查看: 873|回复: 9
求hp zhan 66 pro g1 mt bios 论坛高手谁会拼接?
发表于 2024-3-16 12:00:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
刷黑了~~
附上刷黑前拷的bios
afuwinhp66.rom (10 MB, 下载次数: 0)
发表于 2024-3-16 16:32:55 来自迅维网APP | 只看该作者 �
拼接????论坛上的高手,大部分就是你口中的J商,都是吃这口饭的,你觉得会告诉你吗?不过这论坛有很多资料是真的,自己慢慢学吧。
拼好了~~~~~~~~~~~~~~~  详情 回复 发表于 2024-3-19 18:06
发表于 2024-3-19 18:06:39 | 只看该作者 �
chenyang31 发表于 2024-3-16 16:32
拼接????论坛上的高手,大部分就是你口中的J商,都是吃这口饭的,你觉得会告诉你吗?不过这论坛有很多 ...
拼好了~~~~~~~~~~~~~~~
补充内容 (2024-3-20 06:56):
下面公开回复方法~~
发表于 2024-3-20 06:52:16 | 只看该作者 �
2024-03-19 14:09:58  EFI HP BIOS Update 3.9.4.1 Started
2024-03-19 14:09:58  [L]> System ID: 8526
2024-03-19 14:09:58  Failed Loading EFI_HP_BIOS_IMAGE_INTERFACE_PROTOCOL2_GUID(Not Found)
2024-03-19 14:09:58  HP BIOS Image Interface Protocol Version 2.0
2024-03-19 14:09:59  [L]> No Battery Control Protocol is present; Try KBC.
2024-03-19 14:09:59  [L]> Found 1 Absolute Pointer Protocol(s)
2024-03-19 14:09:59  [L]> 0 UART device path node found.
2024-03-19 14:09:59  All Required Protocols Located
2024-03-19 14:09:59  HpBiosUpdate.Mode = 4
2024-03-19 14:09:59  WRITE_BB = 0
2024-03-19 14:09:59  Current Directory = \HP\BIOSUpdate\
2024-03-19 14:09:59  [L]> System ID: 8526
2024-03-19 14:09:59  SMBIOS Init Success
2024-03-19 14:09:59  SystemFamily = 4
2024-03-19 14:09:59  [L]> PlatformLang reported as en-US.
2024-03-19 14:09:59  [L]> Language Selected is currently (eng).
2024-03-19 14:09:59  Starting BIOS Update Process
2024-03-19 14:09:59  Setting BIOS Update Token
2024-03-19 14:09:59  Getting BIOS Detail Information
2024-03-19 14:09:59  IsBiosSixDigits = 0
2024-03-19 14:09:59  BIOS Returned BiosID '08526'
2024-03-19 14:09:59  QueryImageDetail: 4K Block Size detected.
2024-03-19 14:09:59  Skip Addresses:
2024-03-19 14:09:59  Entry 0: Address 0x0: Size: 0x600000
2024-03-19 14:09:59  Entry 1: Address 0x600000: Size: 0x10000
2024-03-19 14:09:59  Entry 2: Address 0x610000: Size: 0x30000
2024-03-19 14:09:59  Entry 3: Address 0x640000: Size: 0x30000
2024-03-19 14:09:59  Entry 4: Address 0x670000: Size: 0x1000
2024-03-19 14:09:59  Entry 5: Address 0x671000: Size: 0x1000
2024-03-19 14:09:59  Entry 6: Address 0x672000: Size: 0x2000
2024-03-19 14:09:59  Entry 7: Address 0xF80000: Size: 0x80000
2024-03-19 14:09:59  Loading BIOS Image
2024-03-19 14:09:59  File name constructed: HP\BIOS\Current\08526.bin
2024-03-19 14:09:59  Reading New BIOS Image HP\BIOS\Current\08526.bin
2024-03-19 14:09:59  Getting BIOS version from file image
2024-03-19 14:09:59  Bios Version = F.36
2024-03-19 14:09:59  Verifying AC or Battery Power Status
2024-03-19 14:09:59  NeedACScreen function pointer is NULL, assume AC mode
2024-03-19 14:09:59  Verifying Binary match
2024-03-19 14:09:59  Loading Signature File
2024-03-19 14:10:00  Loading Password File if required
2024-03-19 14:10:00  BIOS Password not required.
