查看: 1095|回复: 0
如何确保不会出现抖动且按紧不会熄灭 代码
发表于 2016-3-15 13:52:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar code du[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code we[] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
sbit dula = P2^6;
sbit wela = P2^7;
sbit coke = P2^3;
uchar shi,fen,miao,aa;
void display(uchar);
void delay(uint z)
        uint x;
        for(;z>0;z--)
                for(x=110;x>0;x--);
void mm(uchar a,k)
        wela=1;
        P0=we[a];
        wela=0;
        dula=1;
        P0=du[k];
        dula=0;
        delay(1);
        P0=0xff;
void main()
        uchar temp;
        uchar miao_ge,miao_shi,fen_ge,fen_shi;
        uchar shi_ge,shi_shi;
        aa=0;
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        while(1)
                miao_ge        =(miao%10);
                miao_shi=(miao/10);
                fen_ge=(fen%10);
                fen_shi=(fen/10);
                shi_ge=(shi%10);
                shi_shi=(shi/10);
                dula=1;
                wela=1;
          mm(5,miao_ge);
                mm(4,miao_shi);
                mm(3,fen_ge);
                mm(2,fen_shi);
                mm(1,shi_ge);
                mm(0,shi_shi);
                dula = 0;
                wela = 0;
                P0 = 0xff;
                if(aa<10)
                        dula = 1;
                        P0 = 0x80;
                        dula = 0;
                        wela = 1;
                        P0 = 0x15;
                        wela = 0;
                        P0 = 0xff;
void timer0() interrupt 1
        aa++;
        if(aa==20)
                aa=0;
                miao++;
                if(miao>59)
                                fen++;
                        miao=0;
                if(fen>59)
                                shi++;
                        fen=0;
                if(shi>23)
                        shi=0;
        if(fen==0&&miao==0)
                        coke=0;
                else
                        coke=1;
