查看: 15197|回复: 0
[BIOS]IPX31-GS-THTF-0014-20091017
发表于 2010-6-13 08:51:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
----------------------THTF IPX31_GS-THTF BIOS Release Note---------------------------------------------
Module  : IPX31_GS-THTF
North Bridge : Intel G31
South Bridge : Intel ICH7
Super I/O : Winbond W83627DHG
Flash  : 4Mb SPI flash
AFUDOS Version : 4.15
DOS Flash Method: AFUDOS Filename /p /b /c
MRC version : 2.20
VBIOS Version : 1533
Changes from : IPX31-GS-THTF-0011
**Micro Code Information**
F56F426
016F533
016FBB6
016FDA3
016F25A
506F533
031066004
011066138
016F6CB
04F620F
34F6404
04F650B
106F768
106FBB6
101067660C
011067660C
111067AA07
1010677705
0110671106
0110674404
IPX31-GS-THTF-0014-20091017.ROM 10/17/2009
Checksum: D7A5h
01. Change SLP2.1 back to SLP2.0.
02. Move [CPU Fan Fail Warning] function from post code 0052 to 0085.
IPX31-GS-THTF-0011-20090829.ROM 08/12/2009
Checksum: 041Ah
01. Update SLP2.1 for THTF.
02. Update audio verb table to fix WHQL test fail on Win7.
03. Fix the bug that Processor Family information show wrong in DMI Type4.
04. Fix the bug that onboard LAN can not be shown in popup menu.
05. When set [Boot From Other Device] as [Enabled], boot from HDD.
06. Make user can not modify [Quick Boot] when [User Access Level] item set as "Limited" in Setup Menu.
IPX31-GS-THTF-0010-20090812.ROM 08/12/2009
Checksum: 90ADh
01. Update microcode M0110671106 for Wolfdale, stepping A1, CPUID 10671.
    Update microcode M0110674404 for Wolfdale, stepping B1, CPUID 10674.
IPX31-GS-THTF-0009-20090730.ROM 07/30/2009
Checksum: 6CCFh
01. [THTF BIOS Quick Test Report V1.2][Bug7]: Fix the bug that if set [USB Function] as [Disabled], [USB2.0 Controller] still shows and the value can be changed.
02. [THTF BIOS Quick Test Report V1.2][Bug9]: Fix the bug that when disable some bootable devices in BIOS Setup, they also can display in POPUP menu.
03. [THTF BIOS Quick Test Report V1.2][Bug13]: Fix the bug that if set User password as [ViewOnly], and entering BIOS Setup by User password, we can still change the system Time/Date.
04. [THTF BIOS Quick Test Report V1.2][Bug14]: Fix the bug that if set User password as [Limited], and entering BIOS Setup by user password, we can't save our changes of system time/date by hotkey [F10].
05. [THTF BIOS Quick Test Report V1.2]: Modify or remove some items in BIOS Setup to meet THTF spec.
06. Implement the function of backspace key when inputing BIOS Setup password.
IPX31-GS-THTF-0008-20090716.ROM 07/16/2009
Checksum: 24D3h
01. Modify [Manufacturer Name] from "PEGATRON CORPORATION" to "PEGATRON" in DMI type2.
    Modify [Product Name] from "To be filled by O.E.M." to "IPX31-GS" in DMI type2.
IPX31-GS-THTF-0007-20090429.ROM 04/29/2009
Checksum: 343Bh
01. Change the following items to meet THTF new spec comment 090427:
1. Change the default setting of [TF TCM support] from [Yes] to [No];
2. Change [Enabled] to [Enable], [Disabled] to [Disable] in [Execute TCM Command].
02. When plug the TCM card and set [TCM Support] and [TCM State] as [Enabled] in the BIOS setup,
    make the TCM device not been displayed in the Device Manager under Vista.