2024-03-19 14:10:00  Writing BIOS Image
2024-03-19 14:11:26  Verifying Written BIOS Image
2024-03-19 14:11:26  VerifyImage: 4K Block Size detected.
2024-03-19 14:11:26  Skipping Verification Block 0 Address 0x0000000000000000 Size 0x0000000000600000
2024-03-19 14:11:26  Next BlockIndex 1536, BlockAddress = 0x0000000000600000
2024-03-19 14:11:26  Skipping Verification Block 1536 Address 0x0000000000600000 Size 0x0000000000010000
2024-03-19 14:11:26  Next BlockIndex 1552, BlockAddress = 0x0000000000610000
2024-03-19 14:11:26  Skipping Verification Block 1552 Address 0x0000000000610000 Size 0x0000000000030000
2024-03-19 14:11:26  Next BlockIndex 1600, BlockAddress = 0x0000000000640000
2024-03-19 14:11:26  Skipping Verification Block 1600 Address 0x0000000000640000 Size 0x0000000000030000
2024-03-19 14:11:26  Next BlockIndex 1648, BlockAddress = 0x0000000000670000
2024-03-19 14:11:26  Skipping Verification Block 1648 Address 0x0000000000670000 Size 0x0000000000001000
2024-03-19 14:11:26  Next BlockIndex 1649, BlockAddress = 0x0000000000671000
2024-03-19 14:11:26  Skipping Verification Block 1649 Address 0x0000000000671000 Size 0x0000000000001000
2024-03-19 14:11:26  Next BlockIndex 1650, BlockAddress = 0x0000000000672000
2024-03-19 14:11:26  Skipping Verification Block 1650 Address 0x0000000000672000 Size 0x0000000000002000
2024-03-19 14:11:26  Next BlockIndex 1652, BlockAddress = 0x0000000000674000
2024-03-19 14:11:32  Skipping Verification Block 3968 Address 0x0000000000F80000 Size 0x0000000000080000
2024-03-19 14:11:32  Next BlockIndex 4096, BlockAddress = 0x0000000001000000
2024-03-19 14:11:32  Updating BIOS files
2024-03-19 14:11:32  EfiBiosUpdateLibEntry(): Result is 0x0
2024-03-19 14:11:32  Setting Flash Completion Status
2024-03-19 14:11:32  BIOS Update Process Complete
2024-03-19 14:11:32  BIOS Update Successful
2024-03-19 16:10:03  EFI HP BIOS Update 3.9.4.1 Started
2024-03-19 16:10:03  [L]> System ID: 8526
2024-03-19 16:10:03  Failed Loading EFI_HP_BIOS_IMAGE_INTERFACE_PROTOCOL2_GUID(Not Found)
2024-03-19 16:10:03  HP BIOS Image Interface Protocol Version 2.0
2024-03-19 16:10:03  [L]> No Battery Control Protocol is present; Try KBC.
2024-03-19 16:10:03  [L]> Found 1 Absolute Pointer Protocol(s)
2024-03-19 16:10:03  [L]> 0 UART device path node found.
2024-03-19 16:10:03  All Required Protocols Located
2024-03-19 16:10:03  HpBiosUpdate.Mode = 4
2024-03-19 16:10:03  WRITE_BB = 0
2024-03-19 16:10:03  Current Directory = \HP\BIOSUpdate\
2024-03-19 16:10:03  SMBIOS Init Success
2024-03-19 16:10:03  SystemFamily = 4
2024-03-19 16:10:03  [L]> PlatformLang reported as en-US.
2024-03-19 16:10:03  [L]> Language Selected is currently (eng).
2024-03-19 16:10:03  Starting BIOS Update Process
2024-03-19 16:10:03  Setting BIOS Update Token
2024-03-19 16:10:03  Getting BIOS Detail Information
2024-03-19 16:10:03  IsBiosSixDigits = 0
2024-03-19 16:10:03  BIOS Returned BiosID '08526'
2024-03-19 16:10:03  QueryImageDetail: 4K Block Size detected.
