查看: 1135|回复: 2
求一款能支持三星ssd mas0901m闪存 主控的量产工具
发表于 2023-1-9 05:31:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Model Name: HS-SSD-C100 120G
Serial Number: 30034335425
Firmware Revision: SN07985
Heads: 16   Cylinders: 16383   Sectors per Track: 63
Current capacity in sectors (CHS mode): 16514064
Total number of user addressable sectors (LBA mode): 234441648
Multiword DMA mode 2 and below are supported
Multiword DMA is selected: mode 2
Ultra DMA mode 6 and below are supported
Ultra DMA is selected: none
SMART feature set supported, enabled
Security Mode feature set supported, not enabled
World Wide Name: 5000000000000006
发表于 2023-1-9 13:52:52 | 只看该作者 �
这个真没有
回复 支持 0 反对 1
发表于 2023-3-14 17:55:58 来自迅维网APP | 只看该作者 �
主控下面的闪存啥型号,要根据主控,闪存型号下载开卡软件
