查看: 1249|回复: 0
arm开关中断汇编接口
发表于 2016-7-26 07:24:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
;                                                EQUATES
CPU_ARM_CTRL_INT_DIS  EQU       0xC0                            ; Disable both FIQ & IRQ
;                                      CODE GENERATION DIRECTIVES
    AREA _CPU_A_CODE_, CODE, READONLY
    ARM
;$PAGE
;                                      CRITICAL SECTION FUNCTIONS
; Description : Disable/Enable interrupts by preserving the state of interrupts.  Generally speaking, the
;               state of the interrupt disable flag is stored in the local variable 'cpu_sr' & interrupts
;               are then disabled ('cpu_sr' is allocated in all functions that need to disable interrupts).
;               The previous interrupt state is restored by copying 'cpu_sr' into the CPU's status register.
; Prototypes  : CPU_SR  CPU_SR_Save   (void);
;               void    CPU_SR_Restore(CPU_SR cpu_sr);
CPU_SR_Save
        MRS     R0, CPSR
CPU_SR_Save_Loop
        ; Set IRQ & FIQ bits in CPSR to DISABLE all interrupts
        ORR     R1, R0, #CPU_ARM_CTRL_INT_DIS
        MSR     CPSR_c, R1
        MRS     R1, CPSR                                        ; Confirm that CPSR contains the proper interrupt disable flags
        AND     R1, R1, #CPU_ARM_CTRL_INT_DIS
        CMP     R1,     #CPU_ARM_CTRL_INT_DIS
        BNE     CPU_SR_Save_Loop                                ; NOT properly DISABLED (try again)
        BX      LR                                              ; DISABLED, return the original CPSR contents in R0
CPU_SR_Restore                                                  ; See Note #2
        MSR     CPSR_c, R0
        BX      LR
;$PAGE
;                                     CPU ASSEMBLY PORT FILE END
        END
