309405363709924212868
weibo.com/ttarticle/p/show?comment=1&id=2309405363709924212868
weibo.com/ttarticle/p/show?id=2309405363709958029361
weibo.com/ttarticle/p/show?comment=1&id=2309405363709958029361
weibo.com/ttarticle/p/show?id=2309405363709995515927
weibo.com/ttarticle/p/show?comment=1&id=2309405363709995515927
