OpenPuff is a professional steganography tool, with unique features you won’t find among any other free or commercial software. OpenPuff is 100% free and suitable for highly sensitive data covert transmission.
OpenPuff是一种专业的隐写工具,具有独特的功能,您不会在任何其他免费或商业软件中找到。OpenPuff是100%免费,适用于高灵敏度数据隐蔽传输。
The tool contains deniable steganography, carrier chains, unique layers of security and obfuscation, multiple carrier formats, is portable and is freeware (ad-free). 该工具包含可隐蔽的隐写术,载体链,独特的安全和混淆层,多种载体格式,便携式,免费(免费)。 Features 特征 Carrier chains – Data is split among many carriers. Only the correct carrier sequence enables unhiding. Moreover, up to 256Mb can be hidden, if you have enough carriers at disposal. Last carrier will be filled with random bits in order to make it undistinguishable from others. 运营商链 - 数据在许多运营商之间分配。只有正确的载波序列才能取消隐藏。此外,如果您有足够的运营商处理,高达256Mb可以隐藏。最后一个载波将被填充随机比特,以使其与其他人不可区分。 Supported formats – Images, audios, videos, flash, adobe. 支持的格式 - 图像,音频,视频,闪存,adobe。 Layers of security – Data, before carrier injection, is encrypted (1), scrambled (2), whitened (3) and encoded (4). 安全层 - 载波注入之前的数据被加密(1),加扰(2),增白(3)和编码(4)。 Extra security (Deniable steganography) – Top secret data can be protected using less secret data as a decoy. 额外的安全性(Deniable steganography) - 最奥秘的数据可以运用较少的奥秘数据作为诱饵来保护。 Source code – This program relies on the libObfuscate system-independent open-source library. 源代码 - 该程序依赖于libObfuscate系统独立的开源库。
Details 细节 HW seeded random number generator (CSPRNG) HW种子随机数发生器(CSPRNG) Deniable steganography 可靠的隐写术 Carrier chains (up to 256Mb of hidden data) 载波链(高达256Mb的隐藏数据) Carrier bits selection level 载波位选择电平 Modern multi-cryptography (16 algorithms) 现代多密码学(16种算法) Multi-layered data obfuscation (3 passwords) 多层数据混淆(3个密码) X-squared steganalysis resistance X平方隐匿分析抗性 256bit+256bit symmetric-key cryptography (with KDF4 password extension) 256bit + 256bit对称密钥加密(带KDF4密码扩展) 256bit symmetric-key data scrambling (CSPRNG-based shuffling) 256bit对称密钥数据加扰(基于CSPRNG的改组) 256bit symmetric-key data whitening (CSPRNG-based noise mixing) 256bit对称密钥数据白化(基于CSPRNG的噪声混合) Adaptive non-linear carrier bit encoding 自适应非线性载波比特编码 Images (BMP, JPG, PCX, PNG, TGA) 图像(BMP,JPG,PCX,PNG,TGA) Audio support (AIFF, MP3, NEXT/SUN, WAV) 音频支持(AIFF,MP3,NEXT / SUN,WAV) Video support (3GP, MP4, MPG, VOB) 视频支持(3GP,MP4,MPG,VOB) Flash-Adobe support (FLV, SWF, PDF) Flash-Adobe支持(FLV,SWF,PDF) Native portable structure (no installation, registry keys, .ini files) 本机便携式结构(无安装,注册表项,.ini文件) Runs in user mode with DEP on 以DEP开启用户模式 Multithread support (up to 16 处理器s) = Faster processing 多线程支持(最多16个处理器)=更快的处理速度 Spyware/adware-free 间谍软件/广告软件免费 Fully redistributable 完全可再分发 OpenSource core crypto-library (libObfuscate) OpenSource核心加密库(libObfuscate)