2024-03-19 16:10:03  Skip Addresses:
2024-03-19 16:10:03  Entry 0: Address 0x0: Size: 0x600000
2024-03-19 16:10:03  Entry 1: Address 0x600000: Size: 0x10000
2024-03-19 16:10:03  Entry 2: Address 0x610000: Size: 0x30000
2024-03-19 16:10:03  Entry 3: Address 0x640000: Size: 0x30000
2024-03-19 16:10:03  Entry 4: Address 0x670000: Size: 0x1000
2024-03-19 16:10:03  Entry 5: Address 0x671000: Size: 0x1000
2024-03-19 16:10:03  Entry 6: Address 0x672000: Size: 0x2000
2024-03-19 16:10:03  Entry 7: Address 0xF80000: Size: 0x80000
2024-03-19 16:10:03  Loading BIOS Image
2024-03-19 16:10:03  File name constructed: HP\BIOS\Current\08526.bin
2024-03-19 16:10:04  Reading New BIOS Image HP\BIOS\Current\08526.bin
2024-03-19 16:10:04  Getting BIOS version from file image
2024-03-19 16:10:04  Bios Version = F.36
2024-03-19 16:10:04  Verifying AC or Battery Power Status
2024-03-19 16:10:04  NeedACScreen function pointer is NULL, assume AC mode
2024-03-19 16:10:04  Verifying Binary match
2024-03-19 16:10:04  Loading Signature File
2024-03-19 16:10:04  Loading Password File if required
2024-03-19 16:10:04  BIOS Password not required.
2024-03-19 16:10:04  Writing BIOS Image
2024-03-19 16:11:30  Verifying Written BIOS Image
2024-03-19 16:11:30  VerifyImage: 4K Block Size detected.
2024-03-19 16:11:30  Skipping Verification Block 0 Address 0x0000000000000000 Size 0x0000000000600000
2024-03-19 16:11:30  Next BlockIndex 1536, BlockAddress = 0x0000000000600000
2024-03-19 16:11:30  Skipping Verification Block 1536 Address 0x0000000000600000 Size 0x0000000000010000
2024-03-19 16:11:30  Next BlockIndex 1552, BlockAddress = 0x0000000000610000
2024-03-19 16:11:30  Skipping Verification Block 1552 Address 0x0000000000610000 Size 0x0000000000030000
2024-03-19 16:11:30  Next BlockIndex 1600, BlockAddress = 0x0000000000640000
2024-03-19 16:11:30  Skipping Verification Block 1600 Address 0x0000000000640000 Size 0x0000000000030000
2024-03-19 16:11:30  Next BlockIndex 1648, BlockAddress = 0x0000000000670000
2024-03-19 16:11:30  Skipping Verification Block 1648 Address 0x0000000000670000 Size 0x0000000000001000
2024-03-19 16:11:30  Next BlockIndex 1649, BlockAddress = 0x0000000000671000
2024-03-19 16:11:30  Skipping Verification Block 1649 Address 0x0000000000671000 Size 0x0000000000001000
2024-03-19 16:11:30  Next BlockIndex 1650, BlockAddress = 0x0000000000672000
2024-03-19 16:11:30  Skipping Verification Block 1650 Address 0x0000000000672000 Size 0x0000000000002000
2024-03-19 16:11:30  Next BlockIndex 1652, BlockAddress = 0x0000000000674000
2024-03-19 16:11:36  Skipping Verification Block 3968 Address 0x0000000000F80000 Size 0x0000000000080000
2024-03-19 16:11:36  Next BlockIndex 4096, BlockAddress = 0x0000000001000000
2024-03-19 16:11:36  Updating BIOS files
2024-03-19 16:11:36  EfiBiosUpdateLibEntry(): Result is 0x0
2024-03-19 16:11:36  Setting Flash Completion Status
2024-03-19 16:11:36  BIOS Update Process Complete
2024-03-19 16:11:36  BIOS Update Successful
2024-03-19 16:13:48  EFI HP BIOS Update 3.9.4.1 Started
2024-03-19 16:13:48  [L]> System ID: 8526
2024-03-19 16:13:48  Failed Loading EFI_HP_BIOS_IMAGE_INTERFACE_PROTOCOL2_GUID(Not Found)
2024-03-19 16:13:48  HP BIOS Image Interface Protocol Version 2.0
2024-03-19 16:13:48  [L]> No Battery Control Protocol is present; Try KBC.
