查看: 1026|回复: 1
上一主题 下一主题
AsRock Z77 Pro3 DPWROK signal problem
发表于 2020-6-25 03:58:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
Hi
No problem with the visually on the motherboard and no liquid contact
no start on motherboard. standby voltages OK.
I found a strange problem. No reaction when starting motherboard
But when this signal (DPWROK pull-down) shifts to ground, the motherboard starts
RSMRST# +3.3 ok
DPWROK +3.3 ok
Could there be a chipset problem?
ASROCK_Z77 PRO3_R1.04(70-MXGM00-A03).fz (386.12 KB, 下载次数: 6)
参与人数 1下载分 +2 +2 收起 理由
kerokrrl + 2 + 2 给愿意分享经验的人加分!
发表于 2020-6-28 16:58:15 | 只看该作者 �
Maintenance is like gambling. You can take it into consideration when you are sure
发表于 2020-6-30 02:28:47 �
I changed the chipset and the problem went away
支持 反对
