查看: 22|回复: 0
[其他]
惠普M281fdw报错50.2,换二手拆机定影后问题依旧,是主板还是高压板问题
发表于 半小时前 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东深圳
惠普M281fdw彩色激光一体机。客户描述前一天晚上关机还正常,第二天开机就报错50.2(定影预热故障),机器预热有轻微的转动声,但没转几秒直接报错,无法工作。
先从最简单的入手,拆下后盖测量定影灯管两端阻值,正常(约几欧姆)。目测热敏电阻和恒温器没有明显烧焦或变形。插回主板的定影排线,开机依然报50.2。
同行店里刚好有一台废旧机器,拆了一个确认好的二手拆机定影组件换上,满心欢喜以为能秒杀,结果开机还是报50.2。这个时候心里有点发毛了。
重新插拔主板和电源板连接定影的所有排线,用万用表测量定影接口的供电电压,发现开机瞬间有24V跳变,随后很快掉为0V。怀疑是不是电源板带载能力差,或者是主板检测到异常切断了供电。
惠普M281fdw换了定影还报50.2,是不是电源板给定影供电的24V出问题了?怎么用万用表量主板定影接口的输出电压或者反馈信号
weibo.com/ttarticle/p/show?id=2309405354366218928247
weibo.com/ttarticle/p/show?comment=1&id=2309405354366218928247
weibo.com/ttarticle/p/show?id=2309405354366369660994
weibo.com/ttarticle/p/show?comment=1&id=2309405354366369660994
weibo.com/ttarticle/p/show?id=2309405354366533239022
weibo.com/ttarticle/p/show?comment=1&id=2309405354366533239022
weibo.com/ttarticle/p/show?id=2309405354366675845150
weibo.com/ttarticle/p/show?comment=1&id=2309405354366675845150
weibo.com/ttarticle/p/show?id=2309405354366818713705
weibo.com/ttarticle/p/show?comment=1&id=2309405354366818713705
weibo.com/ttarticle/p/show?id=2309405354366965252167
weibo.com/ttarticle/p/show?comment=1&id=2309405354366965252167
weibo.com/ttarticle/p/show?id=2309405354368391315541
weibo.com/ttarticle/p/show?comment=1&id=2309405354368391315541
weibo.com/ttarticle/p/show?id=2309405354368655556653
weibo.com/ttarticle/p/show?comment=1&id=2309405354368655556653
weibo.com/ttarticle/p/show?id=2309405354368923992197
weibo.com/ttarticle/p/show?comment=1&id=2309405354368923992197
weibo.com/ttarticle/p/show?id=2309405354369201078487
weibo.com/ttarticle/p/show?comment=1&id=2309405354369201078487
weibo.com/ttarticle/p/show?id=2309405354369486291072
weibo.com/ttarticle/p/show?comment=1&id=2309405354369486291072
weibo.com/ttarticle/p/show?id=2309405354369767047184
weibo.com/ttarticle/p/show?comment=1&id=2309405354369767047184
weibo.com/ttarticle/p/show?id=2309405354370039939160
weibo.com/ttarticle/p/show?comment=1&id=2309405354370039939160
weibo.com/ttarticle/p/show?id=2309405354370308374652
weibo.com/ttarticle/p/show?comment=1&id=2309405354370308374652
weibo.com/ttarticle/p/show?id=2309405354370576548034
weibo.com/ttarticle/p/show?comment=1&id=2309405354370576548034
weibo.com/ttarticle/p/show?id=2309405354370845245586
weibo.com/ttarticle/p/show?comment=1&id=2309405354370845245586
weibo.com/ttarticle/p/show?id=2309405354371113680965
weibo.com/ttarticle/p/show?comment=1&id=2309405354371113680965
weibo.com/ttarticle/p/show?id=2309405354371541237769
weibo.com/ttarticle/p/show?comment=1&id=2309405354371541237769
weibo.com/ttarticle/p/show?id=2309405354371805479078
weibo.com/ttarticle/p/show?comment=1&id=2309405354371805479078
weibo.com/ttarticle/p/show?id=2309405354372069720181
weibo.com/ttarticle/p/show?comment=1&id=2309405354372069720181
weibo.com/ttarticle/p/show?id=2309405354372334223492
weibo.com/ttarticle/p/show?comment=1&id=2309405354372334223492
weibo.com/ttarticle/p/show?id=2309405354372598202614
weibo.com/ttarticle/p/show?comment=1&id=2309405354372598202614
weibo.com/ttarticle/p/show?id=2309405354372862705774
weibo.com/ttarticle/p/show?comment=1&id=2309405354372862705774
weibo.com/ttarticle/p/show?id=2309405354373126946932
weibo.com/ttarticle/p/show?comment=1&id=2309405354373126946932
weibo.com/ttarticle/p/show?id=2309405354373420286012
weibo.com/ttarticle/p/show?comment=1&id=2309405354373420286012
weibo.com/ttarticle/p/show?id=2309405354373684527189
weibo.com/ttarticle/p/show?comment=1&id=2309405354373684527189
weibo.com/ttarticle/p/show?id=2309405354373952962582
weibo.com/ttarticle/p/show?comment=1&id=2309405354373952962582