2024-03-19 16:13:48  [L]> Found 1 Absolute Pointer Protocol(s)
2024-03-19 16:13:48  [L]> 0 UART device path node found.
2024-03-19 16:13:48  All Required Protocols Located
2024-03-19 16:13:48  HpBiosUpdate.Mode = 4
2024-03-19 16:13:48  WRITE_BB = 0
2024-03-19 16:13:48  Current Directory = \HP\BIOSUpdate\
2024-03-19 16:13:48  SMBIOS Init Success
2024-03-19 16:13:48  SystemFamily = 4
2024-03-19 16:13:48  [L]> PlatformLang reported as en-US.
2024-03-19 16:13:48  [L]> Language Selected is currently (eng).
2024-03-19 16:13:48  Starting BIOS Update Process
2024-03-19 16:13:48  Setting BIOS Update Token
2024-03-19 16:13:48  Getting BIOS Detail Information
2024-03-19 16:13:48  IsBiosSixDigits = 0
2024-03-19 16:13:48  BIOS Returned BiosID '08526'
2024-03-19 16:13:48  QueryImageDetail: 4K Block Size detected.
2024-03-19 16:13:48  Skip Addresses:
2024-03-19 16:13:48  Entry 0: Address 0x0: Size: 0x600000
2024-03-19 16:13:48  Entry 1: Address 0x600000: Size: 0x10000
2024-03-19 16:13:48  Entry 2: Address 0x610000: Size: 0x30000
2024-03-19 16:13:48  Entry 3: Address 0x640000: Size: 0x30000
2024-03-19 16:13:48  Entry 4: Address 0x670000: Size: 0x1000
2024-03-19 16:13:48  Entry 5: Address 0x671000: Size: 0x1000
2024-03-19 16:13:48  Entry 6: Address 0x672000: Size: 0x2000
2024-03-19 16:13:48  Entry 7: Address 0xF80000: Size: 0x80000
2024-03-19 16:13:48  Loading BIOS Image
2024-03-19 16:13:48  File name constructed: HP\BIOS\Current\08526.bin
2024-03-19 16:13:49  Reading New BIOS Image HP\BIOS\Current\08526.bin
2024-03-19 16:13:49  Getting BIOS version from file image
2024-03-19 16:13:49  Bios Version = F.36
2024-03-19 16:13:49  Verifying AC or Battery Power Status
2024-03-19 16:13:49  NeedACScreen function pointer is NULL, assume AC mode
2024-03-19 16:13:49  Verifying Binary match
2024-03-19 16:13:49  Loading Signature File
2024-03-19 16:13:49  Loading Password File if required
2024-03-19 16:13:49  BIOS Password not required.
2024-03-19 16:13:49  Writing BIOS Image
2024-03-19 16:15:16  Verifying Written BIOS Image
2024-03-19 16:15:16  VerifyImage: 4K Block Size detected.
2024-03-19 16:15:16  Skipping Verification Block 0 Address 0x0000000000000000 Size 0x0000000000600000
2024-03-19 16:15:16  Next BlockIndex 1536, BlockAddress = 0x0000000000600000
2024-03-19 16:15:16  Skipping Verification Block 1536 Address 0x0000000000600000 Size 0x0000000000010000
2024-03-19 16:15:16  Next BlockIndex 1552, BlockAddress = 0x0000000000610000
2024-03-19 16:15:16  Skipping Verification Block 1552 Address 0x0000000000610000 Size 0x0000000000030000
2024-03-19 16:15:16  Next BlockIndex 1600, BlockAddress = 0x0000000000640000
2024-03-19 16:15:16  Skipping Verification Block 1600 Address 0x0000000000640000 Size 0x0000000000030000
2024-03-19 16:15:16  Next BlockIndex 1648, BlockAddress = 0x0000000000670000
2024-03-19 16:15:16  Skipping Verification Block 1648 Address 0x0000000000670000 Size 0x0000000000001000
2024-03-19 16:15:16  Next BlockIndex 1649, BlockAddress = 0x0000000000671000
2024-03-19 16:15:16  Skipping Verification Block 1649 Address 0x0000000000671000 Size 0x0000000000001000
