查看: 1769|回复: 1
ASUS A68HM-K REV1.00有时会自动开启电源,有时不会触发并重设
发表于 2020-1-3 18:17:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
ASUS A68HM-K REV1.00 sometimes automatically power on, sometimes it does not trigger and reset
Power switch voltage up and down
Sometimes 2.97V, 1.45V, 1.79V,
with
Corrected 1.45V at some time
After finding it I checked 1.45V
It comes from 3VSB.
3VSB is converted from 5VSB
3VSB comes from PU601.
I check if PU601 has a device circuit
PU601 PIN 2 is connected to PR604, it is 1.27K, but I removed and checked it.
Its value is becoming 8.5K
I changed 1.27K to 1.50K.
After non-automatic startup, the trigger is successful, and the code is run and displayed perfectly.
发表于 2020-1-4 21:52:08 来自迅维网APP | 只看该作者 �
外国人吗,看着很吃力,应该是换电阻修好了吧
