查看: 3389|回复: 18
please help fix UUID error, rfid for Lenovo thinkpad E460 NM A511 rev 1.0
发表于 2021-6-7 19:13:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
I have a computer thinkpad E460 NM A551 rev 1.0 i5 6200U .
I replaced the IO IT8586E and saved the IO ec rom. Maybe the copy I saved has errors because when I write the ec rom to the new IO, when I start the machine, it gives an error UUID invalid , RFID invalid .
I've tried looking for other bios, ec roms but nothing changed. In the bios setup the MTM sections, system unit serial number , system board serial number is invalid , the UUID line is FFFFF...
I used the IBM thinkpad Maintenance Diskette 1.9 tool to record the MTM , serial unit , serial board . Everything is OK  . Only the UUID doesn't change, even when I go to the assign UUID section of the IBM Maintenance Diskette tool.
now every time i install windows i get error 0189 Invalid RFID configuration information area , and invalid UUID and I have to press ESC to enter windows .
Does anyone know how to recover the UUID ? I don't quite understand because if the HP computer after recording the serial, the UUID will appear again by itself. As for Lenovo, I don't quite understand its UUID .
发表于 2021-6-11 10:30:24 来自迅维网APP | 只看该作者 �
老外也修电脑吗
发表于 2021-6-11 09:56:04 来自迅维网APP | 只看该作者 �
Hǎole méi? Xiūhǎole méiyǒu?
哈哈,老外看得懂拼音吗? 是不说的带程序的ec?  详情 回复 发表于 2021-6-11 11:24
Done yet? Is it fixed?  详情 回复 发表于 2021-6-11 09:56
发表于 2021-6-11 08:00:21 来自迅维网APP | 只看该作者 �
我还以为我进错地方了。
发表于 2021-6-9 15:51:38 | 只看该作者 �
If the motherboard is not equipped with pca24s08ad, the it8586e is damaged
发表于 2021-6-9 15:41:02 | 只看该作者 �
If you can't write UUID with the U disk tool, it may be EC that is broken
发表于 2021-6-9 15:39:13 | 只看该作者 �
Do you use tools to add UUID to U disk
发表于 2021-6-8 16:19:47 | 只看该作者 �
wuyaping 发表于 2021-6-8 10:33
Download the program in the link and read the manual
thank you, I have downloaded and followed your instructions link but everything is the same, error code 2201 UUID and error code 0189 RFID still appear every time I install windows. I think there is something wrong with the RFID error but I really don't understand, I have updated the bios update downloaded from Lenovo support but nothing changed.
https://ibb.co/mzfNRwG
发表于 2021-6-8 10:29:14 | 只看该作者 �
发表于 2021-6-8 10:33:53 | 只看该作者 �
Download the program in the link and read the manual Thinkpad Maintenance Disk 使用说明.pdf (532.81 KB, 下载次数: 32)
thank you, I have downloaded and followed your instructions link but everything is the same, error code 2201 UUID and error code 0189 RFID still appear every time I install windows. I think there is s  详情 回复 发表于 2021-6-8 16:19
发表于 2021-6-11 09:42:21 来自迅维网APP | 只看该作者 �
ni de  English  za zheme niubi  ?  is  chusheng yuan  zhuang de ?
发表于 2021-6-11 09:56:53 来自迅维网APP | 只看该作者 �
发表于 2021-6-11 10:30:42 来自迅维网APP | 只看该作者 �
我才太看得懂:老外也修电脑吗
发表于 2021-6-11 11:00:58 来自迅维网APP | 只看该作者 �
Where are you from?
发表于 2021-6-11 11:24:54 来自迅维网APP | 只看该作者 �
哈哈,老外看得懂拼音吗?
是不说的带程序的ec?
发表于 2021-6-12 10:37:33 来自迅维网APP | 只看该作者 �
哈哈哈
发表于 2021-6-14 04:01:44 | 只看该作者 �
the bug was fixed 2 days ago , i used the tool HDM version 2.06 , boot only uefi , and easily rewrote the serial , model and regenerated UUID .
Sorry I'm not Chinese, my English is not good because I'm using google translate. Thanks .
n1ctm02w.zip
258.97 KB, 下载次数: 9, 下载积分: 下载分 -2 分, 下载 1 次
ver 2.02
n1ctm04w.zip
303.85 KB, 下载次数: 11, 下载积分: 下载分 -2 分, 下载 1 次
ver 2.04
n1ctm06w.zip
363.5 KB, 下载次数: 29, 下载积分: 下载分 -2 分, 下载 1 次
ver 2.06
n1ctm07w.zip
364.46 KB, 下载次数: 16, 下载积分: 下载分 -2 分, 下载 1 次
ver 2.07
发表于 2021-6-14 04:06:14 | 只看该作者 �
n1ctm02w.zip
258.97 KB, 下载次数: 4, 下载积分: 下载分 -2 分, 下载 1 次
n1ctm04w.zip
303.85 KB, 下载次数: 3, 下载积分: 下载分 -2 分, 下载 1 次
n1ctm06w.zip
363.5 KB, 下载次数: 14, 下载积分: 下载分 -2 分, 下载 1 次
n1ctm07w.zip
364.46 KB, 下载次数: 5, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2021-6-14 04:17:32 | 只看该作者 �
my error fixed with tool HDM version 2.06 , boot with UEFI .