2024-03-19 16:15:17  Next BlockIndex 1650, BlockAddress = 0x0000000000672000
2024-03-19 16:15:17  Skipping Verification Block 1650 Address 0x0000000000672000 Size 0x0000000000002000
2024-03-19 16:15:17  Next BlockIndex 1652, BlockAddress = 0x0000000000674000
2024-03-19 16:15:22  Skipping Verification Block 3968 Address 0x0000000000F80000 Size 0x0000000000080000
2024-03-19 16:15:22  Next BlockIndex 4096, BlockAddress = 0x0000000001000000
2024-03-19 16:15:22  Updating BIOS files
2024-03-19 16:15:22  EfiBiosUpdateLibEntry(): Result is 0x0
2024-03-19 16:15:22  Setting Flash Completion Status
2024-03-19 16:15:22  BIOS Update Process Complete
2024-03-19 16:15:22  BIOS Update Successful
2024-03-19 16:19:09  EFI HP BIOS Update 3.9.4.1 Started
2024-03-19 16:19:09  [L]> System ID: 8526
2024-03-19 16:19:09  Failed Loading EFI_HP_BIOS_IMAGE_INTERFACE_PROTOCOL2_GUID(Not Found)
2024-03-19 16:19:09  HP BIOS Image Interface Protocol Version 2.0
2024-03-19 16:19:09  [L]> No Battery Control Protocol is present; Try KBC.
2024-03-19 16:19:09  [L]> Found 1 Absolute Pointer Protocol(s)
2024-03-19 16:19:09  [L]> 0 UART device path node found.
2024-03-19 16:19:09  All Required Protocols Located
2024-03-19 16:19:09  HpBiosUpdate.Mode = 4
2024-03-19 16:19:09  WRITE_BB = 0
2024-03-19 16:19:09  Current Directory = \HP\BIOSUpdate\
2024-03-19 16:19:09  SMBIOS Init Success
2024-03-19 16:19:09  SystemFamily = 4
2024-03-19 16:19:09  [L]> PlatformLang reported as en-US.
2024-03-19 16:19:09  [L]> Language Selected is currently (eng).
2024-03-19 16:19:09  Starting BIOS Update Process
2024-03-19 16:19:09  Setting BIOS Update Token
2024-03-19 16:19:09  Getting BIOS Detail Information
2024-03-19 16:19:09  IsBiosSixDigits = 0
2024-03-19 16:19:09  BIOS Returned BiosID '08526'
2024-03-19 16:19:09  QueryImageDetail: 4K Block Size detected.
2024-03-19 16:19:09  Skip Addresses:
2024-03-19 16:19:09  Entry 0: Address 0x0: Size: 0x600000
2024-03-19 16:19:09  Entry 1: Address 0x600000: Size: 0x10000
2024-03-19 16:19:09  Entry 2: Address 0x610000: Size: 0x30000
2024-03-19 16:19:09  Entry 3: Address 0x640000: Size: 0x30000
2024-03-19 16:19:09  Entry 4: Address 0x670000: Size: 0x1000
2024-03-19 16:19:09  Entry 5: Address 0x671000: Size: 0x1000
2024-03-19 16:19:09  Entry 6: Address 0x672000: Size: 0x2000
2024-03-19 16:19:09  Entry 7: Address 0xF80000: Size: 0x80000
2024-03-19 16:19:09  Loading BIOS Image
2024-03-19 16:19:09  File name constructed: HP\BIOS\Current\08526.bin
2024-03-19 16:19:09  Reading New BIOS Image HP\BIOS\Current\08526.bin
2024-03-19 16:19:09  Getting BIOS version from file image
2024-03-19 16:19:09  Bios Version = F.36
2024-03-19 16:19:09  Verifying AC or Battery Power Status
2024-03-19 16:19:09  NeedACScreen function pointer is NULL, assume AC mode
2024-03-19 16:19:09  Verifying Binary match
2024-03-19 16:19:09  Loading Signature File
2024-03-19 16:19:10  Loading Password File if required
2024-03-19 16:19:10  BIOS Password not required.
2024-03-19 16:19:10  Writing BIOS Image
2024-03-19 16:20:36  Verifying Written BIOS Image
2024-03-19 16:20:36  VerifyImage: 4K Block Size detected.