IPX31-GS-THTF-0006-20090423.ROM 04/23/2009
Checksum: 0389h
01. Fix the bug that when MFG enabled, system report F1/F2 error message and install unknow password after the following steps:
1. Unplug AC -> Remove RTC battery -> Clear CMOS ->
2. Install battery -> Plug AC -> Power on the system
IPX31-GS-THTF-0005-20090416.ROM 04/16/2009
Checksum: C02Ah
01. Update MFG function to meet factory's request.
IPX31-GS-THTF-0004-20090408.ROM 04/08/2009
Checksum: 6760h
01. Remove the beep sound when resume from S3.
02. Remove the delay when enter [Hardware Monitor Setup].
03. Fix the bug that when CPU fan speed is too slow, the system will beep when enter [Hardware Monitor Setup].
04. Fix the bug that when set [CPU Fan Fail Warning] as [Disabled], it needs 5-6 seconds to enter [Hardware Monitor Setup].
05. Fix the bug that when use AFUDOS to flash BIOS with command "/L2", system will hang at post code "0045" during POST when first reboot.
06. Add the beep sound during POST to meet THTF new request.
07. Update audio verb table to fix WHQL test fail.
08. Remove the [Primary Graphics Adapter] item according to FAE's request.
09. When plug PCIEx16 VGA card, hide the following items:
[DVMT Mode]
[DVMT Fixed Memory Size]
[PCI Express force on x1].
IPX31-GS-THTF-0608-20090324.ROM 03/24/2009
Checksum: F01Eh
01. Enable HPET function to pass WHQL test.
02. Update audio verb table.
03. Disable CPU C3 and C4 state according to EE's request.
IPX31-GS-THTF-0607-20090317.ROM 03/17/2009
Checksum: 15F7h
01. Change the copyright information from "2008" to "2009" during POST.
02. Fix the bug that when set [Restore On AC Power Loss] as [Last State], it has the same function as [Power On] on some kinds of CPU.
03. Remove the [KB Power On Password] function in [Power Management Features] to meet THTF spec comment.
04. Fix the bug that when set PS/2 KB wake up as enabled in Device Manager, and set [Power On By PS/2 Keyboard] as [Disabled] in BIOS setup menu,
    then sleep to S1/S3/S4, system will not be resumed by PS/2 KB.
IPX31-GS-THTF-0606-20090310.ROM 03/10/2009
Checksum: 1C21h
01. BBU-31: Fix the bug that when set [Restore On AC Power Loss] as [Power On], and press power button 4s long to shut down in OS,
     the system can not auto power on.
IPX31-GS-THTF-0003-20090303.ROM 03/03/2009
Checksum: F634h
01. Fix the bug that when set [Smart Fan Start PWM Value] as [127], system fan speed will not follow the CPU fan speed.
02. Remove the system beep when disconnect or connect USB device to meet THTF spec comment.
03. Change [Fixed Mode] to [Fixed], [DVMT Mode] to [DVMT] in [DVMT Mode].
    Change [128M] to [128], [256M] to [256] in [DVMT Fixed Memory Size].
04. Add [USB Function] item in [System Device Setup] to follow IPX41.
05. Hide [USB Mode] item in [System Device Setup] to follow IPX41.
IPX31-GS-THTF-0605-20090224.ROM 02/24/2009
Checksum: D912h
01. QTC-50222: Fix the bug that when set [Halt On] as [All Error], and set [Quick Boot] as [Disabled], BIOS will not halt when there is no floppy.
02. QTC-60867: Fix the bug that when set [Onboard LAN Boot ROM] as [Enabled], [Load Optimal Defaults] will not take effect
        when the [3rd Boot Device] is setting as [LAN].
03. Fix the bug that when both PS/2 and USB KB are not present, BIOS will show two error messages at the end of POST.
04. Change [Discard Changes and Exit] hot key from "F11" to "ESC" and change the help string according to FAE's mail.
05. Add the MFG function.
IPX31-GS-THTF-0002-20090219.ROM 02/19/2009
Checksum: 12F3h
01. QTC-06041, QTC-53249: Change TPM function to TCM function.
02. QTC-73524: Update [IDE Features] in [Standard CMOS Setup].
03. QTC-81872: Hide [KB Power On Password] item when [Power On By PS/2 Keyboard] is not setting as [Password].
04. QTC-62355: Add [Boot from other device] function in [System Boot Setup].
05. QTC-78740: Change the Copyright information from "2008" to "2009" in setup menu.
06. QTC-00001: Update the default value of [Restore On AC Power Loss] from [Power on] to [Power off] to meet THTF spec 090216.doc.