weibo.com/ttarticle/p/show?id=2309405354374225592322
weibo.com/ttarticle/p/show?comment=1&id=2309405354374225592322
weibo.com/ttarticle/p/show?id=2309405354374490095729
weibo.com/ttarticle/p/show?comment=1&id=2309405354374490095729
weibo.com/ttarticle/p/show?id=2309405354374749880539
weibo.com/ttarticle/p/show?comment=1&id=2309405354374749880539
weibo.com/ttarticle/p/show?id=2309405354392575934622
weibo.com/ttarticle/p/show?comment=1&id=2309405354392575934622
weibo.com/ttarticle/p/show?id=2309405354392714346606
weibo.com/ttarticle/p/show?comment=1&id=2309405354392714346606
weibo.com/ttarticle/p/show?id=2309405354392861147190
weibo.com/ttarticle/p/show?comment=1&id=2309405354392861147190
weibo.com/ttarticle/p/show?id=2309405354392995365152
weibo.com/ttarticle/p/show?comment=1&id=2309405354392995365152
weibo.com/ttarticle/p/show?id=2309405354393133514906
weibo.com/ttarticle/p/show?comment=1&id=2309405354393133514906
weibo.com/ttarticle/p/show?id=2309405354393267994910
weibo.com/ttarticle/p/show?comment=1&id=2309405354393267994910
weibo.com/ttarticle/p/show?id=2309405354393406406778
weibo.com/ttarticle/p/show?comment=1&id=2309405354393406406778
weibo.com/ttarticle/p/show?id=2309405354393549013016
weibo.com/ttarticle/p/show?comment=1&id=2309405354393549013016
weibo.com/ttarticle/p/show?id=2309405354393699745994
weibo.com/ttarticle/p/show?comment=1&id=2309405354393699745994
weibo.com/ttarticle/p/show?id=2309405354393850740872
weibo.com/ttarticle/p/show?comment=1&id=2309405354393850740872
weibo.com/ttarticle/p/show?id=2309405354393989415111
weibo.com/ttarticle/p/show?comment=1&id=2309405354393989415111
weibo.com/ttarticle/p/show?id=2309405354394127826976
weibo.com/ttarticle/p/show?comment=1&id=2309405354394127826976
weibo.com/ttarticle/p/show?id=2309405354394262044826
weibo.com/ttarticle/p/show?comment=1&id=2309405354394262044826
weibo.com/ttarticle/p/show?id=2309405354394400456940
weibo.com/ttarticle/p/show?comment=1&id=2309405354394400456940
weibo.com/ttarticle/p/show?id=2309405354394538606621
weibo.com/ttarticle/p/show?comment=1&id=2309405354394538606621
weibo.com/ttarticle/p/show?id=2309405354394672824505
weibo.com/ttarticle/p/show?comment=1&id=2309405354394672824505
weibo.com/ttarticle/p/show?id=2309405354394807042499
weibo.com/ttarticle/p/show?comment=1&id=2309405354394807042499
weibo.com/ttarticle/p/show?id=2309405354394945454249
weibo.com/ttarticle/p/show?comment=1&id=2309405354394945454249
weibo.com/ttarticle/p/show?id=2309405354395084128289
weibo.com/ttarticle/p/show?comment=1&id=2309405354395084128289
weibo.com/ttarticle/p/show?id=2309405354395239055593
weibo.com/ttarticle/p/show?comment=1&id=2309405354395239055593
weibo.com/ttarticle/p/show?id=2309405354395377467506
weibo.com/ttarticle/p/show?comment=1&id=2309405354395377467506
weibo.com/ttarticle/p/show?id=2309405354395511947395
weibo.com/ttarticle/p/show?comment=1&id=2309405354395511947395
weibo.com/ttarticle/p/show?id=2309405354395650359475
weibo.com/ttarticle/p/show?comment=1&id=2309405354395650359475
weibo.com/ttarticle/p/show?id=2309405354395788509552
weibo.com/ttarticle/p/show?comment=1&id=2309405354395788509552
weibo.com/ttarticle/p/show?id=2309405354395931378029
weibo.com/ttarticle/p/show?comment=1&id=2309405354395931378029
weibo.com/ttarticle/p/show?id=2309405354396073984273
weibo.com/ttarticle/p/show?comment=1&id=2309405354396073984273
weibo.com/ttarticle/p/show?id=2309405354396216590380
weibo.com/ttarticle/p/show?comment=1&id=2309405354396216590380
weibo.com/ttarticle/p/show?id=2309405354396367585469
weibo.com/ttarticle/p/show?comment=1&id=2309405354396367585469