2024-03-19 16:20:36  Skipping Verification Block 0 Address 0x0000000000000000 Size 0x0000000000600000
2024-03-19 16:20:36  Next BlockIndex 1536, BlockAddress = 0x0000000000600000
2024-03-19 16:20:36  Skipping Verification Block 1536 Address 0x0000000000600000 Size 0x0000000000010000
2024-03-19 16:20:36  Next BlockIndex 1552, BlockAddress = 0x0000000000610000
2024-03-19 16:20:36  Skipping Verification Block 1552 Address 0x0000000000610000 Size 0x0000000000030000
2024-03-19 16:20:36  Next BlockIndex 1600, BlockAddress = 0x0000000000640000
2024-03-19 16:20:36  Skipping Verification Block 1600 Address 0x0000000000640000 Size 0x0000000000030000
2024-03-19 16:20:36  Next BlockIndex 1648, BlockAddress = 0x0000000000670000
2024-03-19 16:20:36  Skipping Verification Block 1648 Address 0x0000000000670000 Size 0x0000000000001000
2024-03-19 16:20:36  Next BlockIndex 1649, BlockAddress = 0x0000000000671000
2024-03-19 16:20:36  Skipping Verification Block 1649 Address 0x0000000000671000 Size 0x0000000000001000
2024-03-19 16:20:36  Next BlockIndex 1650, BlockAddress = 0x0000000000672000
2024-03-19 16:20:36  Skipping Verification Block 1650 Address 0x0000000000672000 Size 0x0000000000002000
2024-03-19 16:20:36  Next BlockIndex 1652, BlockAddress = 0x0000000000674000
2024-03-19 16:20:42  Skipping Verification Block 3968 Address 0x0000000000F80000 Size 0x0000000000080000
2024-03-19 16:20:42  Next BlockIndex 4096, BlockAddress = 0x0000000001000000
2024-03-19 16:20:42  Updating BIOS files
2024-03-19 16:20:42  EfiBiosUpdateLibEntry(): Result is 0x0
2024-03-19 16:20:42  Setting Flash Completion Status
2024-03-19 16:20:42  BIOS Update Process Complete
2024-03-19 16:20:42  BIOS Update Successful
2024-03-19 16:31:31  EFI HP BIOS Update 3.9.4.1 Started
2024-03-19 16:31:31  [L]> System ID: 8526
2024-03-19 16:31:32  Failed Loading EFI_HP_BIOS_IMAGE_INTERFACE_PROTOCOL2_GUID(Not Found)
2024-03-19 16:31:32  HP BIOS Image Interface Protocol Version 2.0
2024-03-19 16:31:32  [L]> No Battery Control Protocol is present; Try KBC.
2024-03-19 16:31:32  [L]> Found 1 Absolute Pointer Protocol(s)
2024-03-19 16:31:33  [L]> 0 UART device path node found.
2024-03-19 16:31:33  All Required Protocols Located
2024-03-19 16:31:33  HpBiosUpdate.Mode = 4
2024-03-19 16:31:33  WRITE_BB = 0
2024-03-19 16:31:33  Current Directory = \HP\BIOSUpdate\
2024-03-19 16:31:33  [L]> System ID: 8526
2024-03-19 16:31:33  SMBIOS Init Success
2024-03-19 16:31:33  SystemFamily = 4
2024-03-19 16:31:33  [L]> PlatformLang reported as en-US.
2024-03-19 16:31:33  [L]> Language Selected is currently (eng).
2024-03-19 16:31:33  Starting BIOS Update Process
2024-03-19 16:31:33  Setting BIOS Update Token
2024-03-19 16:31:33  Getting BIOS Detail Information
2024-03-19 16:31:33  IsBiosSixDigits = 0
2024-03-19 16:31:33  BIOS Returned BiosID '08526'
2024-03-19 16:31:33  QueryImageDetail: 4K Block Size detected.