07. QTC-22360: Remove the unnecessary channels in Device Manager because we don't have PATA ports.
08. QTC-60867: Update the following wrong strings in [Boot Device Priority]:
        "Network" to "LAN";
        "Removable Dev." to "Removable";
        "SATA" to "HDD";
        "CD/DVD" to "CD/DVD ROM".
09. According to EE's request, change Clock Gen control register 09h bit[2:0] to 100b.
10. Update power LED function to meet schematic 1.02.
IPX31-GS-THTF-0604-20090210.ROM 02/10/2009
Checksum: 0E8Dh
01.BBU-26: Remove the DIMM1 information in DMI.
02.QTC-74367: 1. Change [HiSpeed] to [High Speed], [FullSpeed] to [Full Speed] in [USB Mode] to meet THTF spec.
       2. Add [PCI Express force on x1] item in [System Device Setup] to meet THTF spec.
       3. Change [Enabled, 1MB] to [1M], [Enabled, 8MB] to [8M] in [Pre-Allocated Memory Size] to meet THTF spec.
       4. Change [USB 2.0 Controller Mode] to [USB Mode] in [System Device Setup] to meet THTF spec.
03.QTC-02460: Change the default value of [3rd Boot Device] from [Removable Dev.] to [Disabled].
04.QTC-44337: Add [Removable Device Priority] and [CD/DVD Priority] item in [System Boot Setup] to meet THTF spec.
       The two items will always show even though there is no removable device or CD/DVD device.
05.QTC-72820: Change [Memory Mode] to [Channel Mode] in [Memory Features] to meet THTF spec.
06.QTC-84069: Change "Always" to "system", "Setup" to "setup" in [Password Check] help string to meet THTF spec.
07.Change the default boot sequence to "[CD/DVD], [Hard Disk], [Disabled]" in [System Boot Setup] to meet THTF spec.
Update the [Hardware Monitor Setup] as following(Please test the function after EE's rework):
08.QTC-02620: 1. Change the default value of [CPU Over Temperature Warning] from [Disabled] to [Enabled].
       2. Update [CPU Over Temperature Warning] function.
09.QTC-49184: Remove [System Smart Fan Function] item in [Hardware Monitor Setup] to meet THTF spec comment.
10.Update [CPU Temperature Status] function.
11.Update [PECI Value] function.
12.Change [CPU FAN Speed] to [CPU Fan Speed] in [Hardware Monitor Setup] to meet THTF spec.
13.Make [PECI Value] item hide when [CPU Smart Fan Function] is disabled.
14.Make [CPU Smart Fan Function] available when S3 resume.
15.Make [CPU Over Temperature Warning] available when S3 resume.
16.Make [Smart Fan Start Offset], [Smart Fan Full Speed Offset], [PECI Value] items hide when [CPU Smart Fan Function] is disabled.
IPX31-GS-THTF-0603-20090203.ROM 02/03/2009
Checksum: 0568h
01.BBU-07: Add PCIEx1 slot information, update PCIEx16 slot information in DMI Type9 to fix the DMI information shows wrong issue.
02.BBU-13, QTC-18: Update onboard LAN resume from S1/S3/S4/S5 function.
03.BBU-14, QTC-19: Update PCIEx1 LAN resume from S1/S3/S4/S5 function.
04.BBU-15: Fix the bug that system can't resume from S5(entered from DOS) with [Ctrl+Alt+Backspace] on left side of PS/2 keyboard.
05.BBU-16: Fix the bug when the PS/2 Keyboard is disabled and the PS/2 Mouse is enabled in Device Manager,
    if we click PS/2 Keyboard first, and then click or move PS/2 Mouse to resume, the system can't be resumed by PS/2 Mouse.
06.BBU-17: Fix the bug when the PS/2 Mouse is disabled and the PS/2 Keyboard is enabled in Device Manager,
    if we click or move PS/2 Mouse first, and then click PS/2 Keyboard to resume, the system can't be resumed by PS/2 Keyboard.
07.BBU-22: Fix the bug that when disable PS/2 KB wake up in Device Manager, system can still resume from S3&S4 by PS/2 KB Hot Key.
08.QTC-11: Add [System Smart Fan Function] item in [Hardware Monitor Setup] to meet THTF spec.