weibo.com/ttarticle/p/show?id=2309405354396514385998
weibo.com/ttarticle/p/show?comment=1&id=2309405354396514385998
weibo.com/ttarticle/p/show?id=2309405354398368268293
weibo.com/ttarticle/p/show?comment=1&id=2309405354398368268293
weibo.com/ttarticle/p/show?id=2309405354398586372170
weibo.com/ttarticle/p/show?comment=1&id=2309405354398586372170
weibo.com/ttarticle/p/show?id=2309405354398812602402
weibo.com/ttarticle/p/show?comment=1&id=2309405354398812602402
weibo.com/ttarticle/p/show?id=2309405354399026774178
weibo.com/ttarticle/p/show?comment=1&id=2309405354399026774178
weibo.com/ttarticle/p/show?id=2309405354399244615691
weibo.com/ttarticle/p/show?comment=1&id=2309405354399244615691
weibo.com/ttarticle/p/show?id=2309405354399446204445
weibo.com/ttarticle/p/show?comment=1&id=2309405354399446204445
weibo.com/ttarticle/p/show?id=2309405354399643337133
weibo.com/ttarticle/p/show?comment=1&id=2309405354399643337133
weibo.com/ttarticle/p/show?id=2309405354399861440646
weibo.com/ttarticle/p/show?comment=1&id=2309405354399861440646
weibo.com/ttarticle/p/show?id=2309405354400096321795
weibo.com/ttarticle/p/show?comment=1&id=2309405354400096321795
weibo.com/ttarticle/p/show?id=2309405354400398311674
weibo.com/ttarticle/p/show?comment=1&id=2309405354400398311674
weibo.com/ttarticle/p/show?id=2309405354400599638078
weibo.com/ttarticle/p/show?comment=1&id=2309405354400599638078
weibo.com/ttarticle/p/show?id=2309405354400796508382
weibo.com/ttarticle/p/show?comment=1&id=2309405354400796508382
weibo.com/ttarticle/p/show?id=2309405354400993902932
weibo.com/ttarticle/p/show?comment=1&id=2309405354400993902932
weibo.com/ttarticle/p/show?id=2309405354401194967114
weibo.com/ttarticle/p/show?comment=1&id=2309405354401194967114
weibo.com/ttarticle/p/show?id=2309405354401392361693
weibo.com/ttarticle/p/show?comment=1&id=2309405354401392361693
weibo.com/ttarticle/p/show?id=2309405354401593688078
weibo.com/ttarticle/p/show?comment=1&id=2309405354401593688078
weibo.com/ttarticle/p/show?id=2309405354401790820470
weibo.com/ttarticle/p/show?comment=1&id=2309405354401790820470
weibo.com/ttarticle/p/show?id=2309405354401996341271
weibo.com/ttarticle/p/show?comment=1&id=2309405354401996341271
weibo.com/ttarticle/p/show?id=2309405354402218639471
weibo.com/ttarticle/p/show?comment=1&id=2309405354402218639471
weibo.com/ttarticle/p/show?id=2309405354402424160610
weibo.com/ttarticle/p/show?comment=1&id=2309405354402424160610
weibo.com/ttarticle/p/show?id=2309405354402625224741
weibo.com/ttarticle/p/show?comment=1&id=2309405354402625224741
weibo.com/ttarticle/p/show?id=2309405354402822619337
weibo.com/ttarticle/p/show?comment=1&id=2309405354402822619337
weibo.com/ttarticle/p/show?id=2309405354403023683739
weibo.com/ttarticle/p/show?comment=1&id=2309405354403023683739
weibo.com/ttarticle/p/show?id=2309405354403225272397
weibo.com/ttarticle/p/show?comment=1&id=2309405354403225272397
weibo.com/ttarticle/p/show?id=2309405354403422142891
weibo.com/ttarticle/p/show?comment=1&id=2309405354403422142891
weibo.com/ttarticle/p/show?id=2309405354403623731346
weibo.com/ttarticle/p/show?comment=1&id=2309405354403623731346
weibo.com/ttarticle/p/show?id=2309405354403820601415
weibo.com/ttarticle/p/show?comment=1&id=2309405354403820601415
weibo.com/ttarticle/p/show?id=2309405354404026122307
weibo.com/ttarticle/p/show?comment=1&id=2309405354404026122307
weibo.com/ttarticle/p/show?id=2309405354404223516731
weibo.com/ttarticle/p/show?comment=1&id=2309405354404223516731
weibo.com/ttarticle/p/show?id=2309405354404429037631
weibo.com/ttarticle/p/show?comment=1&id=2309405354404429037631