2024-03-19 16:31:33  Skip Addresses:
2024-03-19 16:31:33  Entry 0: Address 0x0: Size: 0x600000
2024-03-19 16:31:33  Entry 1: Address 0x600000: Size: 0x10000
2024-03-19 16:31:33  Entry 2: Address 0x610000: Size: 0x30000
2024-03-19 16:31:33  Entry 3: Address 0x640000: Size: 0x30000
2024-03-19 16:31:33  Entry 4: Address 0x670000: Size: 0x1000
2024-03-19 16:31:33  Entry 5: Address 0x671000: Size: 0x1000
2024-03-19 16:31:33  Entry 6: Address 0x672000: Size: 0x2000
2024-03-19 16:31:33  Entry 7: Address 0xF80000: Size: 0x80000
2024-03-19 16:31:33  Loading BIOS Image
2024-03-19 16:31:33  File name constructed: HP\BIOS\Current\08526.bin
2024-03-19 16:31:33  Reading New BIOS Image HP\BIOS\Current\08526.bin
2024-03-19 16:31:33  Getting BIOS version from file image
2024-03-19 16:31:33  Bios Version = F.36
2024-03-19 16:31:33  Verifying AC or Battery Power Status
2024-03-19 16:31:33  NeedACScreen function pointer is NULL, assume AC mode
2024-03-19 16:31:33  Verifying Binary match
2024-03-19 16:31:33  Loading Signature File
2024-03-19 16:31:34  Loading Password File if required
2024-03-19 16:31:34  BIOS Password not required.
2024-03-19 16:31:34  Writing BIOS Image
2024-03-19 16:33:00  Verifying Written BIOS Image
2024-03-19 16:33:00  VerifyImage: 4K Block Size detected.
2024-03-19 16:33:00  Skipping Verification Block 0 Address 0x0000000000000000 Size 0x0000000000600000
2024-03-19 16:33:00  Next BlockIndex 1536, BlockAddress = 0x0000000000600000
2024-03-19 16:33:00  Skipping Verification Block 1536 Address 0x0000000000600000 Size 0x0000000000010000
2024-03-19 16:33:00  Next BlockIndex 1552, BlockAddress = 0x0000000000610000
2024-03-19 16:33:00  Skipping Verification Block 1552 Address 0x0000000000610000 Size 0x0000000000030000
2024-03-19 16:33:00  Next BlockIndex 1600, BlockAddress = 0x0000000000640000
2024-03-19 16:33:00  Skipping Verification Block 1600 Address 0x0000000000640000 Size 0x0000000000030000
2024-03-19 16:33:00  Next BlockIndex 1648, BlockAddress = 0x0000000000670000
2024-03-19 16:33:00  Skipping Verification Block 1648 Address 0x0000000000670000 Size 0x0000000000001000
2024-03-19 16:33:00  Next BlockIndex 1649, BlockAddress = 0x0000000000671000
2024-03-19 16:33:00  Skipping Verification Block 1649 Address 0x0000000000671000 Size 0x0000000000001000
2024-03-19 16:33:00  Next BlockIndex 1650, BlockAddress = 0x0000000000672000
2024-03-19 16:33:00  Skipping Verification Block 1650 Address 0x0000000000672000 Size 0x0000000000002000
2024-03-19 16:33:00  Next BlockIndex 1652, BlockAddress = 0x0000000000674000
2024-03-19 16:33:06  Skipping Verification Block 3968 Address 0x0000000000F80000 Size 0x0000000000080000
2024-03-19 16:33:06  Next BlockIndex 4096, BlockAddress = 0x0000000001000000
2024-03-19 16:33:06  Updating BIOS files
2024-03-19 16:33:06  EfiBiosUpdateLibEntry(): Result is 0x0
2024-03-19 16:33:06  Setting Flash Completion Status
2024-03-19 16:33:06  BIOS Update Process Complete
2024-03-19 16:33:06  BIOS Update Successful
发表于 2024-3-20 06:54:30 | 只看该作者 �
发表于 2024-3-20 06:55:44 | 只看该作者 �
发表于 2024-3-20 07:00:05 | 只看该作者 �
上面是官方原版更新的日志是成功更新的 但是没有开机logo和序列号
发表于 2024-3-20 07:05:09 | 只看该作者 �
加入序列号以后再更新是这样的过程:
发表于 2024-3-20 07:07:37 | 只看该作者 �
但是不能通过校验~~~
发表于 2024-3-20 07:15:16 | 只看该作者 �
更新路径是hp/BIOSUpdate/
日志文件名是:
HpBiosUpdate
再恢复原bios后正常可以更新
恢复的最后是这样的~
更新成功了~但是序列号没有加入
开机logo也没有~~待论坛大侠意见