09.QTC-24: Change [Specific Key for PowerOn] to [KB Power On Password] in [Power Management Features] to meet THTF spec.
10.QTC-25: Change [SYS FAN Speed] to [System Fan Speed], [CPU FAN Speed] to [CPU Fan Speed], [Temperature Step] to [Slope Select PWM/C]
11.QTC-28: Fix the bug that Nvidia VGA driver can't be installed after flash BIOS 0602.
12.Update [KB Power On Password] function in [Power Management Features].
IPX31-GS-THTF-0602-20090120.ROM 01/20/2009
Checksum: B770h
01.BBU-05, QTC-88791: Add [PECI Value] item in [Hardware monitor setup] to show CPU temperature.
           Update CPU Smart FAN function: when enable [CPU Smart Fan Function], CPU FAN speed will slow down.
               Fix the bug that system FAN speed always show "N/A".
02.BBU-06, QTC-03922, QTC-22763: Update the [Restore on AC Power Loss] function.
03.BBU-09, QTC-49469: Delete "Type:" to show CPU information fully in setup menu.
04.BBU-11: According to PM's request, add [Boots Graphic Adapter Priority] item, set its default value as [PEG/IGD].
05.BBU-15: Fix the bug that the system can not resume from S5 with PS/2 keyboard Hot Key.
06.BBU-20: Update the F_USB3 and F_USB4 ports over-current function.
07.BBU-22: Fix the bug that system can be resumed from S3/S4 by PS/2 KB&MS with any key.
08.QTC-90700: Disable PS/2 KB wake up from S3 when pressing any key.
09.QTC-09723: Disable PS/2 KB wake up from S4 when pressing any key.
10.QTC-49184: When pressing "Ctrl+F1", show [Smart Fan Start PWM Value], [System Smart Fan Function] and so on in [Hardware Monitor Setup].
11.QTC-07880: Add [VBIOS] item, VBIOS version: 1533.
12.QTC-49428: Add Hot Key "F11" to [Discard changes and Exit].
13.QTC-83232: Enable PS/2 KB wake up from S5 when pressing the Hot Key (Ctrl+Alt+<--).
14.QTC-64390: Remove all help information about F7 because F7 have no function in THTF spec.
15.QTC-32271: Remove [Auto] option in [ACPI Suspend Mode].
16.QTC-59944: Add [Password] and [Hotkey] options in [Power Management Features]-->[Power On PS/2 KB].
       Add [KB Power On Password] item in [Power Management Features].
       Fix the default value of [Restore On AC Power Loss] to [Power on].
17.QTC-16778: Fix the wrong string "ALL Errors But KeyBoar" to "ALL Errors But KeyBoard".
18.QTC-65013: Remove COM2, LPT port in OS Device Manager.
19.QTC-95196: Update LAN Boot ROM to support RPL and PXE function.
20.QTC-28063: When set [Onboard Serial Port 1] as 2F8/IRQ3 in BIOS it show normally in
       OS-->Device Manager-->Port-->COM1-->resources.
IPX31-GS-THTF-0601-20090112.ROM 1/13/2009
Checksum: 8C58h
01.BBU-1: Set power LED on at S0, blink at S1, and off at S3/4/5.
02.BBU-2: Remove [SATA3], [Third IDE Master] and [Third IDE Slave] items in setup menu.
03.BBU-4: Remove floppy in boot menu because IPX31 do not support floppy.
04.BBU-8: Remove [Onboard Parallel Port] and [Parallel Port Mode] items in setup menu because IPX31 do not support parallel port.
05.BBU-10: Add [Execute Disable Function] item in setup menu.
06.Update ALC662 to VT1708S: update verb table.
07.Fix the bug when set [SATA Mode] as [Auto], system can not find boot device.
08.Fix the bug when set [Onboard LAN Boot ROM] as [Disabled], system can still boot from LAN boot ROM.
09.Fix [Standard CMOS Steup] to [Standard CMOS Setup] in setup menu.
10.Update strings in setup menu to meet THTF spec.
IPX31-GS-THTF-0001-20081229.ROM 12/29/2008
Checksum: 7E08h
01.Initial BIOS.
IPX31-GS-THTF-0014-20091017(bat).zip
543.39 KB, 下载次数: 112, 下载积分: 下载分 -2 分, 下载 1 次
