查看: 1123|回复: 0
讯景.RX480.8G.三星显存BIOS
发表于 2021-1-22 06:57:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
GPU Device Id: 0x1002 0x67DF113-P10XT-E1338-8GB-34EW81D00901 Polaris10 XT A1 GDDR5 256Mx32 8GB 300e/300m(C) 1988-2010, Advanced Micro Devices, Inc.ATOMBIOSBK-AMD VER015.050.000.000.000000P10X834E.W81CCC Overdrive Limits  GPU Clock: 2000 MHz  Memory Clock: 2250 MHzPowerTune Limit: -50% to +50%Limits  TDP: 110 W  TDC Power: 107 A  Battery Power: 115 W  Small Power Power: 115 W  Max. Power Limit: 115 W  Max. Temp: 90°CGPU Clocks  300 MHz, 608 MHz, 910 MHz, 1077 MHz  1160 MHz, 1225 MHz, 1285 MHz, 1338 MHzMemory Clocks  300 MHz, 2000 MHzTemperature Target: 70 °CMemory Support  8192 MB, GDDR5, Samsung K4G80325FBMemory Timings (Samsung)  tRCDW-tRCDWA-tRCDR-tRCDRA-tRC-tCL-tRFC  250 MHz: 2-3-3-3-11-8-27  400 MHz: 3-3-5-5-17-9-43  600 MHz: 5-5-8-8-26-11-65  900 MHz: 7-7-13-13-39-15-98  1000 MHz: 8-8-14-14-43-16-109  1125 MHz: 9-9-16-16-49-17-123  1250 MHz: 10-10-18-18-55-18-137  1375 MHz: 12-12-20-20-61-19-151  1500 MHz: 13-13-22-22-65-20-164  1625 MHz: 14-14-24-24-71-21-178  1750 MHz: 16-16-26-26-77-22-192  2000 MHz: 17-17-29-29-87-24-219
XFX.RX480.8192.160802.rom
256 KB, 下载次数: 14, 下载积分: 下载分 -2 分, 下载 1 次
